Cutting an oval hole
johngoodman
PostPosted: Wed Sep 20, 2006 1:24 pm    Post subject: Cutting an oval hole Reply with quote
I'm in the early stages of the Horizontal Stab and the plans show cutting an oval hole in two of the leading ribs for the trim cables. the plans show the hole to be 1.5" by .5". I can think of lots of ways to do it and each one gives me nightmares of a buggered job.
Any suggestions?
Rick S.
PostPosted: Wed Sep 20, 2006 1:42 pm    Post subject: Cutting an oval hole Reply with quote
John,
It's only for the passing of the trim cables and not that critical. I hand drew mine and just used a uni bit in the middle then nibbled it out with a nibbler and deburred. you can pass the trim cable through to se if you have any areas that may hang up. It is fun to route these when your done, actually it's a pain but I used a clothes hanger to pull it through.
Rick S.
40185
Rick S.
RV-10
40185
jjessen
PostPosted: Wed Sep 20, 2006 1:57 pm    Post subject: Cutting an oval hole Reply with quote
John,
Go here ( http://www.jessen-RV10.com ) and go to Empennage, HS, Page 8-7,
then see step #4. Click on the picture to get a better view.
John Jessen
#40328
Vern(at)teclabsinc.com
PostPosted: Wed Sep 20, 2006 2:31 pm    Post subject: Cutting an oval hole Reply with quote
John,
One way is to drill a pilot hole and use a Demel tool to enlarge it.
Vern (#40324)
pitts_pilot(at)bellsouth.
PostPosted: Wed Sep 20, 2006 3:48 pm    Post subject: Cutting an oval hole Reply with quote
Another way is to use your Unibit to make two holes side-by-side and
then trim out the rest.
Linn
Vern W. Smith wrote:
John,
Vern (#40324)
jjessen
PostPosted: Wed Sep 20, 2006 4:21 pm    Post subject: Cutting an oval hole Reply with quote
Linn has it right. Just go to jessen-rv10.com and take a look at the series
of pictures in the thumbnails. You get to the thumbnails by clicking on the
picture for that particular step under the HS section. You'll see the
procedure, step by step. Making the hole as shown in the plans is easy to
do.
John Jessen
#40328 Tailcone
John Ackerman
PostPosted: Wed Sep 20, 2006 6:26 pm    Post subject: Cutting an oval hole Reply with quote
John, in retrospect, this looks a lot worse than it is - like so many
things on the 10.
I found that the left hole needs to be enlarged anyway, to keep from
cutting the trim cable housing. Others probably know better methods,
but I drilled a stater hole, then cut to the line with a carbide burr
on a cheap ($5.00!!) die grinder from Harbor Freight and deburred.
John Ackerman
40458 wings
On Sep 20, 2006, at 2:24 PM, johngoodman wrote:
<johngoodman(at)earthlink.net>
Any suggestions?
#40572 Empennage
N711JG reserved
http://forums.matronics.com/viewtopic.php?p=62844#62844
Jack.Phillips(at)cardinal
PostPosted: Thu Sep 21, 2006 3:27 am    Post subject: Cutting an oval hole Reply with quote
I'm at the same stage John, and will cut those holes tonight. I plan to
use a hole saw and then elongate the holes with a rat-tail file.
Jack Phillips
#40610
N142KW reserved
jdalton77(at)comcast.net
PostPosted: Thu Sep 21, 2006 5:28 am    Post subject: Cutting an oval hole Reply with quote
A file didn't work so well for me - I used a step drill and a dremel tool.
Worked great but was loud!
Rick S.
PostPosted: Thu Sep 21, 2006 5:34 am    Post subject: Cutting an oval hole Reply with quote
Jack,
You like metal work huh? I hated using a file on sheet metal to enlarge holes mainly because it would grab and distort the hole but it was mostly my lack of technique and laziness to break out the dremel tool. Although I used the large fine vixen on the edges to remove the tooloing and clean up the edge. Two light passes then followed with the V-grove deburr tool and a light buff with the scotchbite made the aluminum sheet just as smooth and polished as you could ever want.
Rick S.
40185
Rick S.
RV-10
40185
johngoodman
PostPosted: Thu Sep 21, 2006 8:11 am    Post subject: Re: Cutting an oval hole Reply with quote
I'd like to thank everyone for the quick responses and good ideas. I've been looking at the Uni Bit thinking it was the solution, but now I'm gonna go for it. I really appreciated the JJessen web site - you have a new lurker Wink
