rhdudley1(at)bellsouth.ne Guest
Posted: Wed Feb 28, 2007 5:31 pm Post subject: Van's Ammeter |
Listers,
I have a Van's - 0 + ammeter. It is very sensitive to rapidly changing
loads, especially to the strobe load. The needle is in constant
vibration while the strobes are on and/or the landing/taxi light wig-wag
is wig-wagging . Is there a reasonable means (preferably connected
externally) for increasing its response time. Its external connections
are gnd, power, and two terminals to the shunt.
Thanks in advance for suggestions.
Richard Dudley
RV-6A flying
nuckollsr(at)cox.net Guest
Posted: Wed Feb 28, 2007 6:15 pm Post subject: Van's Ammeter |
At 08:30 PM 2/28/2007 -0500, you wrote:
<rhdudley1(at)bellsouth.net>
Listers,
loads, especially to the strobe load. The needle is in constant vibration
while the strobes are on and/or the landing/taxi light wig-wag is
Richard Dudley
RV-6A flying
This instrument is a very low-impedance device (40mv full
scale as I recall) in terms of adding damping. The really
slick way to damp these devices is to put a drop of hi-viscosity
silicone oil in the pivot bearings. We experimented with this
at Cessna about 1965 . . . it worked really well. I think
we had Stewart-Warner do that mod on future units but I
don't recall now. There's a 50,000 cts "differential lock"
oil that's popular with the electric race car crowd that costs
about $5.00 for a 1 oz bottle. One drop on each bearing
would damp it very nicely.
The problem with doing the job electrically is that the
source impedance for the driving signal is VERY low . . .
like a few milliohms. It takes a whopping capacitor to
add much time-constant at this low level. Try putting say
a 10 ohm resistor in series with one of the shunt leads
and the parallel the instrument with the biggest capacitor
you can find. I've got some 330uf/6v tantalums you could
try. About three of those in parallel would get 1000uF.
This MIGHT be useful to try.
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
Posted: Thu Mar 01, 2007 6:45 am Post subject: Van's Ammeter |
Thanks for the reply.
I would prefer trying the external experiment before considering opening
the meter.
So, I'd like to take you up on your offer of the loan your capacitors to
do the experiment. If it works, I'll replace your caps.
Earlier, I tried to surpress RF which pinned the meter when I
transmitted. A ferrite clamp on one lead did reduce the reaction.
My address is
RH Dudley
8425 Littleleaf Ct.
Orlando, FL 32835
Thanks.
Richard Dudley
Robert L. Nuckolls, III wrote:
<nuckollsr(at)cox.net>
> Listers,
> changing loads, especially to the strobe load. The needle is in
> constant vibration while the strobes are on and/or the landing/taxi
> light wig-wag is wig-wagging . Is there a reasonable means
> (preferably connected externally) for increasing its response time.
> Its external connections are gnd, power, and two terminals to the
> shunt.
> Richard Dudley
> RV-6A flying
( EVERY day . . . )
Posted: Thu Mar 01, 2007 8:58 am Post subject: Van's Ammeter |
At 09:44 AM 3/1/2007 -0500, you wrote:
the meter.
Earlier, I tried to surpress RF which pinned the meter when I transmitted.
????? an RF sensitive ammeter ????
This doesn't sound like the instrument I looked at
several years ago that came from Vans. Is this a powered
device? More than two wires that only come from a shunt?
| Quote: | My address is
RH Dudley
8425 Littleleaf Ct.
Orlando, FL 32835
Thanks.
Richard Dudley
Posted: Thu Mar 01, 2007 9:13 am Post subject: Van's Ammeter |
Yes, as I mentioned in my first e-mail, there are four connections, two
in addition to the shunt for power and ground.
> Bob,
> opening the meter.
> to do the experiment. If it works, I'll replace your caps.
> My address is
> RH Dudley
> 8425 Littleleaf Ct.
> Orlando, FL 32835
> Thanks.
> Regards,
> Richard Dudley
