motoadve
Posted: Sun Dec 13, 2020 5:19 pm Post subject: Artificial horizon staying tilted after aerobatics. |
Artificial horizon, starts good, works good in normal flight first couple rolls still good, then if I do a sequence like aileron roll right, then roll left, loop, barrel roll, then I go to level flight, the AI stays tilted for the next 10 or 15 minutes.
Any ideas?
_________________ www.Backcountry182.com
Cessna 182 P
CJ -6 |
Ttail
Posted: Sun Dec 13, 2020 6:26 pm Post subject: Re: Artificial horizon staying tilted after aerobatics. |
I had a similar issue in my CJ. Put a new one ... problem went away.
_________________ Sean Trestrail
ttail[at]internode.on.net |
n13472(at)aol.com Guest
Posted: Sun Dec 13, 2020 7:01 pm Post subject: Artificial horizon staying tilted after aerobatics. |
Could be low output from the rotary power converter
Tom Elliott
CJ-6A NX63727
777 Quartz Ave
PMB 7004
Sandy Valley NV.
89019
Cell 541-297-5497
N13472(at)AOL.COM
easy_driver
Joined: 25 Jul 2020 Posts: 13 Location: Alexandria, VA
Posted: Mon Dec 14, 2020 12:14 pm Post subject: Re: Artificial horizon staying tilted after aerobatics. |
something in that box went TU. could be electrolytic "vertical" sensor, correction mechanism switch or driving motor - to name a few.
or you naughty boy exceeded 120d/s max roll rate
Ttail
Posted: Mon Dec 14, 2020 3:01 pm Post subject: Re: Artificial horizon staying tilted after aerobatics. |
"or you naughty boy exceeded 120d/s max roll rate"
How do you get a Chang to do that ?
easy_driver
Posted: Mon Dec 14, 2020 3:16 pm Post subject: Re: Artificial horizon staying tilted after aerobatics. |
let me guess - a snap roll at maneuvering speed ?
