n1cxo320(at)salidaco.com Guest
Posted: Sun Mar 11, 2007 9:24 am Post subject: RV6/6A Fuel Tank Attachment |
In preparation for replacing my loose slosh fuel tanks I want to mount the inboard forward bracket attachment the way Van now recommends it. My earlier plans just had you bolt the angle from the fuselage to the angle from the fuel tank tip.
How is the 'new' arrangement? Which angle bracket gets the 1/4-inch slot? The tank one or the fuselage one?
Also which goes forward - the tank bracket or the fuselage bracket.? Which bracket gets the platenut?
My search said that Rvator #1 of 1998 shows what Van now recommends, but my old Rvators were given away long ago. If someone had one handy and could e-mail me what I believe is on page 11 of that issue I would appreciate it.
Thanks for any help/insight.
n1cxo320(at)salidaco.com (n1cxo320(at)salidaco.com)
stevea(at)svpal.org Guest
Posted: Sun Mar 11, 2007 10:50 am Post subject: RV6/6A Fuel Tank Attachment |
John Fasching wrote: | Quote: | In preparation for replacing my loose slosh fuel tanks I want to mount the inboard forward bracket attachment the way Van now recommends it. My earlier plans just had you bolt the angle from the fuselage to the angle from the fuel tank tip.
John,
1st issue 1998, p 11 shows:
* slot in the tank angle
* plate nut in the fuselage angle
* tank angle forward of the fuselage angle.
If you'd like, I can scan the page and e-mail it directly to you.
Steve
RV-6A
Posted: Sun Mar 11, 2007 12:24 pm Post subject: RV6/6A Fuel Tank Attachment |
No, thank you, Steve, the information you gave me is exactly what I needed to know. I can take it from here.
Again, thank you !!!
Posted: Sun Mar 11, 2007 2:56 pm Post subject: RV6/6A Fuel Tank Attachment |
Tank one goes foreward.
Tank one get s the slot.
Fuse one gets the platenut.
Just did my 6A.
Don't have the appropriate RVator handy though - but I can take pictures next weekend of my install!
Zap me direct......if you want 'em.....
Ralph
Posted: Sun Mar 11, 2007 3:36 pm Post subject: RV6/6A Fuel Tank Attachment |
DO NOT ARCHIVE
Thanks, Ralph.
Posted: Sun Mar 11, 2007 3:47 pm Post subject: RV6/6A Fuel Tank Attachment |
John Fasching wrote: | Quote: | No, thank you, Steve, the information you gave me is exactly what I needed to know. I can take it from here.
| John,
Just for the record, in case you don't have this, there are some details on the bolt/washer installation. It is not a standard 1/4" bolt torque.
>From the RVator:
"Do not over tighten the bolt. If there is too much clamping pressure the joint will note separate. The correct torque is achieved by tightening the bolt until the AN970 washer can barely be moved with your fingers. Then tighten the bolt 1/6 of a turn (one flat on the head). The bolt has a drilled head and should be safety wired."
Good luck with the tank slosh clean out.
Steve
Gerald Richardson
Joined: 11 Jan 2006 Posts: 7 Location: Medicine Hat, Alberta
Posted: Sun Mar 11, 2007 7:21 pm Post subject: RV6/6A Fuel Tank Attachment |
Steve:
Wh en you get the page scanned, I would greatly appreciate a copy of it also.
Please email me at gerric(at)shaw.ca (gerric(at)shaw.ca)
Thank you for your time.
Gerald Richardson
RV-6A
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Steve Allison
Sent: Sunday, March 11, 2007 12:42
To: rv-list(at)matronics.com
Subject: Re: RV6/6A Fuel Tank Attachment
John,
Steve
RV-6A | Quote: | | Email Forum -http://www.matronics.com/Navigator?RV-List | 01234
03/11/2007 09:27
03/11/2007 09:27
_________________ RV6A |
wdleonard(at)gmail.com Guest
Posted: Mon Mar 12, 2007 5:09 am Post subject: RV6/6A Fuel Tank Attachment |
I am in the same boat as John (my wings are off for painting), but I can't remember the purpose of the platenut.
Dave Leonard
On 3/11/07, Gerald Richardson <gerric(at)shaw.ca (gerric(at)shaw.ca)> wrote: [quote]
Steve:
Gerald Richardson
RV-6A
David Leonard
Turbo Rotary RV-6 N4VY
My websites at:
http://members.aol.com/_ht_a/rotaryroster/index.html
http://members.aol.com/_ht_a/vp4skydoc/index.html
http://leonardiniraq.blogspot.com
khorton01(at)rogers.com Guest
Posted: Mon Mar 12, 2007 5:52 am Post subject: RV6/6A Fuel Tank Attachment |
On 12 Mar 2007, at 09:08, David Leonard wrote:
| Quote: | I am in the same boat as John (my wings are off for painting), but
Pictue the angle on the nose of the inboard tank rib is bolted to the
angle on the fuselage, with no slots in either angle. Now, imagine a
crash scenario where the wing leading edge hits something, and this
pushes the wing back. The nose of the tank rib is rigidly attached
to the fuselage, so there is a risk of the rib being pulled out of
the tank, releasing a large quantity of fuel, and leading to a fire.
This apparently happened on more than one accident, and led to a
design change.
The design change puts a slot in one of those angles. If the bolt is
not too tight, it will simply slide out the slot, and allow the wing
to be pushed back without pulling the fuel tank apart. This should
hopefully reduce the chance of a fuel tank breach, and reduce the
risk of a post-crash fire, which should improve survivability.
From a functionality point of view, it doesn't matter which angle
has the slot. My recollection is that for retrofits to existing
tanks, Van suggested to put the slot in the fuselage angle, as it can
be unbolted to make the mod. For new build tanks, Van suggested to
put the slot on the tank angle, as this was perceived to have some
advantage.
Ottawa, Canada
http://www.kilohotel.com/rv8
Posted: Mon Mar 12, 2007 7:35 pm Post subject: RV6/6A Fuel Tank Attachment |
Thanks Kevin,
I understand the purpose of the slot, though to be honest I am still hesitant to cut the slot. What if it changes the flutter characteristics or allows some movement that wears over time etc... (I know, lots of planes flying with that mod but it is a tough one to accept).
Anyway, my question is about the platenut. Even though Steve sent me the copy of the plans from the original RVator, I still don't understand the placement and/or purpose of the platenut. Is it a large platenut installed on the washer? (the plans say "miniature platenut"). If so, why not use a regular nut? Something about not letting the bolt get crooked when release is needed?
Dave Leonard
On 3/12/07, Kevin Horton <khorton01(at)rogers.com (khorton01(at)rogers.com)> wrote: [quote]--> RV-List message posted by: Kevin Horton <khorton01(at)rogers.com (khorton01(at)rogers.com)>
design change.
advantage.
Ottawa, Canada
My websites at:
http://leonardiniraq.blogspot.com [quote][b]
Posted: Tue Mar 13, 2007 2:48 am Post subject: RV6/6A Fuel Tank Attachment |
Ah, now I understand. Yeah, it could be to keep the bolt square to
the angle if release is ever needed. If you just had a bolt, nut and
two washers, I can imagine that the bolt could tip sideways a bit and
bind, which would defeat the purpose of the mod.
The purpose of these pieces of angle appear to be to support the
weight of the front of the fuel, especially when pulling some g.
Adding the slot does not compromise that function. I see no way this
would affect flutter, nor would I expect much movement, and thus
there should be very little, if any wear. I don't see a downside,
other than the time required to do the mod.
Kevin
On 12 Mar 2007, at 23:34, David Leonard wrote:
| Quote: | Thanks Kevin,
Dave Leonard
On 3/12/07, Kevin Horton <khorton01(at)rogers.com> wrote: --> RV-List
message posted by: Kevin Horton <khorton01(at)rogers.com >
design change.
advantage.
Ottawa, Canada
