bbradburry(at)allvantage. Guest
Posted: Fri Feb 23, 2007 3:08 pm Post subject: How to solder Mini DIN connectors |
I could use little assistance...
I am trying to solder the pins on a mini din connector and I melted the
plastic on the first one! The pins do not look like they are removable,
but if the plastic is that easy to melt...
Can someone give me a little advice?
Bill B
n395v
Posted: Fri Feb 23, 2007 4:11 pm Post subject: Re: How to solder Mini DIN connectors |
Get a good crimper, some pins and new connectors. Crimp don't solder.
_________________ Milt |
mprather(at)spro.net Guest
Posted: Fri Feb 23, 2007 4:12 pm Post subject: How to solder Mini DIN connectors |
Assuming it needs to be solder.. How hot is your iron (how many watts)?
Having a hot/high wattage iron means the area of the pin where the
soldering needs to be done can get hot quickly enough to melt the solder
while the end of the pin embedded in the plastic remains cool enough to
not melt the plastic. A slow/small iron will take relatively longer to
locally heat the pin enough to melt the solder, and the extra time will
heat the whole pin more - melting the plastic.
Use a freshly cleaned iron tip. And freshly tin the tip. The iron can
transfer heat faster if the tip has tin on it.
Another trick I have used with some amount of success is to take a pair of
small forceps and grip the pin being soldered right where the pin goes
into the plastic. This creates a heat sink which causes there to be
steeper temperature gradient along the length of the pin. At least that's
the theory I use to explain it to myself..
The trick is to get onto and off of the pin as quickly as possible. Use a
hot, clean, freshly tinned iron..
Matt-
<bbradburry(at)allvantage.com>
Bill B
