Radiator Mods for NSI engine
Clem Nichols
PostPosted: Sun Feb 25, 2007 5:36 am    Post subject: Radiator Mods for NSI engine Reply with quote
Floyd:
Any pictures available on your radiator modification? My NSI EA81 does OK during cooler weather, but in the summer it has a tendency to overheat during long climbs, and the cooling is only marginal at level flight.
Clem Nichols
n10pg(at)neo.rr.com
PostPosted: Sun Feb 25, 2007 7:43 am    Post subject: Radiator Mods for NSI engine Reply with quote
Hi Clem:
On this subject I would like to relate a little story in the life of my NSI
equipped Kitfox5.
My airplane's first flight was in May 1996. I was very anxious to fly into
small grass strips for breakfast fly-ins and such. As the summer progressed
I noticed an ever increasing coolant temperature. I related this info to
Lance Wheeler and he suggested that I replace the originally furnished brass
radiator with his new aluminum one, which I did. The results were pleasingly
dramatic. The old brass radiator was sitting in the corner of my workbench
and at the end of my annual inspection that winter I decided to find a more
suitable permanent resting place for it, up on the shelves. As I looked at
the radiator a little more closely, I noticed that it was well over 50%
plugged up by mostly bugs and insects. I guess flying in and out of grass
stips is somewhat detrimental to water cooled engines. Particularly on
takeoff with full power the prop sucks up everything in its path and shoves
it into the radiator. The buildup will soon deminish the air flow through
the radiator, thus reducing the cooling capacity. It is now part of my
annual inspection to thoroughly clean the fins of the radiator. Sometimes it
is necessary to repeat that once or twice in the summer/fall. I haven't had
any cooling problems since.
Peter Graichen
http:/home.neo.rr.com/n10pg/kitfox.htm
[mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Clem Nichols
Sent: Sunday, 25 February, 2007 08:33
Subject: Radiator Mods for NSI engine
Floyd:
Clem Nichols
wingsdown(at)verizon.net
PostPosted: Sun Feb 25, 2007 7:51 am    Post subject: Radiator Mods for NSI engine Reply with quote
Clem,
Contact me off list.
Rick
GENTRYLL(at)aol.com
PostPosted: Sun Feb 25, 2007 8:06 am    Post subject: Radiator Mods for NSI engine Reply with quote
Would it be practical to put some fiberfax or similiar material on the oil pan, between it and the muffler on the NSI installation, to help reduce the oil temperature?
AOL now offers free email to everyone. Find out more about what's free from AOL at 657x4311227241x4298082137/aol?redir=http%3A%2F%2Fwww%2Eaol%2Ecom" target="_blank">AOL.com. [quote][b]
Clem Nichols
PostPosted: Sun Feb 25, 2007 11:17 am    Post subject: Radiator Mods for NSI engine Reply with quote
Peter:
I gave the radiator an external "flushing" last summer, and did seem to
notice some improvement even though there were no bugs, grass, etc., readily
visible on it. Perhaps there was some thin dirt buildup from flying off a
wet turf field that wasn't apparent the way bugs, etc. would be. Certainly
none of the openings were completely plugged. If I have the same problem
this summer I may flush the engine and radiator, and see if that helps. I
remember someone not too long ago talking about finding a bunch of "goop" in
an NSI engine. All that aside, however, I'd still like to see what Floyd
did to make a cowl for his radiator as mine does not have one, and I
consider myself somewhat conceptually challenged.
Clem Nichols
Hi Clem:
NSI
equipped Kitfox5.
brass
radiator with his new aluminum one, which I did. The old brass radiator
more
stips is somewhat detrimental to water cooled engines. It is now part of
my
it
had
Peter Graichen
Floyd:
Clem Nichols
Clem Nichols
PostPosted: Sun Feb 25, 2007 11:18 am    Post subject: Radiator Mods for NSI engine Reply with quote
That certainly sounds worth considering. Has anyone tried it?
kitfox69(at)earthlink.net
PostPosted: Sun Feb 25, 2007 2:16 pm    Post subject: Radiator Mods for NSI engine Reply with quote
Klem,
I have the NSI cowl which I modified. I'll get some pictures later this week. It is supposed to warm up here and be clear for a few hours. We only get these conditions about every 52 1/2 days by decree of Mother Nature. The real reason my cooling is under control now is because of the efforts of Jay Roese. He now knows precicely what radiator the EA 81 needs. I suggest you talk to him. The cost of a new radiator is worth the peace of mind. Meanwhile, I'll get some pictures together for you.
Regards, Floyd
P.S. Jays cell: 585-729-5098
PostPosted: Sun Feb 25, 2007 2:26 pm    Post subject: Radiator Mods for NSI engine Reply with quote
I'm going tom jump in here and suggest you talk to Jay Roese about this one too. He is privy to all the latest technology and can probably suggest something which will fill the bill. Ie may not have it, but he sure can tell you where to find it.
BTY, and this is not an advertizement, Jay built me a beautiful Tuned exhaust for my EA 81 engine. It is simple and efficient.
We toned it down with a short insert in the straight section. Cool! Jay can be reached at: 585-729-5098
d(at)cfisher.com
PostPosted: Mon Feb 26, 2007 4:57 am    Post subject: Radiator Mods for NSI engine Reply with quote
Clem,
Although I do not have a NSI engine I will tell you I have over 30 years in the automotive field. I would suggest if your radiator sizing is correct and has worked in the past for other owners of same engine and climate then you have a problem unique to you.
A good rad shop will flow test your rad and tell you if it is ok. A radiator can get get crusted up on the inside and the flow and heat transfer will suffer dramatically. Same goes for your cooling hose if you have any that are not free flowing. You can always get your rad shop to make you a new radiator with a thicker core if you do not want to expand the area of it . Rad shops that work on custom builds will know best.
A radiator with a thin film of "grime" will have less cooling capacity than a clean one. Wipe a clean rag over the front of rad and see if it shows dirt.
I get a ton of bugs in summer time and I power wash from rear and blow out all those bugs and dirt that collect every few weeks but that might be every 10 or 20 hours. Even a garden hose will clena alot of . Try some soap or degreaser on the radiator prior to washing to loosen up the grime. Make sure if is compatible with your rad -- Copper or Alum !!
Hope that " cools " you down !!
Dave
avtar412
PostPosted: Sat Mar 03, 2007 10:52 pm    Post subject: Re: Radiator Mods for NSI engine Reply with quote
Here is a shot of my series 5 radiator set up. I had the origianl NSI brass unit but had to replace with aluminium one. I have a front exposed scoop inlet and defuser track. Hot day I get 100C on climb& 90 on cruise
 Filesize:  900.05 KB
 Viewed:  700 Time(s)
