spar corrosion
mj(at)yakuk.com
PostPosted: Sat Feb 17, 2007 2:42 am    Post subject: spar corrosion Reply with quote
I believe it was Denis who wanted pics of spar corrosion. Anyway, attached.
Pic 2631 shows the spare surface near the wing skin. You will see how the
exfoliation has bulged outwards. The tell tale is the wing skin being pushed
from the inside.
Pic 2633 was from the inside surface.
Go check your spars in the areas that are not accessible. I find a small
digi flash camera very good if you can get your hand in through the
lightening holes.
Hole that helps some one. We have seen this on about 6 a/c out of 70 or so
in the UK.
Mark Jefferies for YAK <http://www.yakuk.com> UK Ltd
 Filesize:  152.14 KB
 Viewed:  216 Time(s)
 Filesize:  145.9 KB
 Viewed:  251 Time(s)
 Filesize:  135.21 KB
 Viewed:  226 Time(s)
dsavarese(at)elmore.rr.co
PostPosted: Sat Feb 17, 2007 5:56 am    Post subject: spar corrosion Reply with quote
Thanks Mark.
Dennis
ggg6(at)att.net
PostPosted: Sat Feb 17, 2007 5:37 pm    Post subject: spar corrosion Reply with quote
Is this in reference to CJ's or Yak's ?? Gary Gabbard CJ N22YK
[quote]-------------- Original message from "Mark Jefferies YAK UK" <mj(at)yakuk.com>: --------------
from the inside.
lightening holes.
in the UK.
Mark Jefferies for YAK UK Ltd
