kfackler(at)ameritech.net Guest
Posted: Fri Mar 02, 2007 7:58 pm Post subject: Landing distances |
After some careful, but not scientifically accurate, measurements, I've
determined the following for my aircraft:
Min takeoff: 400'
Min landing: 500'
Realistic takeoff: 500'
Realistic landing: 600'
This is in a Kolb Mark II with a Rotax 503, flying consistently at gross
weight of 750 lbs. I do have brakes, but they're the go-cart cable type and
hardly effective. They're not useful on landings or for short field takeoff
technique, only for slowing down while taxiing.
How do these compare to what the rest of you experience?
-Ken Fackler
Kolb Mark II / N722KM
Rochester MI
knowvne(at)aol.com Guest
Posted: Fri Mar 02, 2007 8:50 pm Post subject: Landing distances |
Really! 500 ft for landing???
Two foot ball fields end to end ???
I would have thought less...
Is this also the case for a Firestar II ????
The KOLB site doesn't list the landing distance but has
take off at 200 ft with a 503... Do we assume at Gross weight ?
How far off are these figure???? 8-/
Thanks!
Mark Vaughn
Posted: Fri Mar 02, 2007 9:01 pm Post subject: Landing distances |
| Quote: | Really! 500 ft for landing???
The KOLB site doesn't list the landing distance but has take off at 200 ft
with a 503
| Quote: | Do we assume at Gross weight ?
Like most mfgs of any sort of product, I'm sure they put the figures out
that have the most "wow" factor. Not to say they're wrong, but they probably
were generated under the most favorable conditions imaginable: a very light
ship with a very light pilot carrying a gallon or two of fuel on a low DA
day and with a stiff headwind. Don't get me wrong, I love my Kolb! But as
you say, what's realistic?
I don't claim to be a 'hot stick' so it's quite possible others can fly
their ships at slow enough speeds, and possibly with some help from flaps
which I don't have, and get it slow enough to stop much more quickly. But
that's why I asked, to see what others are doing.
-Ken
Eugene Zimmerman
Posted: Sat Mar 03, 2007 5:28 am Post subject: Landing distances |
Ken,
I easily cut that in half, no wind.
On Mar 2, 2007, at 10:57 PM, <kfackler(at)ameritech.net>
<kfackler(at)ameritech.net> wrote:
I've
Min takeoff: 400'
Min landing: 500'
gross
type and
takeoff
-Ken Fackler
Rochester MI
possums(at)bellsouth.net Guest
Posted: Sat Mar 03, 2007 6:16 am Post subject: Landing distances |
| Quote: | a very light
Depends on the ship
Short Field landings
http://video.google.com/videoplay?docid=-4011065178040668060&hl=en
These guys are good.
Posted: Sat Mar 03, 2007 6:48 am Post subject: Landing distances |
Bet a Kolb could catch the #3 wire.... ONCE hahahahaha
Mark Vaughn
a58r(at)verizon.net Guest
Posted: Sat Mar 03, 2007 11:55 am Post subject: Landing distances |
Most any Kolb could probably BACK in to #2 wire...even #1. Reminds me
of the HotRock who "specialized" in grabbing #1 wire. His epitaph:
Fantail Frank...rip.
regards,
Bob N. FireFly 070 Old Kolb
Bill Vincent
Posted: Sat Mar 03, 2007 6:29 pm Post subject: Landing distances |
Possum
How big is the tail hook on your plane?
Bill Vincent
FS II
P.S. Just read a story about landing on Aircraft carriers,it surprised me
they land almost strictly by angle of attack.
_________________ Bill Vincent
Firestar II
Upper Peninsula of Michigan |
Posted: Sat Mar 03, 2007 7:58 pm Post subject: Landing distances |
What do you mean Land by Angle of Attack?
They use a Vasi system, I thought ...
Mark Vaughn
David Lucas
Joined: 10 Jan 2006 Posts: 79 Location: Europe. based Amsterdam NL
Posted: Sun Mar 04, 2007 4:53 am Post subject: Re: Landing distances |
Reminds me of landing at one of the jungle strips I used to fly into in Papua New Guinea years back. It had an upslope on it with the parking bay about two thirds of the way up the strip, but that last third was almost level so you could actually land downhill if you were lightly loaded, providing you put it down right at the threshold and jumped on the brakes. The Pilatus Porter turbo prop with beta range and reverse thrust could stop before the turn off but the rest of us in our 206's, aztecs, etc usually went past a bit and had to turn around and taxy back. It developed into an unofficial short landing contest with the winner being acknowledged at the bar the next evening.
There was one of those push/pull twin boom cessna 337's (I think) made an approach there one day, first day out after major maintenance. He touched down right on the mark and stopped short of the turn off ! Fantastic stuff. Won the prize that week.
Slight problem though, the reason for the short landing roll was that is was not a roll, but a skid ! He'd forgotten to put the gear down and the back of the drag curve, full flap approach required enough power that it did not not to trigger the warning horn. It turns out he had been flying the fixed gear version, the 336, earlier in the day.... oops !
The competition was called off after that as it was thought nobody could trump that effort .... particularly as it was the chief pilot at the time who did it !!!!
C’est la vie ....... and no it wasn't me !
David.
lndc
Posted: Sun Mar 04, 2007 7:11 pm Post subject: Re: Landing distances |
Hi, I used to own an original firestar with a 377. Take off was never over 125'. Landing about the same maybe a little longer.
Dan Charter
John Jung
Joined: 10 Jan 2006 Posts: 108 Location: Surprise, AZ, USA
Posted: Tue Mar 06, 2007 6:10 pm Post subject: Re: Landing distances |
Ken,
I fly a 503 Firestar II, which should be similar to yours for take-off and landing. Trouble is, I usually fly at 600 pounds gross, or less. When I have flown at 750 pounds, both take-off and landing were significantly longer. So, your numbers don't sound bad to me.
_________________ John Jung
Firestar II N6163J
Surprise, AZ |
