Don Owens
Joined: 17 Jan 2006 Posts: 24 Location: North Central Washington
Posted: Fri Feb 23, 2007 10:50 am Post subject: [Spam] How to connect to 2" aluminium tube? |
I used 1/2" copper tape (purchased from stained-glass store) with adhesive
back. I attached several strips to the plastic tank, soldered them together
with aircraft wire then attached the wire to the filler neck. I don't know
if it works, but it looks real good!
Don Owens
I want to ground a 2" aluminium tube used below the fuel filler of a
Europa (plastic).
I suppose I could weld a tab on it, or was thinking could order a few Adel
clamps (with aluminium straps), and discard the rubber and see if I could
get proper size and connect the ground wire to mounting screw after I
cleaned off any finish on areas I want to conduct.
Any other ideas? There are hoses clamped on this elbow at both ends, I am
looking for a way to dissipate static charge. Think by sneaking a flat
thin piece of aluminium half under the clamp and attaching to this would
be an OK resolution?
Thx.
Ron Parigoris
10:22 AM
1:26 PM
