sam(at)fr8dog.net Guest
Posted: Mon Feb 26, 2007 12:14 pm Post subject: 2 Grounds |
Do I need a separate ground for the Avionics, including the phones. Or
will the ganged firewall (cool side) ground block be satisfactory for
all my grounds? I think the audio panel (GMA 340) has a ground block.
Sam Marlow
steerr(at)bellsouth.net Guest
Posted: Tue Feb 27, 2007 8:43 am Post subject: 2 Grounds |
Did you ever get an answer to this, Sam? I don't know if it applies to your
situation, but I'm using an intercom in addition to my Microaire 760 radio.
Bob kindly gave me a wiring diagram for hooking up the two together. That
diagram specifically separated the signal ground from the power ground.
Hope this helps.
sam.marlow
Posted: Tue Feb 27, 2007 4:47 pm Post subject: 2 Grounds |
No, I didn't get an answer, and my grounds are just hanging waiting to be connected. If I just knew where?
Hope this helps.
john(at)ballofshame.com Guest
Posted: Tue Feb 27, 2007 9:20 pm Post subject: 2 Grounds |
Bleary eyed, but still almost thinking straight, I'll take a shot at
this....
Ground is ground is ground...however, the best grounding schemes would
use wiring with 0 resistance and 0 length. Since we have to use real
wire, the second best choice is to keep the avionics ground wires as
short as possible to a single grounding point. That ground point then
gets grounded to the firewall ground. This is good because it keeps
everything very short AND it makes wiring a lot more convenient (only 1
wire going to the firewall). What you DON'T want to do is mount a piece
of copper on the instrument panel, for example, and then tie that to the
firewall ground because then you'll have caused a ground loop (you'll
have ground coming from the panel metal also in this example). Wherever
you tie them together, the only metal it should be touching (other than
the other avionic ground wires) is the firewall ground.
As far as a "signal" ground, I'm assuming we're talking about the serial
lines? Anything that communicates with each other should have their
signal grounds tied together. I'm not up to my avionics install yet but
if avionics are anything like the real word, how you do this, exactly,
is dependent on the specific thingy you're installing. In a perfect
world, you would have a signal ground pin somewhere but I believe some
avionics don't quite work this way. If you list the avionics you're
trying to make play with each other, I'm sure someone probably has a
good answer.
-John
www.ballofshame.com
> Hope this helps.
> Bill
nuckollsr(at)cox.net Guest
Posted: Wed Feb 28, 2007 10:42 am Post subject: 2 Grounds |
At 11:32 AM 2/26/2007 -0500, you wrote:
will the ganged firewall (cool side) ground block be satisfactory for all
Sam Marlow
See chapter on Grounds in the 'Connection and in
particular the suggested architectures illustrated
in Figure Z-15 in . . .
http://aeroelectric.com/articles/Rev11/AppZ_R11J.pdf
The term "need" is not quantifiable. There are tens
of thousands of vehicles including airplanes where
various systems in power distribution and signal
handling are "grounded" willy-nilly without consideration
for the physics
For every builder that touts a "need" there will be
a half dozen who cite observations based on their
own experiences that contradict the notion of "need".
Bottom line is that there are reasons based in physics
that show now potential for noise and/or degraded operation
can be elevated by inattention to grounding. It's easy
to do but if you don't wish to do it, probability of
a PERCEIVED degradation of performance is low. HOWEVER
when a build comes on the list citing some anomalous or
noisy behavior, the first question that enters my mind
is, "How are your grounds architectured?".
If things are stuck down to the airframe without regard
to practices and principles KNOWN to reduce risk, then
identifying and fixing the problem can be much harder.
None of us can tell you that you NEED to do anything
but plenty of us who will sympathize with you should
some noise problem present itself at some time in the
future.
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
LarryRosen
Posted: Wed Feb 28, 2007 6:02 pm Post subject: 2 Grounds |
To quote you, chapter 18 page 11 of the connection (hope I am not
violating your copy write)
"The forest-of-ground-tabs technique described in Chapter 5 is entirely
suitable and convenient for most equipment in the electrical system.
However, while it is electrically correct to wire all the panel mounted
equipment to the same ground block the total number of wires can be
significant.
Further, given that there are a number of small signal systems
vulnerable to noise concentrated on the panel, it makes sense to create
separate and co-located ground system for these potential victims. ..."
Are you saying that the separate and co-located avionics ground system
is acceptable because the potential for noise from this design is
minimal, and the advantage of not running many separate grounds from all
the avionics to the ground bus outweighs the minimal noise potential.
Can I then make the conclusion, that if the ground bus were near the
avionics, running the wires a single bus would be minimally superior?
Larry Rosen
Robert L. Nuckolls, III wrote:
<nuckollsr(at)cox.net>
> Or will the ganged firewall (cool side) ground block be satisfactory
> for all my grounds? I think the audio panel (GMA 340) has a ground
> block.
> Thanks,
> Sam Marlow
for the physics
future.
( EVERY day . . . )
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
N1DeltaWhiskey(at)comcast Guest
Posted: Thu Mar 01, 2007 8:26 am Post subject: 2 Grounds |
Larry,
I'll take a stab at attempting to clarify this. It makes sense to run all
ground wires to a single ground point, including the avionics. What I
believe Bob is saying is that common ground point for the avionics may be
established near the avionics, then a single wire connects the avionics
ground point to the "forest of tabs" on the firewall.
In effect, this method uses the same ground point and the circuitry is
virtually identical from a current flow standpoint. It precludes the
possibility of alternate feed paths for the ground current, and may, to some
miniscule degree, reduce the possibility of electromagnetic crosstalk. The
avionics to firewall ground wire needs to be large enough to handle the
combined current demand of all of the avionics.
I see plusses and minuses with the remote avionics ground point. On the
plus side is that the amount of wires from the panel to the firewall is
reduced making, possibly, for a cleaner wiring job, lower weight
(minimally), and so on. On the minus side is that failure of the connection
between the avionics ground and the firewall ground wipes out all of the
avionics (but a good installation should preclude this from being a
significant concern). It is a wash in my view, and therefore, neither
arrangement is necessarily "superior" to the other. Weigh your concerns and
use the system you feel most comfortable with.
Hope this helps.
Doug Windhorn
Posted: Thu Mar 01, 2007 9:09 am Post subject: 2 Grounds |
Thanks Doug for clarification!
Sam Marlow
Doug Windhorn wrote:
<N1DeltaWhiskey(at)comcast.net>
Larry,
all ground wires to a single ground point, including the avionics.
What I believe Bob is saying is that common ground point for the
avionics may be established near the avionics, then a single wire
connects the avionics ground point to the "forest of tabs" on the
firewall.
to some miniscule degree, reduce the possibility of electromagnetic
crosstalk. The avionics to firewall ground wire needs to be large
enough to handle the combined current demand of all of the avionics.
the plus side is that the amount of wires from the panel to the
firewall is reduced making, possibly, for a cleaner wiring job, lower
weight (minimally), and so on. On the minus side is that failure of
the connection between the avionics ground and the firewall ground
wipes out all of the avionics (but a good installation should preclude
this from being a significant concern). It is a wash in my view, and
therefore, neither arrangement is necessarily "superior" to the
other. Weigh your concerns and use the system you feel most
comfortable with.
Hope this helps.
Doug Windhorn
Posted: Thu Mar 01, 2007 9:46 am Post subject: 2 Grounds |
At 12:08 PM 3/1/2007 -0500, you wrote:
Sam Marlow
>Larry,
>What I believe Bob is saying is that common ground point for the avionics
>may be established near the avionics, then a single wire connects the
>avionics ground point to the "forest of tabs" on the firewall.
>crosstalk. The avionics to firewall ground wire needs to be large enough
>connection between the avionics ground and the firewall ground wipes out
>all of the avionics (but a good installation should preclude this from
>being a significant concern). It is a wash in my view, and therefore,
>neither arrangement is necessarily "superior" to the other. Weigh your
>concerns and use the system you feel most comfortable with.
>Hope this helps.
>Doug Windhorn
Right on Doug. Thanks. The single-point failure issue
is addressed by the notation you'll find on Figure Z-15
illustrations for the panel ground bus where I show
five separate, 20AWG wires to run from the panel ground
bus down to the firewall ground.
dennis.glaeser(at)eds.com Guest
Posted: Thu Mar 01, 2007 10:16 am Post subject: 2 Grounds |
I ran Power grounds for each radio to the forest of tabs, and used the
'remote ground' for all of the signal connection 'lows' and shields.
With this setup, I believe that the connection from the remote ground to
the forest of tabs is non-critical (although I agree it's failure
potential rivals my chances of winning the lottery
Dennis Glaeser
--- <-snip-> ---
and
Hope this helps.
Doug Windhorn
LarryRosen
Posted: Thu Mar 01, 2007 3:27 pm Post subject: 2 Grounds |
Thanks you all for the clarification
Larry
> Sam Marlow
>> Larry,
>> run all ground wires to a single ground point, including the avionics.
>> firewall.
>> is virtually identical from a current flow standpoint. It precludes
>> the possibility of alternate feed paths for the ground current, and
>> may, to some miniscule degree, reduce the possibility of
>> electromagnetic crosstalk. The avionics to firewall ground wire
>> needs to be large enough to handle the combined current demand of
>> lower weight (minimally), and so on. On the minus side is that
>> failure of the connection between the avionics ground and the
>> firewall ground wipes out all of the avionics (but a good
>> installation should preclude this from being a significant
>> Hope this helps.
>> Doug Windhorn
#40356
N205EN (reserved)
<http> |
enewton57(at)cableone.net Guest
Posted: Thu Mar 01, 2007 4:33 pm Post subject: 2 Grounds |
I have a decidedly small and low tech avionics system. A single radio (ICOM A200) a single transponder (Colllins) and a single intercom (PS 1000). So with that simple of a system, I'll probably just run the ground wire from each component to the forest of tabs on the firewall. If I'm reading your post right, that's perfectly acceptable, right?
Eric Newton - Long Beach, MS
BH #682
http://mybearhawk.com
Posted: Thu Mar 01, 2007 8:53 pm Post subject: 2 Grounds |
Eric,
Certainly a way that I could feel comfortable with (and the way I did mine).
Doug
rv9jim(at)juno.com Guest
Posted: Fri Mar 02, 2007 6:16 am Post subject: 2 Grounds |
Yup! That is what I did. Just get a large enough ground tab block. I
had to run several wires thru the fire wall pass thru and use the ground
tabs on the fire wall side. That is OK as there was a lot of unused tabs
on that side anyway. I think I got the 24/24 block. Working out fine
and I still have about a dozen empty tabs on the fire wall side to be
used as necessary.
Jim
RV9-A QB (FWF bout done)
klehman(at)albedo.net Guest
Posted: Fri Mar 02, 2007 6:53 am Post subject: 2 Grounds |
Me too however the radio, intercom, and my strobe power supplies are all
also grounded to their respective cases (as well as their ground pins)
and therefore to the metal airframe. I can not hear the strobe whine in
flight but it is obvious on the ground. Since various capacitors and
chokes on the 12v strobe power supply did not help, I decided that this
was a "feature" to remind me to turn them off after landing
Fortunately there is no transponder reply noise which has annoyed me on
some other airplanes.
Ken
[quote] Eric,
mine).
Doug
Posted: Fri Mar 02, 2007 1:02 pm Post subject: 2 Grounds |
At 06:31 PM 3/1/2007 -0600, you wrote:
| Quote: | I have a decidedly small and low tech avionics system. A single radio
Yes. Taking all wires to the single point is
a perfectly good thing to do. Extending the
ground system up to the panel is useful for
more complex installation where the total number
of grounds gets up to a dozen or more.
Bob .. .
