Gap at the cabin door hinges
bob88
PostPosted: Thu May 08, 2014 8:31 pm    Post subject: Gap at the cabin door hinges Reply with quote
I'm looking for a solution to the open space at the cabin door hinges. Using the McMaster bulb weather stripping on the cabin top door jamb (not on door per Vans). I thought of filling with a piece of foam and glassing over but then no access to the nuts/screws and some concern re moisture trapping and corrosion. Ideas?
sean(at)braunandco.com
PostPosted: Fri May 09, 2014 12:35 am    Post subject: Gap at the cabin door hinges Reply with quote
I built covers out of the extra material cut out of the window area. They
fit flush and seal off the gap. These make a huge difference in noise and
air coming in or out compared to the stock seal. I riveted 10/32 nutplates
on the hinge so I wouldn't have to hold the nuts with an open end wrench.
The PlaneAround strut attachment has a little geometry change which holds
the joint away from the hinge covers. The stock attachment will push into
the cover unless you make an indent.
glastar(at)gmx.net
PostPosted: Fri May 09, 2014 4:20 am    Post subject: Gap at the cabin door hinges Reply with quote
Sean,
do you have a picture please?
Thanks Werner
davidsoutpost(at)comcast.
PostPosted: Fri May 09, 2014 4:31 am    Post subject: Gap at the cabin door hinges Reply with quote
I made a temporary form where the seal bridged the recess out of scrap aluminum, aluminum foil tape, and clay.  Sanded the recess first, installed the form, waxed the form, filled with a stiff epoxy/micro/flox mix, and fulled the form off when cured. Looks good and seals perfectly.
Sent: Friday, May 9, 2014 12:31:14 AM
Subject: Gap at the cabin door hinges
--> RV10-List message posted by: "bob88" <marty.crooks(at)comcast.net>
http://forums.matronics.com/viewtopic.php?p=423039#423039
carl.froehlich(at)verizon
PostPosted: Fri May 09, 2014 4:57 am    Post subject: Gap at the cabin door hinges Reply with quote
This is what I did. It provides a good seal. I had some rigid foam laying
around to shape and fill in the hinge void, then the simple McMaster self
adhesive seal goes on top.
Carl
 Filesize:  701.51 KB
 Viewed:  5909 Time(s)
rv10flyer
PostPosted: Fri May 09, 2014 4:57 am    Post subject: Re: Gap at the cabin door hinges Reply with quote
I hand fit four .032" plates, prosealed them in, painted with inside of doors. Hardware still accessible and water/air-tight.
Wayne G.
PostPosted: Fri May 09, 2014 5:11 am    Post subject: Gap at the cabin door hinges Reply with quote
 Filesize:  816.87 KB
philperry9
PostPosted: Fri May 09, 2014 7:09 am    Post subject: Gap at the cabin door hinges Reply with quote
The aluminum plates is what I have been planning on doing too.  Basically going to use an adhesive to put them in place and then paint to match the interior of the door.  They should disappear and then I can still yank them off at a future date if I ever need to get to those areas.
On Fri, May 9, 2014 at 7:57 AM, rv10flyer <wayne.gillispie(at)gmail.com (wayne.gillispie(at)gmail.com)> wrote:
[quote]--> RV10-List message posted by: "rv10flyer" <wayne.gillispie(at)gmail.com (wayne.gillispie(at)gmail.com)>
Wayne G.
http://forums.matronics.com/viewtopic.php?p=423054#423054
" target="_blank">http://www.matronics.com/Navigator?RV10-List
MS -
k">http://forums.matronics.com
e -
t="_blank">http://www.matronics.com/contribution
rv10flyer(at)live.com
PostPosted: Fri May 09, 2014 7:55 am    Post subject: Gap at the cabin door hinges Reply with quote
I created plates, or was it Don?? anyhow, I have 2 screws I attach it to the hinges, easier to remove, not that I ever needed to. I did not do the glue for 1) fear it would not stick and fly off one day 2) probably ruin the cover in the process of removing if it held it in place so well, in either case I would need to get new covers if I ever needed to remove for any reason.
Sent: Friday, May 09, 2014 7:44 AM
Subject: Re: Re: Gap at the cabin door hinges
Wayne G.
MS -
e -
bill.peyton
PostPosted: Sat May 10, 2014 11:14 am    Post subject: Re: Gap at the cabin door hinges Reply with quote
I used a scrap piece of the window cutout FG to create a small piece to fit over the gap. I glued it in place with resin and micro. Did the body work on the outside with resin stranded body filler.
 Filesize:  110.66 KB
 Viewed:  5861 Time(s)
WA0SYV
Aviation Partners, LLC
