nealtrombley
Posted: Tue May 09, 2017 8:32 am Post subject: wrong rivets used |
I am building my 9a HS and somehow used 426AD3 3.5 ( skin to ribs)
than 426ad3- 4 (skin to spar )
I only did the left skin before noticing and I bucked riveted this thing fairly well..
they look great, but you can see on the right side with the correct rivet has more meat to it>>
should I start drilling?
__________________
Neal Trombley
4520 Randag Dr
North Fort Myers, Fl 33903
Office 239-995-0683
Cell 239-281-6325
Fax 239-995-0753
neal(at)gulfatl.net
www.gulfatl.net
| | - The Matronics RV9-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV9-List |
_________________ Neal Trombley
KFMY |
neil(at)rosoff.com Guest
Posted: Tue May 09, 2017 9:00 am Post subject: wrong rivets used |
Get yourself a rivet Guage. If they are close don't worry about it. Vans rivet pitch is over twice what is needed. If they are to far out of guage, than I would replace them.
Neil Rosoff
On May 9, 2017, at 12:31 PM, Neal Trombley <neal(at)gulfatl.net (neal(at)gulfatl.net)> wrote:
| Quote: | <![endif]--> <![endif]-->
__________________
Neal Trombley
4520 Randag Dr
Office 239-995-0683
Cell 239-281-6325
Fax 239-995-0753
www.gulfatl.net
gbrasch
Posted: Tue May 09, 2017 9:14 am Post subject: Re: wrong rivets used |
I agree, but a picture would help.
_________________ Glenn Brasch
RV-9A Flying
Medevac Helicopter Pilot (Ret)
Owner, "Airport Courtesy Cars" Website www.airportcourtesycars.com |
nealtrombley
Posted: Tue May 09, 2017 9:19 am Post subject: wrong rivets used |
971.5 KB |
15182 Time(s) |
912.23 KB |
15182 Time(s) |
 Download |
| Filename: |
ATT00001.txt |
1.69 KB |
| Downloaded: |
885 Time(s) |
KFMY |
nealtrombley
Posted: Tue May 09, 2017 9:20 am Post subject: wrong rivets used |
Correct rivet used here
984.96 KB |
15182 Time(s) |
 Download |
| Filename: |
ATT00001.txt |
1.69 KB |
| Downloaded: |
876 Time(s) |
KFMY |
Posted: Tue May 09, 2017 4:39 pm Post subject: wrong rivets used |
Some (not all) look over driven, or they were to short. The Gauge should be your guide. Three helpful tips for you. Center punch rivets you drill out, this will prevent the bit from wandering and damaging the skin. Use a bit that is 1 or 2 sizes smaller that than the rivet diameter (i.e. Drill out #40s with #41 or #42), this will help with not over enlarging the hole. If you are riveting an area you are having seeing the shop head, press you finger hard on shop head and look at the indentation, not an exact gauge, that is how many old timers do it.
From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of Neal Trombley
Sent: Tuesday, May 9, 2017 1:19 PM
To: rv9-list(at)matronics.com
Subject: Re: Re: wrong rivets used
nealtrombley
Posted: Tue May 09, 2017 6:23 pm Post subject: wrong rivets used |
Thank you
I changed quite a few that were not measuring up.
Neal Trombley 239-281-6325
On May 9, 2017, at 8:42 PM, Neil Rosoff <neil(at)rosoff.com (neil(at)rosoff.com)> wrote:
From: owner-rv9-list-server(at)matronics.com (owner-rv9-list-server(at)matronics.com) [mailto:owner-rv9-list-server(at)matronics.com (owner-rv9-list-server(at)matronics.com)] On Behalf Of Neal Trombley
To: rv9-list(at)matronics.com (rv9-list(at)matronics.com)
Subject: Re: RV9-List: Re: wrong rivets used
KFMY |
