wrong rivets used
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV9-List
nealtrombley
PostPosted: Tue May 09, 2017 8:32 am    Post subject: wrong rivets used Reply with quote
I am building my 9a HS and somehow used 426AD3 3.5 ( skin to ribs)
than 426ad3- 4 (skin to spar )
I only did the left skin before noticing and I bucked riveted this thing fairly well..
they look great, but you can see on the right side with the correct rivet has more meat to it>>
should I start drilling?
__________________
Neal Trombley
4520 Randag Dr
North Fort Myers, Fl 33903
Office 239-995-0683
Cell 239-281-6325
Fax 239-995-0753
neal(at)gulfatl.net
www.gulfatl.net
- The Matronics RV9-List Email Forum -
http://www.matronics.com/Navigator?RV9-List
Neal Trombley
KFMY
neil(at)rosoff.com
PostPosted: Tue May 09, 2017 9:00 am    Post subject: wrong rivets used Reply with quote
Get yourself a rivet Guage. If they are close don't worry about it. Vans rivet pitch is over twice what is needed. If they are to far out of guage, than I would replace them.
Neil Rosoff
On May 9, 2017, at 12:31 PM, Neal Trombley <neal(at)gulfatl.net (neal(at)gulfatl.net)> wrote:
<![endif]--> <![endif]-->
__________________
Neal Trombley
4520 Randag Dr
Office 239-995-0683
Cell 239-281-6325
Fax 239-995-0753
www.gulfatl.net
gbrasch
PostPosted: Tue May 09, 2017 9:14 am    Post subject: Re: wrong rivets used Reply with quote
I agree, but a picture would help.
Glenn Brasch
RV-9A Flying
Medevac Helicopter Pilot (Ret)
Owner, "Airport Courtesy Cars" Website www.airportcourtesycars.com
nealtrombley
PostPosted: Tue May 09, 2017 9:19 am    Post subject: wrong rivets used Reply with quote
 Filesize:  971.5 KB
 Viewed:  15156 Time(s)
 Filesize:  912.23 KB
ATT00001.txt
 Filename:  ATT00001.txt
 Filesize:  1.69 KB
 Downloaded:  885 Time(s)
Neal Trombley
KFMY
nealtrombley
PostPosted: Tue May 09, 2017 9:20 am    Post subject: wrong rivets used Reply with quote
Correct rivet used here
 Filesize:  984.96 KB
ATT00001.txt
 Filesize:  1.69 KB
 Downloaded:  876 Time(s)
Neal Trombley
KFMY
neil(at)rosoff.com
PostPosted: Tue May 09, 2017 4:39 pm    Post subject: wrong rivets used Reply with quote
Some (not all) look over driven, or they were to short. The Gauge should be your guide. Three helpful tips for you. Center punch rivets you drill out, this will prevent the bit from wandering and damaging the skin. Use a bit that is 1 or 2 sizes smaller that than the rivet diameter (i.e. Drill out #40s with #41 or #42), this will help with not over enlarging the hole. If you are riveting an area you are having seeing the shop head, press you finger hard on shop head and look at the indentation, not an exact gauge, that is how many old timers do it.
From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of Neal Trombley
Sent: Tuesday, May 9, 2017 1:19 PM
To: rv9-list(at)matronics.com
Subject: Re: Re: wrong rivets used
nealtrombley
PostPosted: Tue May 09, 2017 6:23 pm    Post subject: wrong rivets used Reply with quote
Thank you
I changed quite a few that were not measuring up.
Neal Trombley  239-281-6325
On May 9, 2017, at 8:42 PM, Neil Rosoff <neil(at)rosoff.com (neil(at)rosoff.com)> wrote:
From: owner-rv9-list-server(at)matronics.com (owner-rv9-list-server(at)matronics.com) [mailto:owner-rv9-list-server(at)matronics.com (owner-rv9-list-server(at)matronics.com)] On Behalf Of Neal Trombley
To: rv9-list(at)matronics.com (rv9-list(at)matronics.com)
Subject: Re: RV9-List: Re: wrong rivets used
Neal Trombley
KFMY
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV9-List All times are GMT - 8 Hours
