bob88
Posted: Thu May 08, 2014 8:31 pm Post subject: Gap at the cabin door hinges |
I'm looking for a solution to the open space at the cabin door hinges. Using the McMaster bulb weather stripping on the cabin top door jamb (not on door per Vans). I thought of filling with a piece of foam and glassing over but then no access to the nuts/screws and some concern re moisture trapping and corrosion. Ideas?
sean(at)braunandco.com Guest
Posted: Fri May 09, 2014 12:35 am Post subject: Gap at the cabin door hinges |
I built covers out of the extra material cut out of the window area. They
fit flush and seal off the gap. These make a huge difference in noise and
air coming in or out compared to the stock seal. I riveted 10/32 nutplates
on the hinge so I wouldn't have to hold the nuts with an open end wrench.
The PlaneAround strut attachment has a little geometry change which holds
the joint away from the hinge covers. The stock attachment will push into
the cover unless you make an indent.
glastar(at)gmx.net Guest
Posted: Fri May 09, 2014 4:20 am Post subject: Gap at the cabin door hinges |
Sean,
do you have a picture please?
Thanks Werner
On 09.05.2014 10:23, Seano wrote:
davidsoutpost(at)comcast. Guest
Posted: Fri May 09, 2014 4:31 am Post subject: Gap at the cabin door hinges |
I made a temporary form where the seal bridged the recess out of scrap aluminum, aluminum foil tape, and clay. Sanded the recess first, installed the form, waxed the form, filled with a stiff epoxy/micro/flox mix, and fulled the form off when cured. Looks good and seals perfectly.
Sent: Friday, May 9, 2014 12:31:14 AM
Subject: Gap at the cabin door hinges
--> RV10-List message posted by: "bob88" <marty.crooks(at)comcast.net>
http://forums.matronics.com/viewtopic.php?p=423039#423039
Posted: Fri May 09, 2014 4:57 am Post subject: Gap at the cabin door hinges |
This is what I did. It provides a good seal. I had some rigid foam laying
around to shape and fill in the hinge void, then the simple McMaster self
adhesive seal goes on top.
Carl
701.51 KB |
5989 Time(s) |
rv10flyer
Posted: Fri May 09, 2014 4:57 am Post subject: Re: Gap at the cabin door hinges |
I hand fit four .032" plates, prosealed them in, painted with inside of doors. Hardware still accessible and water/air-tight.
_________________ Wayne G. |
Posted: Fri May 09, 2014 5:11 am Post subject: Gap at the cabin door hinges |
816.87 KB |
5989 Time(s) |
philperry9
Posted: Fri May 09, 2014 7:09 am Post subject: Gap at the cabin door hinges |
The aluminum plates is what I have been planning on doing too. Basically going to use an adhesive to put them in place and then paint to match the interior of the door. They should disappear and then I can still yank them off at a future date if I ever need to get to those areas.
On Fri, May 9, 2014 at 7:57 AM, rv10flyer <wayne.gillispie(at)gmail.com (wayne.gillispie(at)gmail.com)> wrote:
[quote]--> RV10-List message posted by: "rv10flyer" <wayne.gillispie(at)gmail.com (wayne.gillispie(at)gmail.com)>
Wayne G.
http://forums.matronics.com/viewtopic.php?p=423054#423054
" target="_blank">http://www.matronics.com/Navigator?RV10-List
MS -
e -
rv10flyer(at)live.com Guest
Posted: Fri May 09, 2014 7:55 am Post subject: Gap at the cabin door hinges |
I created plates, or was it Don?? anyhow, I have 2 screws I attach it to the hinges, easier to remove, not that I ever needed to. I did not do the glue for 1) fear it would not stick and fly off one day 2) probably ruin the cover in the process of removing if it held it in place so well, in either case I would need to get new covers if I ever needed to remove for any reason.
Sent: Friday, May 09, 2014 7:44 AM
Subject: Re: Re: Gap at the cabin door hinges
| Quote: | --> RV10-List message posted by: "rv10flyer" <wayne.gillispie(at)gmail.com (wayne.gillispie(at)gmail.com)>
Wayne G.
MS -
e -
bill.peyton
Joined: 19 Sep 2010 Posts: 198 Location: St. Louis, MO
Posted: Sat May 10, 2014 11:14 am Post subject: Re: Gap at the cabin door hinges |
I used a scrap piece of the window cutout FG to create a small piece to fit over the gap. I glued it in place with resin and micro. Did the body work on the outside with resin stranded body filler.
110.66 KB |
5941 Time(s) |
_________________ Bill
WA0SYV
Aviation Partners, LLC |
