Michel
Posted: Thu Aug 07, 2008 11:04 am Post subject: Landing and engine pictures |
| Quote: | From: Lynn Matteson [lynnmatt(at)jps.net]
Spot-on, you say old chap? Well, bully then, the next pint's on me!
By Jove! You do speak English, don't you? Good show, old fruit!
.. okay, I'll shut up, leave the room and go and play with my new pacemaker!
Michel
_________________ Kitfox 3 - Jabiru 2200 |
Michel
Posted: Thu Aug 07, 2008 11:36 am Post subject: Landing and engine pictures |
| Quote: | From: Jim_and_Lucy Chuk [thesupe(at)hotmail.com]
Sorry if I offended anyone, I didn't mean to.
Ouch, that hurts, Jim! Aren't you ashamed to hit an old man with a pacemaker?
Just kidding; I agree with you. The Jabiru with its 85 HP gives more cruise power but not climb power than the 582. I don't think it has anything to do with the propeller but simply the torque of an engine that turns twice as slow as a Rotax.
I was very well aware of that when I bought my Jabiru. Although I know virtually nothing about aircraft engines, my thinking was this: Yes, the Rotax (912 and 582) are two mighty engines with water cooling and gear box, thus very stable and therefore a favourite in experimental aviation, the Jabiru was atractive by its simplicity and when you don't know much about engines, less is more. I also thought that if Continental and Lycoming were also direct drive air-cooled engines, ... the technology was still good for aviation.
Lynn wrote:
| Quote: | My serial number is 2062, Michel, just 5 engines before they went to
wet lifters (hydraulics)....what number is yours? Did you already
have the dowels in your engine?
My serial number is 1665, Lynn. An older engine but still from what is called the third generation Jabiru although I don't have the dowels. Thanks for your advice and I will look under the flywheel at each pre-flight. It's easy for my, my opening under the cowling is very large and it gives a good view of the rear bottom end of the engine. Looking there is already in my pre-flight because it allows me to check the recovery bottle without removing the cowling.
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200 ... grounded for now.
Fox5flyer Guest
Posted: Thu Aug 07, 2008 2:11 pm Post subject: Landing and engine pictures |
http://www.ntsb.gov/ntsb/brief.asp?ev_id=20080806X01164&key=1
We don't often hear about it happening, but even a 912 can come apart. Here's a recent NTSB report of a Kitfox IV emergency landing that, fortunately, ended up with both the pilot and airplane relatively intact.
Anybody know this guy?
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 388+ TT
- Joseph Joubert
gary.algate(at)sandvik.co Guest
Posted: Thu Aug 07, 2008 2:55 pm Post subject: Landing and engine pictures |
Lynn
If you would like to send the broken gear to my office in Barrie, Ontario I can have our metallurgist take a look at it. We can do carbon analysis and have metallurgical inspection as my people there are qualified in fatigue analysis for our drilling products.
Might show something!
the only other thing that the jab people here could come up with was some sort of contaminant in the oil etc that jammed between the teeth. After reading your posts I find that highly unlikely!
How were the rest of your pistons and valves?
Gary
Gary Algate
SMC, Exploration
Office Phone: +61 8 8276 7655
This e-mail is confidential and it is intended only for the addressees. Any review, dissemination, distribution, or copying of this message by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error, kindly notify us immediately by telephone or e-mail and delete the message from your system. The sender does not accept liability for any errors or omissions in the contents of this message which may arise as a result of the e-mail transmission.
Lynn Matteson <lynnmatt(at)jps.net>
Sent by: owner-kitfox-list-server(at)matronics.com
08/08/2008 01:01 AM
Please respond to
kitfox-list(at)matronics.com To
kitfox-list(at)matronics.com cc
Subject
Re: RE: Landing and engine pictures
--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
Thanks for checking into it, Gary.
I did the service bulletin at the time it was issued, and I changed
all the bolts, the originals of which were already at the then-
current torque specs, so no "loose flywheel" at that time. No loose
flywheel at this time either, and no fretting was seen when I took it
off this time. My engine (#2062) had the three dowels already fitted.
Unless they'd like to see my broken gear, and give me some new parts
(yeah, right!), I guess I'l just buy new parts and get back to flying.
Lynn
On Aug 6, 2008, at 9:19 PM, gary.algate(at)sandvik.com wrote:
> Lynn
> The head engine builder (Don) at Jabiru just called me and we ran
> thru your timing gear failure.
> Jabiru Australia have one (1) reported Crankshaft Timing gear
> failure and this happened three years ago at Innisfil (S.Australia)
> on a Jab2200 powered lightwing.
> The gear was inspected at Jabiru and heat treat and mfg were all
> within spec. There were no signs of contamination between the gears
> and the final consensus was that the operator may have been
> experiencing pre-ignition or was running with a loose flywheel
> which could have over-stressed the gear.
> The gear only runs the camshaft at a 2:1 ratio and is very lightly
> loaded so with over 1500 units in operation and only one recorded
> failure that could not be attributed to component overstress no
> service directive was issued.
> They have released directives to ensure all fly-wheel bolts are
> correctly torqued.
> Sorry I couldn't get you a more definitive answer but it appears
> that this might have been a 1 off (or 2 - off)
> best regards
> Gary
> Gary Algate
> Kitfox Classic 4 2200A
> arise as a result of the e-mail transmission. _-
> www.matronics.com/Navigator?Kitfox-List _-
> www.matronics.com/contribution _-
Posted: Thu Aug 07, 2008 3:15 pm Post subject: Landing and engine pictures |
Jim
You are dead right about climb performance when you compare a Jab to a 582 or 912.
Both of the Rotax engines are geared and therefore run large diameter props (72") and with props diameter normally dictates climb rate.
I went from a 582 Blue head to a very early model Jabiru and the climb rate that I saw was very similar on both engines (500 - 650ft/min at gross) however the Jab cruised faster, quieter, vibrated less and used far less fuel. 13 Ltr/Hr at cruise vs 19 Ltr/hr on the 582.
When I fitted the new 2200 I noticed it was significantly more powerful and I now see consistent climb rates of over 1000ft/min which is far better than I saw with the 582
As you point out the Rotax 912 and 912S with the large diameter props have excellent climb performance - (Normally better than the Jab2200).
If I were on floats I would certainly go for the 912 over the Jab2200.
For simplicity the Jab is air cooled, direct drive, low revving, fuel efficient, lightweight, very pretty and sounds like a real airplane engine.
The 912 is also an excellent choice although slightly more complicated however it is still the engine of choice in N.America and most of Europe.
There are over 2,000 jab engines in service and the company is growing exponentially - with a 2,000 hr TBO
If you go to the Rotax service bulletin web site I think you will find that Rotax also have a significant number of updates posted but being engines in experimental aircrafts I think this is to be expected - both companies are also continually improving and upgrading their products based on service history so once again changes are inevitable.
I think both engines are great and please take this with a grain of salt as it is only my opinion!
Gary
Gary Algate
Classic 4 Jab2200
Jim_and_Lucy Chuk <thesupe(at)hotmail.com>
08/08/2008 01:17 AM
Please respond to
<kitfox-list(at)matronics.com> cc
Subject
RE: RE: Landing and engine pictures
Just thought I would open my mouth on this (and probably regret it later LOL) I have a Jabiru in my Avid Mk IV
and while it seems to run fine, it does not have the performance I expected from it. It is faster than the 582 it
replaced, but does not climb as well. Maybe I don't have it set up right prop wise, but at about $500 each for a
Tennasee prop, how much experimenting can you do. On the Kitfox 4 I'm building, I picked up a used 912 Rotax
engine and have high hopes for it. At least with it I can put on a large ground adjustable prop and set it where I
want it. I think the 60" to 64" wood prop you have to use on the Jabiru is a big disadvantage. The Jabiru probably
weighs 20 lbs less installed than the 912 and that might be a factor on the Kitfox 2 with the lower gross weight.
I've also read a lot of the posts on the Rotax matronics list as well as most of them on the Jabiru sites. There are a
lot more Rotaxes out there than the Jabirus, but I think there are more posts of major problems on the Jab sites than
the Rotax ones. Sorry if I offended anyone, I didn't mean to. Just putting into words what I've come to belive about
these engines. Granted, I have yet to fly a 912 Rotax. Jim Chuk Kitfox 4 building, Avid MK IV flying MN
Date: Thu, 7 Aug 2008 07:56:11 -0700
Subject: Re: RE: Landing and engine pictures
I, for one, appreciate the discussion. Re-engining may be in the offing for me and the Jab 2200 was/is on my short list of possibilities. Please continue.
Marco Menezes N99KX
Model 2 582-90 C-Box
Date: Thursday, August 7, 2008, 10:14 AM
I haven't said anything regarding my engine failure on either of the
Jabiru lists, Matronics or Yahoo...yet. I will when I have something
to say, (wink, wink). Still waiting to hear back from Jabiru...they
have been informed of the incident.
Michel, I was right behind you on the flywheel bolt issue...my engine
had the dowels already in place, the existing bolts were tight, and
the engine lasted a good 300 hours (I'm guessing, since I'm not where
my records are) since I complied with that Service Bulletin. Boy,
that was a busy time on the ol' Jabiru site, eh?
My oil was seeping from right below the rear main oil seal. If you
recall, the timing gear provides the surface upon which the oil seal
rides. It's a rather strange design, unlike any I've seen in all the
engines I've dealt with over the years, but then we're in the
aviation world now, where lightness, compactness, and engineering
done to the Nth degree is commonplace. You have to look behind the
flywheel, Michel, from below, to see the area.
I could kick my ass, in hindsight, for not getting right after that
leak after I first saw it. Like I said before, a seeping seal is not
the reason one normally pulls the engine and goes after it. After
all, it's only "seeping", not pouring out, threatening a fire,
etc.
But looking back on it, that's what I should have done. Actually, the
repair could have been done with the engine still in the
plane...barely, in my case. The rear cover is all that must be
pulled, and this requires taking the flywheel off. After that is off,
the timing gear cover can be removed, and the timing gears are then
exposed. Even taking the flywheel off and pulling the seal might have
revealed the crack in the timing gear, which in my case could
probably have been seen at that point. From the looks of the broken
pieces, this has been a faulty gear for some time.
Guy, if this is getting too far away from "Kitfox" in nature, holler.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
Status: "Condition grounded, but determined to try." (Pink
Floyd..."Learning to Fly")
On Aug 7, 2008, at 7:15 AM, Michel Verheughe wrote:
> Gary and Lynn; one question: why am I on the Jabiru list we I have
> you guys, here on the Kitfox one? ... )
> Thanks a lot for both answers. I will check for oil stain as a pre-
> flight routine, Lynn, that's a good idea. I agree with you, Gary,
> the Jabiru is a fine engine but - like any engine - it can be
> subject to failure. If you remember my writing on the Jabiru list,
> I have always been the advocate to tolerance and stress that when
> we take an engine designed to be installed in a Jabiru aircraft,
> but install it in something else, we are entering the world of
> experimental aviation with all of its consequences. We are,
> actually, test pilots.
> I am also please to own one of the last solid lifters model. The
> question to know if a loose flywheel could be the cause of Lynn's
> failure is interesting. As you remember, I was one of the first to
> comply to the bulletin requesting a retorquing of them, which I did
> and illustrated here:
> http://home.online.no/~michel/Flywheel
> Now, Lynn, where exactly did you see your oil seeping from? I
> understand that the timing gear is behind (or rather, in front of,
> if you look forward) of the flywheel. But I am not sure where the
> oil leaks from.
> Cheers,
> Michel Verheughe
> Norway
> Kitfox 3 - Jabiru 2200 ... grounded.
> <pre><b><font size color="#000000"
face="courier new,courier">
> List">http://www.matronics.com/Navigator?Kitfox-List</a>
> forums.matronics.com</a>
> www.matronics.com/contribution</a>
> </b></font></pre>
tfox-List
Got Game? Win Prizes in the Windows Live Hotmail Mobile Summer Games Trivia Contest Find out how.
n61kf
Joined: 27 Aug 2006 Posts: 23 Location: Waynesville Ohio
Posted: Fri Aug 08, 2008 3:54 am Post subject: Re: Landing and engine pictures |
Lynn at Oshkosh worrying about the condition of his engine!
287.79 KB |
714 Time(s) |
_________________ Keith Schneider
Red Stewart Airfield
Waynesville Ohio
KF IV 912ul |
Lynn Matteson
Posted: Fri Aug 08, 2008 4:24 am Post subject: Landing and engine pictures |
From the sounds of things, my gear breakage is another of those
"we've never heard of that happing before" things, and nobody else
will have to worry. I certainly hope so.
On the recovery bottle thing...mine is fiberglas, and I built up the
bottom of it with more 'glas so I could drill and tap it with a
1/4"NPT tap. I installed a petcock so I could drain the contents of
the bottle and didn't have to remove the cowl to do it...all I had to
do was reach up through the lower cowl air exit and turn the petcock
a zillion turns to drain the oil. Now I'm thinking of using a quick-
drain fitting and a length of hose so the fitting is right at the
bottom of the lower cowl, and can be drained more readily.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
On Aug 7, 2008, at 3:34 PM, Michel Verheughe wrote:
| Quote: | Thanks for your advice and I will look under the flywheel at each
Michel Verheughe
Norway
</b></font></pre>
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
shinco(at)bright.net Guest
Posted: Fri Aug 08, 2008 5:43 am Post subject: Landing and engine pictures |
n61kf wrote:
ones...GOOD PICTURE STEVE SHINABERY N554KF KF2
Lynn Matteson
Posted: Fri Aug 08, 2008 6:24 am Post subject: Landing and engine pictures |
I'd like to do that, Gary. But first I want to wait until I get some
word from the Jabiru dealer to see if they want to see the pieces. If
not, I'll get in touch with you and send them off.
I think the only contaminant that got between the teeth was another
one of the teeth. : )
Even the intake valve that was hit by the piston is still without
runout when spun in my lathe, but a local aircraft engine rebuilder
magnafluxed it and said it looked like it had cracks, but that it
might have been where the head was spun-welded onto the stem, and
that he would not use it. And to that I gave a big amen, 'cause I
sure as hell WASN'T gonna put that back into the engine, even if I
got a "good to go report" from the magnaflux check. See picture:
I certainly didn't need the 'flux job to tell me not to use this
valve, but I also couldn't determine what the "scratchy-looking"
marks were. My best guess is that very hard metal was flexed, and
where the flex occurred, the edges flaked off, leaving a slight
crater which shows up as a scratch.
The guides are worn to their allowable tolerances, but the valve
stems are right on specs. The valve "wobble test" told me more than
the micrometer did, and I plan on getting the heads done...new valves
and guides. The local aircraft engine guy said he thought they'd make
it to the 1000 hr suggested head overhaul time, but certainly not
with the one valve looking like it does. His estimate was based on
the appearance of the guides, valves, and the wobble test, and his
experience in the field.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
On Aug 7, 2008, at 6:54 PM, gary.algate(at)sandvik.com wrote:
Lynn
Gary
Gary Algate
SMC, Exploration
106.05 KB |
680 Time(s) |
N369LM |
Lynn Matteson
Posted: Fri Aug 08, 2008 6:26 am Post subject: Landing and engine pictures |
Hmmmmm......ya see, Michel, the word "fruit" has sort of a different
meaning over on this side of the pond....... : )
Have ya looked into hopping up that new toy yet?
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
On Aug 7, 2008, at 3:03 PM, Michel Verheughe wrote:
| Quote: | > From: Lynn Matteson [lynnmatt(at)jps.net]
... okay, I'll shut up, leave the room and go and play with my new
pacemaker!
Michel
</b></font></pre>
N369LM |
Michel
Posted: Fri Aug 08, 2008 6:36 am Post subject: Landing and engine pictures |
| Quote: | From: n61kf [bkls1(at)earthlink.net]
Wow! Lynn, you're the coolest pilot I know! ...
Michel
Lynn Matteson
Posted: Fri Aug 08, 2008 6:37 am Post subject: Landing and engine pictures |
Nahhh....if I'da been worried, I'd have had a beer in my hand.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
On Aug 8, 2008, at 7:54 AM, n61kf wrote:
Keith
N369LM |
Lynn Matteson
Posted: Fri Aug 08, 2008 6:58 am Post subject: Landing and engine pictures |
I was walking by the "Air Chair" tent at Oshkosh, and couldn't resist
the orange chair that almost matches my plane, so I bought it. The
wing was tied down on the other side, so I was in no danger of
dropping on my pratt (there's more of that English phrasing again).
After I got back, I tried the chair on the plane without it being
tied down, and it still didn't drop me...try that with your bungee-
cord landing gears. (The former comment was a shameless plug for the
Grove gear, or any other with a wider stance...the larger the pilot,
the wider the stance must be)
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
On Aug 8, 2008, at 10:36 AM, Michel Verheughe wrote:
| Quote: | > From: n61kf [bkls1(at)earthlink.net]
Michel
</b></font></pre>
N369LM |
aaaron(at)tvp.com.au Guest
Posted: Fri Aug 08, 2008 12:38 pm Post subject: Landing and engine pictures |
Fox5flyer Guest
Posted: Sun Aug 10, 2008 6:04 am Post subject: Landing and engine pictures |
That valve appears to be ready to let go at any time, Lynn. Good catch!
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 391+ TT
- Joseph Joubert
Lynn Matteson
Posted: Sun Aug 10, 2008 8:16 am Post subject: Landing and engine pictures |
Stevie Wonder could'a caught that one, Deke!
A little update on the repair process....the word back from Jabiru
was not encouraging, and I'll leave it at that. (I want to first see
if it's ok to pass along what was said)
At this point, I've got the engine completely disassembled. I had
done a run-out check on the gear end of the crank, and found .0015"-.
002" run-out. This could have caused the gear to fail, or could have
been caused by the gear teeth being wedged between the crank, the
remains of the gear, and the gear housing. Either way, run-out is run-
out, and the Jabiru engine manual doesn't give the accepted amount of
run-out. I'll have to consult with them on this measurement. Most
other measurements are within specs, with the exception of the valves/
valve guides. I'll have a valve job done, or if I don't get a "warm
fuzzy" feeling from what I perceive,(that is, do they do it, or send
it out to their local automotive guy) I'll get the parts and do it
myself or have it done by the local aircraft engine rebuilder, if he
would even take it on. This guy is a good friend of my flight
instructor, so we'll see what gives when that time rolls around.
There is always the possibility that I can get a factory rebuild, if
it turns out that this crank is out of specs due to the run-out
issue. The crank in all other aspects is perfect....no wear, bearings
and crank bearing surfaces are primo, and it looks like it would
easily go the rest of the 1500 hrs to the 2000 hr overhaul time.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
On Aug 10, 2008, at 10:03 AM, fox5flyer wrote:
<fox5flyer(at)idealwifi.net>
catch!
Deke Morisse
Mikado Michigan
progress."
- Joseph Joubert
N369LM |
Fox5flyer Guest
Posted: Sun Aug 10, 2008 8:48 am Post subject: Landing and engine pictures |
Keep us updated, Lynn.
Stevie
Lynn Matteson
Posted: Sun Aug 10, 2008 10:16 am Post subject: Landing and engine pictures |
Geez, the signature "Stevie" had me scratching my head, Deke.....then
it hit me.....it must be time for my nap!
Must be I've done WAY too many metric-to-inch conversions today, if
I'm missing my own jokes.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
Stevie
N369LM |
