DVD Player Ground
LarryRosen
PostPosted: Tue Oct 24, 2006 5:50 am    Post subject: DVD Player Ground Reply with quote
Should the ground to the DVD player that I am installing in my RV-10 be
grounded pack to the cockpit ground bus?
See aeroelectric Z15-3 here
<http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z15-3.pdf>
Larry Rosen
RV-10 #356
Larry Rosen
#40356
N205EN (reserved)
<http>
nuckollsr(at)cox.net
PostPosted: Tue Oct 24, 2006 7:51 am    Post subject: DVD Player Ground Reply with quote
Larry Rosen
RV-10 #356
Sure (or the avionics ground bus). It's a potential victim
of ground-loop noises. Now, having said that, be aware that
many appliances have case grounds that parallel their
pin-out grounds in connectors. This is one of the reasons
the panel or avionics ground bus was added to the panel at
Rev 11. This drastically shortens any potential ground loops
due to case grounds running in parallel with wired grounds.
< What is so wonderful about scientific truth...is that >
< the authority which determines whether there can be >
< debate or not does not reside in some fraternity of >
< scientists; nor is it divine. The authority rests >
< with experiment. >
< --Lawrence M. Krauss >
