christoph.both(at)acadiau Guest
Posted: Mon May 14, 2018 5:35 am Post subject: Orientation of NAV/VOR antenna compared to COM antenna |
Hello Europa Builders,
I am about to add a separate antenna to my vertically installed COM antenna (which works fine).
Is this correct: for best NAV/VOR reception: install Horizontally, that is centre antenna located at top fuselage, bending both ends down.
Christoph Both
#223 Wolfville Nova Scotia, Canada
carlp101
Posted: Mon May 14, 2018 7:40 am Post subject: Re: Orientation of NAV/VOR antenna compared to COM antenna |
Hi Christoph,
I've just fitted a VOR/GS antenna on the belly of my Europa Tri-Gear just aft of the hatch for the central tunnel on the underside (see attached pic). It works a treat and it's all signed-off by the LAA inspector! It's a CI 157P antenna. You can either have the V of the antenna pointing forwards or backwards.
Carl
G-URMS
279.68 KB |
4347 Time(s) |
Posted: Wed May 16, 2018 6:42 pm Post subject: Orientation of NAV/VOR antenna compared to COM antenna |
Very helpful advice, thank you!
Now, the question remains, is it better to orient the antenna horizontally for NAV, compared to vertically for COM?
Christoph
On 2018-05-16, 11:26, "owner-europa-list-server(at)matronics.com on behalf of AirEupora" <owner-europa-list-server(at)matronics.com on behalf of AirEupora(at)sbcglobal.net> wrote:
BOB Archer makes a whole set of antennas for glass aircraft. Aircraft Spruce sells them. I put my VOR antenna in the wing. I can get a good signal fifty to sixty miles away.
http://www.aircraftspruce.com/catalog/avpages/archer_antenna7.php?clickkey=5123597
I hope you have not closed out your wing. If you have then you could built a Balun antenna.
http://www.aeroelectric.com/articles/BALUN/Balun_Fabrication.html
http://forums.matronics.com/viewtopic.php?p=480170#480170
