DRDT-2 Table
Kearney(at)shaw.ca
PostPosted: Tue Sep 26, 2006 6:14 am    Post subject: DRDT-2 Table Reply with quote
Hi
In anticipation of ordering an empennage kit on Tuesday next, I have been busy getting my workspace ready. To that end I have built two regulation EAA work tables and now would like to build a table / stand for a DRDT-2 dimplier.
Does anyone have plans for such a beast so I can build the table in advance of receiving my tool order?
Many thanks
Les
RV10 Wannabe
UFOBUCK(at)aol.com
PostPosted: Tue Sep 26, 2006 6:26 am    Post subject: DRDT-2 Table Reply with quote
In a message dated 9/26/2006 9:16:50 A.M. Central Daylight Time, Kearney(at)shaw.ca writes:
.....To that end I have built two regulation EAA work tables .....
There is an EAA regulation to the size of my work benches ????
This is getting too complicated. %-)
Bob Collins
PostPosted: Tue Sep 26, 2006 6:58 am    Post subject: DRDT-2 Table Reply with quote
Here you go
http://www.experimentalaero.com/DRDT-2%20Manual%20&%20Drawings.pdf
Bob Collins
RV Builder's Hotline
http://home.comcast.net/~rvnewsletter/
Bob Collins
St. Paul, Minn.
Letters from Flyover Country
http://rvnewsletter.blogspot.com/
lsbrv7a(at)yahoo.com
PostPosted: Tue Sep 26, 2006 7:06 am    Post subject: DRDT-2 Table Reply with quote
Les, This is the table I made. The EAA tables are level with adn suppor the work.
LES KEARNEY <Kearney(at)shaw.ca> wrote:
--> RV-List message posted by: LES KEARNEY
Hi
Many thanks
Les
RV10 Wannabe
Sherman Butler
RV-7a Wings
Idaho Falls
 Filesize:  606.5 KB
 Viewed:  1056 Time(s)
carlosh(at)sec-engr.com
PostPosted: Tue Sep 26, 2006 7:09 am    Post subject: DRDT-2 Table Reply with quote
LES KEARNEY wrote:
Hi
Many thanks
Les
RV10 Wannabe
Here you go.
Carlos RV7A N174PP "Pretty Penny"
Carlos Hernandez
Structural Engineers, LLC
2111 E. Broadway Rd. - Suite 3
Tempe, AZ 85282
Phone: 480.968.8600
Fax: 480.968.8608
www.sec-engr.com
LloydDR(at)wernerco.com
PostPosted: Tue Sep 26, 2006 7:13 am    Post subject: DRDT-2 Table Reply with quote
Here is a copy of the plans you will get from Experimentalaero when you
purchase your DRDT-2
Dan
40269 (N289DT)
drdt-2_platform.pdf
 Filename:  drdt-2_platform.pdf
 Filesize:  102.01 KB
 Downloaded:  651 Time(s)
smittysrv
PostPosted: Tue Sep 26, 2006 7:31 am    Post subject: DRDT-2 Table Reply with quote
Yeah, and you have to spend a minimum of 5.25 hours in construction on the
tables, take pictures and get a DAR sign off.
(jes' kidding)
Smitty's RV
http://SmittysRV.com
Original Message:
Date: Tue, 26 Sep 2006 10:25:19 EDT
To: rv-list(at)matronics.com
Subject: Re: Re: DRDT-2 Table
mail2web - Check your email from the web at
http://mail2web.com/ .
Smittys RV-9A
SmittysRV.com
jjessen
PostPosted: Tue Sep 26, 2006 8:39 am    Post subject: DRDT-2 Table Reply with quote
Did you save the cutting list? Nice job!
John Jessen
RV-10
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Sherman Butler
Sent: Tuesday, September 26, 2006 8:05 AM
Hi
Many thanks
Les
RV10 Wannabe
Sherman Butler
RV-7a Wings
Idaho Falls
PostPosted: Tue Sep 26, 2006 5:58 pm    Post subject: DRDT-2 Table Reply with quote
John,
The table is 2' X 3' . I started with the EAA table dimensions and I shortened the legs the height of the DRDT-2 table and wheels combined, placed the bottom shelf on the bottom to provide a larger bearing area for the wheel frames. The sliding table is much like the table in the DRDT-2 plans. I used heavy wheels to provide ballast to the table.
My son was here for the weekend, and he worked one summer in a belly landing repair shop. He LOVED it ------- until I showed him the pneumatic squeezer.
John Jessen
RV-10
Many thanks
Les
Sherman Butler
RV-7a Wings
Idaho Falls
Sherman Butler
RV-7a Wings
Idaho Falls
Get your email and more, right on the [url=http://us.rd.yahoo.com/evt=42973/*http://www.yahoo.com/preview] new Yahoo.com[/url] [quote][b]
dmaib@me.com
PostPosted: Tue Sep 26, 2006 7:13 pm    Post subject: DRDT-2 Table Reply with quote
Les,
I built two of the EAA work tables and am very happy with them. I
built the DRDT-2 table from the plans that came with the DRDT-2 and
it is great. Here is a photo of the DRDT-2 table.
[IMG]
http://img87.imageshack.us/img87/88/img0652jd6.th.jpg[/IMG]
David Maib
#40559
On Sep 26, 2006, at 9:13 AM, LES KEARNEY wrote:
Hi
Many thanks
Les
RV10 Wannabe
David Maib
RV-10 #40559
New Smyrna Beach, FL
william(at)gbta.net
PostPosted: Thu Oct 05, 2006 5:17 am    Post subject: DRDT-2 Table Reply with quote
Les, I've got 2 of the 3' X 5' tables also. Due to lack of space in my
garage for another table that will be used minimally, I just slid the two
tables together end to end and screwed the DRDT-2 to a 2 X 6, then I screwed
the 2 X 6 on to the legs of each table (so the dimpling sets were flush with
the table top). Now, when I don't need it (the DRDT-2) I can either unscrew
the dimpler form the board and leave the board on the tables (leaves me a
gap between tables about 6-8 inches wide) or remove the board completely. I
know that every time I need to do some dimpling I have to mess with screwing
either the whole setup back on or atleast the dimpler back on. But, for no
more often than you really use the dimpler it's not that big of a deal,
especially if you've got a cordless drill.
CLEAR AS MUD, right???
If you would like to see some pictures let me know.
Bill Britton
