Weight and Balance on 601XL / Corvair
Goto page Previous  1, 2
Fly with Gus
PostPosted: Mon Jun 22, 2009 10:57 am    Post subject: Re: Weight and Balance on 601XL / Corvair Reply with quote
My experience shows the UL260i to be even a little lighter than the Rotax 912S. My page http://flywithgus.net/html/performance.html shows the same exact airplane with both the corvair and the UL260i. The weight for the corvair was with no paint and only seat cushions. The UL numbers include paint and full interior. With the UL was 695 lbs. without paint and only seat cushions. So same airplane with both engines, and this also probably a bit heavier than a standard 601 as it has 650 canopy and tail mods.
Gus
www.flywithgus.net
Juan Vega Jr
PostPosted: Mon Jun 22, 2009 12:13 pm    Post subject: Weight and Balance on 601XL / Corvair Reply with quote
phil,
they are not, Jabiru is 178 lbs wet. my craft is 760 lbs, with 3300 engine.
pmaxpmax(at)HOTMAIL.COM
PostPosted: Mon Jun 22, 2009 12:24 pm    Post subject: Weight and Balance on 601XL / Corvair Reply with quote
Juan,
That puts us at 17 pounds as the difference, not the 40 or 50 someone reported. Of course it really depends on how the planes are equipped.
Phil Maxson
601XL/Corvair
cookwithgas
PostPosted: Mon Jun 22, 2009 12:39 pm    Post subject: Re: Weight and Balance on 601XL / Corvair Reply with quote
David:
820 is a good weight. Mine is around 850 and flies great with the Corvair engine, Y-stick, BRS and the battery on the firewall.
It's great to hear that another Corvair/601XL will be in the air soon.
Scott Laughlin
601XL/Corvair
Davcoberly(at)wmconnect.c
PostPosted: Mon Jun 22, 2009 1:34 pm    Post subject: Weight and Balance on 601XL / Corvair Reply with quote
Thanks Scott I'm mostly just down to getting the details worked out for the DAR inspection. I sure look forward to meeting you at some Fly-In someday soon!
David Coberly 601XL / Corvair [quote][b]
tigerrick(at)mindspring.c
PostPosted: Mon Jun 22, 2009 4:04 pm    Post subject: Weight and Balance on 601XL / Corvair Reply with quote
Hey, Kids!
We JUST got Rich Vetterli's Zenvair 601XL off of the scales, and it came in at:
Left Main: 281.6
Right Main: 281.4
Nose Gear: 230.0
For a grand total of 793.0 pounds. His airplane is lightly equipped with minimal instrumentation for flight test, has a chopped down center stick, a single set of brakes, but has been painted and features soundproofing throughout. Warp Drive prop, no wheelpants (yet), just wingtip strobes without exterior nav lighting.
Three photos attached.
Phase 1, here he comes...!
Rick Lindstrom
First Light Aviation Group
Livermore, CA
www.flaglvk.com
 Filesize:  148.61 KB
 Viewed:  11358 Time(s)
 Filesize:  137.1 KB
 Filesize:  145.41 KB
PostPosted: Mon Jun 22, 2009 4:56 pm    Post subject: Weight and Balance on 601XL / Corvair Reply with quote
What a beautiful 601XL way to go!! My weights of the three wheels were almost equal. With the nose so light must be a lot more weight aft than mine.
Gig Giacona
PostPosted: Mon Jun 22, 2009 5:19 pm    Post subject: Re: Weight and Balance on 601XL / Corvair Reply with quote
tigerrick(at)mindspring.c wrote:
For a grand total of 793.0 pounds. --
There are clearly not enough gadgets in that aircraft. Pretty paint though.
Smile
W.R. "Gig" Giacona
601XL Under Construction
leinad
That's an inspiration! I've got to get off my duff!
Dan 601xl/corvair Dempsey
Hey, Kids!
Left Main: 281.6
Right Main: 281.4
Nose Gear: 230.0
Rick Lindstrom
Livermore, CA
www.flaglvk.com
bootless(at)earthlink.net
PostPosted: Mon Jun 22, 2009 5:25 pm    Post subject: Weight and Balance on 601XL / Corvair Reply with quote
Way to go, Rich!
leinad wrote: [quote]
--> Zenith-List message posted by: "leinad" <leinad(at)hughes.net> (leinad(at)hughes.net)
Hey, Kids!
Left Main: 281.6
Right Main: 281.4
Nose Gear: 230.0
Rick Lindstrom
Livermore, CA
www.flaglvk.com
[url=http://forums.matronics.com/viewtopic.php?p 49607#249607]http://forums.matronics.com/viewtopic.php?p 49607#249607[/url]
lwinger
PostPosted: Mon Jun 22, 2009 5:55 pm    Post subject: Weight and Balance on 601XL / Corvair Reply with quote
Rich, you're the man!  Great job.  You've come a long way.
Larry Winger
On Mon, Jun 22, 2009 at 5:02 PM, Rick Lindstrom <tigerrick(at)mindspring.com (tigerrick(at)mindspring.com)> wrote:
[quote]Hey, Kids!
Left Main: 281.6
Right Main: 281.4
Nose Gear: 230.0
Rick Lindstrom
Livermore, CA
www.flaglvk.com
Larry Winger
Tustin, CA
Plans building 601XL/650 with Corvair
Installing fuel system
www.mykitlog.com/lwinger
Page 2 of 2
