d(at)cfisher.com Guest
Posted: Tue Feb 20, 2007 3:02 am Post subject: GSC Propeller - edit - Barry more questions |
I added "cable" into this,
>>That is why I have a 1/8" CABLE attached to engine and airframe in case of separation. You lose your engine in a Kitfox and I think you will be outta control . <<
Barry - A few more questions.
How old are blades?
How old is the hub?
How many hours on each ?
When was the last time it was adjusted and torqued?( months and hours )
Do you have any pictures ?
And Like I said -- All blades can depart no matter if an IVO, GSC , NSI or WARP .
I would like to think that they are isolated but it Can happen.
It would be interesting to be able to narrow it down to what happened.
Dave
Float Flyr
Posted: Tue Feb 20, 2007 5:09 am Post subject: GSC Propeller - edit - Barry more questions |
Additionally: Did you have your torque wrench calibrated?? It is very easy for a torque wrench to be out by more than 20 %. The only way I could see all three blades departing at one tine would be if the roots were crushed way too much (too much torque on the mounting bolts) or you hit something mid air which broke all three blades in one revolution. Were the blades recovered? You should try very hard to find them.
Noel [quote]
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
wingsdown(at)verizon.net Guest
Posted: Tue Feb 20, 2007 7:32 am Post subject: GSC Propeller - edit - Barry more questions |
I haven't been on in awhile since the retirement move, but I find the theory of the security cable very interesting. Has anyone actually exercised the performance of the theory with an engine departure. Though I like the idea and find it interesting I am not sure if the aircraft could actually be controlled with the CG aft and in constant change. Might not a ballistic parachute be more relied on?
Rick
rjdaugh
Posted: Tue Feb 20, 2007 7:57 am Post subject: GSC Propeller - edit - Barry more questions |
I read an account a few years ago about a plane (Waco?) that lost a prop and an engine mount with three on board. They could not see the engine, but it was still hanging there by an oil line. ONE OIL LINE! But it was enough to keep their CG far enough forward that they landed safely.
If the oil line had failed to hold the weight of the engine, the out come would have been a disaster.
I don’t have safety cables on my engine, but I get closer every time I read a story like Barry’s.
Randy
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Rick
Sent: Tuesday, February 20, 2007 8:33 AM
Subject: RE: GSC Propeller - edit - Barry more questions
Rick
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
_________________ Randy
Kitfox 5/7 912S
Black Hills, South Dakota |
FLIER(at)sbcglobal.net Guest
Posted: Tue Feb 20, 2007 8:05 am Post subject: GSC Propeller - edit - Barry more questions |
The cable(s) are short. The violent shudder can
break the mounts but the fuel, coolant, ignition
lines, and the cowl sorta hold things in. A safety
cable allows flex and will hopefully hold the mass on
the front end once things quit shaking.
Yes, the CG will change, but I'd rather be a little
aft rather than TOTALLY aft.
--- Original Message ---
| Quote: | I haven't been on in awhile since the retirement
| Quote: | theory of the security cable very interesting. Has
anyone actually
| Quote: | exercised the performance of the theory with an
| Quote: | I like the idea and find it interesting I am not
| Quote: | could actually be controlled with the CG aft and
in constant change.
| Quote: | Might not a ballistic parachute be more relied on?
Rick
fox5flyer(at)idealwifi.ne Guest
Posted: Tue Feb 20, 2007 8:30 am Post subject: GSC Propeller - edit - Barry more questions |
Personally, I think your days of the good life would be over as soon as that heavy engine and prop left the airframe. The w/b would be so far out I doubt very much if it would be controllable. The nose would go straight up in the air without enough elevator to bring it down, the stall would be very quick, then the spin would follow. I think the cables are a good idea. Weight would be minimal and might be a bacon saver.
Anybody know of this happening? It may be such a remote possibility that it's not an issue.
Deke
dcsfoto
Posted: Tue Feb 20, 2007 9:01 am Post subject: Re: GSC Propeller - edit - Barry more questions |
many years ago I built a MEAD Adventure,prior to finishing the designer
Mr Mead was killed when the aircraft was testing had an engine mount fail.
the engine and mount seperated the airframe.
i am building a Model 7 and it will have a cable engine to airframe.
cheap insurance
