Orientation of NAV/VOR antenna compared to COM antenna
christoph.both(at)acadiau
PostPosted: Mon May 14, 2018 5:35 am    Post subject: Orientation of NAV/VOR antenna compared to COM antenna Reply with quote
Hello Europa Builders,
I am about to add a separate antenna to my vertically installed COM antenna (which works fine).
Is this correct: for best NAV/VOR reception: install Horizontally, that is centre antenna located at top fuselage, bending both ends down.
Christoph Both
#223 Wolfville Nova Scotia, Canada
carlp101
PostPosted: Mon May 14, 2018 7:40 am    Post subject: Re: Orientation of NAV/VOR antenna compared to COM antenna Reply with quote
Hi Christoph,
I've just fitted a VOR/GS antenna on the belly of my Europa Tri-Gear just aft of the hatch for the central tunnel on the underside (see attached pic). It works a treat and it's all signed-off by the LAA inspector! It's a CI 157P antenna. You can either have the V of the antenna pointing forwards or backwards.
Carl
G-URMS
 Filesize:  279.68 KB
 Viewed:  4413 Time(s)
PostPosted: Wed May 16, 2018 6:42 pm    Post subject: Orientation of NAV/VOR antenna compared to COM antenna Reply with quote
Very helpful advice, thank you!
Now, the question remains, is it better to orient the antenna horizontally for NAV, compared to vertically for COM?
Christoph
On 2018-05-16, 11:26, "owner-europa-list-server(at)matronics.com on behalf of AirEupora" <owner-europa-list-server(at)matronics.com on behalf of AirEupora(at)sbcglobal.net> wrote:
BOB Archer makes a whole set of antennas for glass aircraft. Aircraft Spruce sells them. I put my VOR antenna in the wing. I can get a good signal fifty to sixty miles away.
http://www.aircraftspruce.com/catalog/avpages/archer_antenna7.php?clickkey=5123597
I hope you have not closed out your wing. If you have then you could built a Balun antenna.
http://www.aeroelectric.com/articles/BALUN/Balun_Fabrication.html
http://forums.matronics.com/viewtopic.php?p=480170#480170
