kevino
Joined: 21 Sep 2010 Posts: 13 Location: United States
Posted: Tue Sep 21, 2010 11:38 am Post subject: Re: performance |
Just to add another endorsement of the TT auto trim, i paid the 625 and thought it was a bargain. Makes a huge difference shooting approaches. Also added the safety trim which gives you two trim speeds which smooths out any trim adjustments. I never see any out of trim indicator on the TT.
Tim Olson
Posted: Tue Sep 21, 2010 12:50 pm Post subject: performance |
Anyone comment on how much wiring for a retrofit there would be?
Looks like it has a big connector.
Tim Olson - RV-10 N104CD
On 9/21/2010 2:38 PM, kevino wrote:
http://forums.matronics.com/viewtopic.php?p=313251#313251
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Tue Sep 21, 2010 12:58 pm Post subject: performance |
They have a tech pubs and manuals on their website. I already looked at
that, I may have to buy one. They show both new and retrofit.
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
rene(at)felker.com Guest
Posted: Tue Sep 21, 2010 1:27 pm Post subject: performance |
I took a quick look yesterday and I am concerned that it would partially
defeat the safety trim I just put in? It says it must be wired directly to
the trim motors and has a warning about runaway trim?
Need to get the Safety Trim and TT guys together for a solution.....maybe,
or I just have it wrong.
Rene' Felker
N423CF
801-721-6080
Posted: Tue Sep 21, 2010 1:30 pm Post subject: performance |
I didn't do it myself, but I did research it. My understanding is that you cut the wires going to the servo and both sets go into the auto trim, then there is power and ground and some wires that run to the pitch servo. I don't think it was a very complicated retrofit, and I'm not sure if any new wires had to be run from the front to the back (controller should go by the AP Pitch Servo, IIRC).
This is just off the top of my head, but I seem to remember that there was a fairly detailed manual that outlines what had to be done.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
C: 352-427-0285
F: 815-377-3694
On Sep 21, 2010, at 4:46 PM, Tim Olson wrote:
Tim Olson
Posted: Tue Sep 21, 2010 1:55 pm Post subject: performance |
See that's my worry too.....if it gets in the way of safety
trim, I won't install it. If it gets installed before
the safety trim, so it can still only run the trim 3 seconds
at a crack, fine, but I won't put it direct to the motors.
Runaway trim would be just too fast of a thing that could
break up the plane for me to trust that. I'll have to
get the wiring diagrams and see.
Rene' Felker
N423CF
801-721-6080
sean(at)stephensville.com Guest
Posted: Tue Sep 21, 2010 2:42 pm Post subject: performance |
Just a note for those going or considering the Vertical Power that it
includes a feature like Bob's great product.
*Runaway trim protection
* There are two runaway trim protection systems, and one works
differently on the ground than in the air. If the trim runs for more
than three seconds in the air, the circuit is disabled. However, you can
run it indefinitely when on the ground.
Also, they have a PDF that shows the inclusion of the Trutrak auto trim
here: http://www.verticalpower.com/docs/VP_Flap-Trim_Wiring.pdf
I'm not affiliated, I'm just a fan...
-Sean #40303 (fuse side skins... still...)
> directly to
> solution.....maybe,
> Rene' Felker
> N423CF
> 801-721-6080
rnewman(at)tcwtech.com Guest
Posted: Tue Sep 21, 2010 3:27 pm Post subject: performance |
Regarding the use of Safety-Trim with TruTrak's autotrim feature: The
Safety-Trim controller feeds into the TT autotrim module where the switch
inputs would normally go. This allows all the benefits of speed control
and run-away trim prevention provided by the Safety-Trimcontroller to
protect the manual control portion of the trim system. When the autopilot
needs to trim the plane it effectively takes trim authority away from the
pilot for just the time required to get the plane trimmed, then returns the
authority back to the Safety-Trim controller. The guys from TT will have
to chime in on their autotrim reliability, I can't provide any details on
that. However, we've had zero issues reported with the combined system.
Regarding the run-away trim prevention feature of Safety-Trim vs that of
Vertical Power: Although similiar they are not the same. The
Safety-Trim system can be reset by clearing the fault in the control stick
switch (ie the coolie hat or rocker switch) or if you really need more
than 3 seconds worth of trim, just release the stick switch and press again
to get up to 3 more seconds worth of trim. This mode of operation is
protected by our recently issued patent. The VP system will disable the
trim switch during this case and you must use the soft keys on VP control
system screen to clear the "fault". This how I understand their system
to work.
Bob Newman
TCW Technologies, LLC
www.tcwtech.com
builder # 40176
Posted: Tue Sep 21, 2010 4:01 pm Post subject: performance |
Thanks Bob, I should have stated that it was different entirely, but
was just referring to the 3-second cutoff. Yours obviously has more
features.
I am curious as to if there would be anything preventing a Safety-Trim
from being inline between a VP-200 and TruTrak Auto Trim? The reason I
ask is that I'd like the speed change, which I don't believe the VP-200
has yet. Would the 3-second VP-200 cutoff interfere with the
Safety-Trim at all?
VP-200 -> Safety-Trim -> Auto Trim. Seems like a lot of "things" in
front of the pitch trim servo.
-Sean
| Quote: | Regarding the run-away trim prevention feature of Safety-Trim vs that
of Vertical Power: Although similiar they are not the same. The
stick switch (ie the coolie hat or rocker switch) or if you really
need more than 3 seconds worth of trim, just release the stick switch
and press again to get up to 3 more seconds worth of trim. This mode
of operation is protected by our recently issued patent. The VP
system will disable the trim switch during this case and you must use
the soft keys on VP control system screen to clear the "fault".
This how I understand their system to work.
Bob Newman
www.tcwtech.com
builder # 40176
Posted: Tue Sep 21, 2010 4:10 pm Post subject: performance |
My mistake. The VP-200 does adjust trim speed. Sorry.
On 9/21/10 6:19 PM, bob-tcw wrote:
The Safety-Trim controller feeds into the TT autotrim module where the
switch inputs would normally go. This allows all the benefits of
speed control and run-away trim prevention provided by the
Safety-Trimcontroller to protect the manual control portion of the
trim system. When the autopilot needs to trim the plane it
effectively takes trim authority away from the pilot for just the time
required to get the plane trimmed, then returns the authority back to
the Safety-Trim controller. The guys from TT will have to chime in
on their autotrim reliability, I can't provide any details on that.
Bob Newman
www.tcwtech.com
builder # 40176
dmaib(at)mac.com Guest
Posted: Tue Sep 21, 2010 4:24 pm Post subject: performance |
VP does have the speed change at this time. I have had it working on
my airplane for several months. Works great.
David Maib
40559
Flying
but was just referring to the 3-second cutoff. Yours obviously has
more features.
Trim from being inline between a VP-200 and TruTrak Auto Trim? The
reason I ask is that I'd like the speed change, which I don't believe
the VP-200 has yet. Would the 3-second VP-200 cutoff interfere with
the Safety-Trim at all?
-Sean
that of Vertical Power: Although similiar they are not the
same. The Safety-Trim system can be reset by clearing the fault
in the control stick switch (ie the coolie hat or rocker switch)
or if you really need more than 3 seconds worth of trim, just
release the stick switch and press again to get up to 3 more
seconds worth of trim. This mode of operation is protected by our
recently issued patent. The VP system will disable the trim
control system screen to clear the "fault". This how I
Bob Newman
www.tcwtech.com
builder # 40176
Posted: Tue Sep 21, 2010 4:41 pm Post subject: performance |
Ya, I know. Please ignore everything I post. It's better for
everyone that way.
-Sean
On 9/21/10 7:13 PM, David Maib wrote:
David Maib
40559
Flying
features.
I ask is that I'd like the speed change, which I don't believe the
VP-200 has yet. Would the 3-second VP-200 cutoff interfere with the
Safety-Trim at all?
-Sean
> Bob Newman
> www.tcwtech.com
> builder # 40176
aerosport1
Posted: Tue Sep 21, 2010 5:44 pm Post subject: performance |
Tim and all interested. The auto trim was very easy to install. It does work
with the TCW safety trim and trims in 3 sec intervals. So far
it has be great and worth every penny as I stated before. It took about 3
hours to install. I have attached some pictures that hopefully
will help. Also all wiring was done right by the Elevator trim servo. I did
wire directly into the trim servo wires going back to the trim servo
in the aft end of tailcone.
Geoff
RV-10 N829GW
115.68 KB |
14083 Time(s) |
111.1 KB |
14083 Time(s) |
97.27 KB |
14083 Time(s) |
_________________ Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033 |
rv10builder(at)verizon.ne Guest
Posted: Tue Sep 21, 2010 6:03 pm Post subject: performance |
Actually, keep it coming, you're not the only one who thinks this way.
Pascal
Sent: Tuesday, September 21, 2010 5:38 PM
Subject: Re: Re: performance
everyone that way.
-Sean
> David Maib
> 40559
> Flying
> features.
> Safety-Trim at all?
> -Sean
>> Bob Newman
>> www.tcwtech.com
>> builder # 40176
dave.saylor.aircrafters(a Guest
Posted: Tue Sep 21, 2010 6:16 pm Post subject: performance |
Keep in mind that you may end up tweaking the adjustment knob a few times to get the autotrim dialed in. Put it someplace that's not too inconvenient to access. Once it's dialed in, though, you'll never touch it again.
Dave Saylor
AirCrafters
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
On Tue, Sep 21, 2010 at 6:40 PM, g.combs <g.combs(at)aerosportmodeling.com (g.combs(at)aerosportmodeling.com)> wrote:
[quote] Tim and all interested. The auto trim was very easy to install. It does work with the TCW safety trim and trims in 3 sec intervals. So far
it has be great and worth every penny as I stated before. It took about 3 hours to install. I have attached some pictures that hopefully
will help. Also all wiring was done right by the Elevator trim servo. I did wire directly into the trim servo wires going back to the trim servo
Geoff
RV-10 N829GW
jfrjr(at)roadrunner.com Guest
Posted: Wed Sep 22, 2010 2:08 am Post subject: performance |
When you purchase the auto trim ($350) from any of the vendors does it come with any of the wiring or connectors for the retrofit setup? Jay Rowe
---- Dave Saylor <dave.saylor.aircrafters(at)gmail.com> wrote:
[quote] Keep in mind that you may end up tweaking the adjustment knob a few times to
Dave Saylor
AirCrafters
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
On Tue, Sep 21, 2010 at 6:40 PM, g.combs <g.combs(at)aerosportmodeling.com>wrote:
> Geoff
> RV-10 N829GW
aerosport1
Posted: Wed Sep 22, 2010 5:14 am Post subject: performance |
No I had to make my own wire harness. Pretty easy
Geoff
Sent from my iPhone Geoff
setup? Jay Rowe
> times to
> inconvenient to
> Dave Saylor
> AirCrafters
> 140 Aviation Way
> 831-722-9141 Shop
> 831-750-0284 Cell
>> does
>> about 3
>> servo. I did
>> Geoff
>> RV-10 N829GW
RV-10 QB N829GW
Flying 500 hrs
40033 |
marcausman
Posted: Thu Sep 30, 2010 12:21 pm Post subject: Re: performance |
We've had zero issues with anyone who has installed the Autotrim module and the VP system. They work well together and a link is posted earlier showing how they are wired together.
As with the TCW system or if you use mechanical relays, the TT autotrim system takes control away from our system to make its own adjustments. If the TT autotrim system runs away there is no way to stop it other than to pull power to the TT autotrim module. If you want a failsafe switch then put one in series bw the trim motor and whatever controller is closest in the wiring. That switch can stop the motor from running but cannot allow you to run the trim motor back.
The VP system DOES have runaway trim protection, variable speed trim, backup trim controls, trim position indicator, and trim fault checking on startup. And with rock-simple wiring.
_________________ Marc Ausman
http://www.verticalpower.com "Move up to a modern electrical system"
RV-7 IO-390 Flying |
