johngoodman
Posted: Wed Sep 20, 2006 1:24 pm Post subject: Cutting an oval hole |
I'm in the early stages of the Horizontal Stab and the plans show cutting an oval hole in two of the leading ribs for the trim cables. the plans show the hole to be 1.5" by .5". I can think of lots of ways to do it and each one gives me nightmares of a buggered job.
Any suggestions?
John
_________________ #40572 Phase One complete in 2011 |
Rick S.
Posted: Wed Sep 20, 2006 1:42 pm Post subject: Cutting an oval hole |
John,
It's only for the passing of the trim cables and not that critical. I hand drew mine and just used a uni bit in the middle then nibbled it out with a nibbler and deburred. you can pass the trim cable through to se if you have any areas that may hang up. It is fun to route these when your done, actually it's a pain but I used a clothes hanger to pull it through.
Rick S.
40185
_________________ Rick S.
RV-10
40185 |
jjessen
Posted: Wed Sep 20, 2006 1:57 pm Post subject: Cutting an oval hole |
John,
Go here ( http://www.jessen-RV10.com ) and go to Empennage, HS, Page 8-7,
then see step #4. Click on the picture to get a better view.
John Jessen
#40328
Vern(at)teclabsinc.com Guest
Posted: Wed Sep 20, 2006 2:31 pm Post subject: Cutting an oval hole |
John,
One way is to drill a pilot hole and use a Demel tool to enlarge it.
Vern (#40324)
Posted: Wed Sep 20, 2006 3:48 pm Post subject: Cutting an oval hole |
Another way is to use your Unibit to make two holes side-by-side and
then trim out the rest.
Linn
Vern W. Smith wrote:
John,
Vern (#40324)
jjessen
Posted: Wed Sep 20, 2006 4:21 pm Post subject: Cutting an oval hole |
Linn has it right. Just go to jessen-rv10.com and take a look at the series
of pictures in the thumbnails. You get to the thumbnails by clicking on the
picture for that particular step under the HS section. You'll see the
procedure, step by step. Making the hole as shown in the plans is easy to
do.
John Jessen
#40328 Tailcone
John Ackerman
Joined: 19 Jun 2006 Posts: 130 Location: Prescott, AZ
Posted: Wed Sep 20, 2006 6:26 pm Post subject: Cutting an oval hole |
John, in retrospect, this looks a lot worse than it is - like so many
things on the 10.
I found that the left hole needs to be enlarged anyway, to keep from
cutting the trim cable housing. Others probably know better methods,
but I drilled a stater hole, then cut to the line with a carbide burr
on a cheap ($5.00!!) die grinder from Harbor Freight and deburred.
John Ackerman
40458 wings
On Sep 20, 2006, at 2:24 PM, johngoodman wrote:
Quote: |
<johngoodman(at)earthlink.net>
Any suggestions?
John
#40572 Empennage
N711JG reserved
http://forums.matronics.com/viewtopic.php?p=62844#62844
Jack.Phillips(at)cardinal Guest
Posted: Thu Sep 21, 2006 3:27 am Post subject: Cutting an oval hole |
I'm at the same stage John, and will cut those holes tonight. I plan to
use a hole saw and then elongate the holes with a rat-tail file.
Jack Phillips
#40610
N142KW reserved
jdalton77(at)comcast.net Guest
Posted: Thu Sep 21, 2006 5:28 am Post subject: Cutting an oval hole |
A file didn't work so well for me - I used a step drill and a dremel tool.
Worked great but was loud!
Rick S.
Posted: Thu Sep 21, 2006 5:34 am Post subject: Cutting an oval hole |
Jack,
You like metal work huh? I hated using a file on sheet metal to enlarge holes mainly because it would grab and distort the hole but it was mostly my lack of technique and laziness to break out the dremel tool. Although I used the large fine vixen on the edges to remove the tooloing and clean up the edge. Two light passes then followed with the V-grove deburr tool and a light buff with the scotchbite made the aluminum sheet just as smooth and polished as you could ever want.
Rick S.
40185
RV-10
40185 |
johngoodman
