I didn't believe it till I saw it
Tommy Walker
PostPosted: Wed Feb 14, 2007 10:27 am    Post subject: I didn't believe it till I saw it Reply with quote
You guys may have seen this 701 on UTube, but I missed it.
I didn't know it would do that, plus I'm not sure I would even try.
http://www.youtube.com/watch?v=PAN6jzbhEAw
Plus, here's another longer one.
http://www.youtube.com/watch?v=O7DIVkrMIOU
Tommy Walker
N25A - Anniston, AL
Chris Lewis
PostPosted: Wed Feb 14, 2007 4:19 pm    Post subject: Re: I didn't believe it till I saw it Reply with quote
There's a photo on the Zenith Website showing a Swedish 701 just about to nose over and it says "Don't try this at home" Interesting that they'd post it...
Chris in Seattle
 Filesize:  85.59 KB
 Viewed:  270 Time(s)
750/ Zen-vair Semi-Scratch Builder
N750XT (reserved)
john300exc
PostPosted: Fri Feb 16, 2007 6:16 am    Post subject: Re: I didn't believe it till I saw it Reply with quote
I hate for my first post on this forum to be negative, but the roll demonstrated on the You Tube video wasn’t much of a roll. The aircraft nose is pointed down as the plane is inverted and he finishes the roll about 90 degrees off his initial heading. I also wonder how many Gs he pulled to get the nose level at the end of his roll. It is hard to estimate his altitude, but how many mistakes high he was flying? The 701 is a tough little plane but the wing is probably not the best for inverted flight. It takes a significant push on the stick in a Decathlon or Pitts to keep the nose up while inverted with their symmetric wing, must take a massive push with the 701. Sometimes “Don’t try this at home” actually means, “DON’T TRY THIS AT HOME!!”
John Bolding
PostPosted: Fri Feb 16, 2007 6:53 am    Post subject: I didn't believe it till I saw it Reply with quote
Interesting video, the roll and loop were fun to watch but what was VERY interesting to me was the impression that this aircraft has a longer wing (the "European" version I've been told).
I ask every few months in case a new member has some info.
Does anyone have any information on the construction of the longer wing??
I have been told (by someone that has looked at one carefully)that a simple increase in span OUTBOARD the struts was done with NO change to the web,caps,skins, ribs ect.,just the addition of one extra bay.
Can anyone add to that info, or throw cold water on it?
LOW&SLOW John Bolding
