Larry Hursh
Joined: 16 Feb 2008 Posts: 125 Location: Edwardsburg, MI (near Elkhart, IN)
Posted: Fri Mar 21, 2008 4:29 pm Post subject: It's official |
Yes Steve, that was a bit of "tongue in cheek" humor on my part.....I DO have a warped one I'm told...LOL. I was chuckling all the time I was writing it and HOPED everyone got the humor.....I certainly wouldn't want anyone to try doing and taking off with it in the lockers.....Just 'cause someone said so", don't make it true! Common sense has to prevail whenever you read anything on here.....
Larry
steve <notsew_evets(at)frontiernet.net> wrote:
[quote] You ARE kidding, yes.???
A four ton jack ? I dont think so, Larry...
Maybe a one half ton but shirley not a four ton...
SW
_________________ Larry Hursh (N650LM Reserved)
"One rivet at a time......one day at a time.."
CH650 (Converted from CH601XL)
1/2 done with fuselage
will be Corvair Powered |
notsew_evets(at)frontiern Guest
Posted: Fri Mar 21, 2008 7:09 pm Post subject: It's official |
Well Larry, I was wondering....
I really knew you dont need a four ton jack to lift a Zenith.
Then again I dont know jack.
I assume I ll be able to carry a one half ton floor type jack in my locker.
After considering the situamation, I figure that the jack will be in the right locker and the handles in the left. That is when I fly solo. With a passenger I ll just put the whole jack and handles in the rear shelf.
Any other ideas will be appreiated.
Larry Hursh
Posted: Sat Mar 22, 2008 12:09 pm Post subject: It's official |
Sounds like some really good advise there KA. I'll keep that in mind as I plan out our route. If I'm good enough, I really won't need the chains cause I plan on going straight over the Rockies and not have to go through any passes to get to California. I MIGHT need a few bottles of oxygen......not only for us to use, but also the engine! LOL.....Sure glad I will have those wing lockers, huh? I might strap on a 75 pound propane bottle under the belly of the plane so I can run a small house furnace inside. I could use the furnace for carb heat and to keep my windshield clear of any frost that might form. I'd hate to get cold up that high too....yah know what I mean??
LH
Keith Ashcraft <keith.ashcraft(at)itt.com> wrote:
[quote]Also, a case of Diet Coke weighs less than a case of Coke (less calories) and if you fly high enough, you don't need ice!!! Only need chains over high mountain passes in the Winter. (not really needed in the Summer) so plan your trips accordingly.
KA
[quote] [quote] ---
