mikelaundy(at)yahoo.co.uk Guest
Posted: Thu Jul 13, 2006 5:32 am Post subject: KF 3 loose wing ribs |
I bought a KF3 a few months back and I have discovered a couple of the ribs have movement in them when gently pressed through the fabric. Since I did not build the plane I don't know exactly how the inside of the wing is set out, but from the outside it seems there are 2 short ribs between each full chord rib. It is 2 of those short ones that don't appear to be attached to the upper skin,. I suspect someone has moved it in the hangar and pushed in the wrong place!
Can anyone give me an idea of how the wing is constructed, or even better a photo before covering.
Many thanks
Mike
[url=http://us.rd.yahoo.com/mail/uk/taglines/default/nowyoucan/pc_mag/*http://us.rd.yahoo.com/evt=40565/*http://uk.docs.yahoo.com/nowyoucan.html]All new Yahoo! Mail[/url] "The new Interface is stunning in its simplicity and ease of use." - PC Magazine
kingjohne(at)adelphia.net Guest
Posted: Thu Jul 13, 2006 6:13 am Post subject: KF 3 loose wing ribs |
Mike,
Attached is a picture of how the ribs of a Kitfox wing are arranged and secured. The smaller false ribs are only attached at two points and could bent sideways slightly between the two attached points with a little side pressure. They should not move at their attached points. It is not important that the false ribs be secured to the fabric itself. Hope this helps.
| Quote: | --
John King
Warrenton, VA |
Michael Laundy wrote: | Quote: | I bought a KF3 a few months back and I have discovered a couple of the ribs have movement in them when gently pressed through the fabric. Since I did not build the plane I don't know exactly how the inside of the wing is set out, but from the outside it seems there are 2 short ribs between each full chord rib. It is 2 of those short ones that don't appear to be attached to the upper skin,. I suspect someone has moved it in the hangar and pushed in the wrong place!
Many thanks
Mike
[url=http://us.rd.yahoo.com/mail/uk/taglines/default/nowyoucan/pc_mag/*http://us.rd.yahoo.com/evt=40565/*http://uk.docs.yahoo.com/nowyoucan.html][/url]
68.41 KB |
349 Time(s) |
Posted: Thu Jul 13, 2006 8:26 am Post subject: KF 3 loose wing ribs |
John,
Many thanks for the information and the photo, it was exactly what I needed to see.
Mike
John King <kingjohne(at)adelphia.net> wrote:
| Quote: | Mike,
| Quote: | | -- John King Warrenton, VA |
Many thanks
Mike
[url=http://us.rd.yahoo.com/mail/uk/taglines/default/nowyoucan/pc_mag/*http://us.rd.yahoo.com/evt=40565/*http://uk.docs.yahoo.com/nowyoucan.html][/url] |
[url=http://us.rd.yahoo.com/mail/uk/taglines/default/nowyoucan/spamguard/*http://us.rd.yahoo.com/evt=40565/*http://uk.docs.yahoo.com/nowyoucan.html]All New Yahoo! Mail[/url] – Tired of Vi(at)gr(at)! come-ons? Let our SpamGuard protect you.
Posted: Thu Jul 13, 2006 8:27 am Post subject: KF 3 loose wing ribs |
John,
Mike
| Quote: | Mike,
Many thanks
Mike
Now you can [url=http://us.rd.yahoo.com/mail/uk/taglines/default/nowyoucan/reading_pane/*http://us.rd.yahoo.com/evt=40565/*http://uk.docs.yahoo.com/nowyoucan.html]scan emails quickly with a reading pane[/url]. Get the new [url=http://us.rd.yahoo.com/mail/uk/taglines/default/nowyoucan/reading_pane/*http://us.rd.yahoo.com/evt=40565/*http://uk.docs.yahoo.com/nowyoucan.html]Yahoo! Mail[/url].
