				|  | Matronics Email Lists Web Forum Interface to the Matronics Email Lists
		| Author | Message |
		| motoadve
				|  Posted: Sun Dec 13, 2020 5:19 pm    Post subject: Artificial horizon staying tilted after aerobatics. |   |
				| Artificial horizon, starts good, works good in normal flight first couple rolls still good, then if I do a sequence like aileron roll right, then roll left, loop, barrel roll, then I go to level flight, the AI stays tilted for the next 10 or 15 minutes.
Any ideas?
 | |  |  | - The Matronics Yak-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Yak-List
 www.Backcountry182.com
 Cessna 182 P
 CJ -6
		| Back to top |  |
		| Ttail
				|  Posted: Sun Dec 13, 2020 6:26 pm    Post subject: Re: Artificial horizon staying tilted after aerobatics. |   |
				| I had a similar issue in my CJ. Put a new one ... problem went away.
 Sean Trestrail
 ttail[at]internode.on.net
		| Back to top |  |
		| n13472(at)aol.com Guest
				|  Posted: Sun Dec 13, 2020 7:01 pm    Post subject: Artificial horizon staying tilted after aerobatics. |   |
				| Could be low output from the rotary power converter
Tom Elliott
 CJ-6A NX63727
 777 Quartz Ave
 PMB 7004
 Sandy Valley NV.
 89019
 Cell 541-297-5497
 N13472(at)AOL.COM
		| Back to top |  |
		| easy_driver
				|  Posted: Mon Dec 14, 2020 12:14 pm    Post subject: Re: Artificial horizon staying tilted after aerobatics. |   |
				| something in that box went TU. could be electrolytic  "vertical" sensor, correction mechanism switch or driving motor - to name a few.
 or you naughty boy exceeded 120d/s max roll rate
		| Back to top |  |
		| Ttail
				|  Posted: Mon Dec 14, 2020 3:01 pm    Post subject: Re: Artificial horizon staying tilted after aerobatics. |   |
				| "or you naughty boy exceeded 120d/s max roll rate"
 How do you get a Chang to do that ?
 Sean Trestrail
		| Back to top |  |
		| easy_driver
				|  Posted: Mon Dec 14, 2020 3:16 pm    Post subject: Re: Artificial horizon staying tilted after aerobatics. |   |
				| let me guess - a snap roll at maneuvering speed ?
		| Back to top |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
