nuckollsr(at)cox.net Guest
Posted: Wed Feb 14, 2007 7:33 am Post subject: Poor man's DAS |
I can't recall if I've mentioned this company before here
on the list but for those interested in watching, gathering,
storing and plotting various data from their airplane or
elsewhere, take a look at this product:
http://www.labjack.com/labjack_u3.php?prodId 5
I've had one on the shelf for about a year but didn't
have the incentive (work order) to get it out of the box
and see what it takes to make it sing, dance and do dishes.
Got a task coming up for a customer that can use a small
portion of its features so I got it out and fired it up
last night. It's almost TOO capable . . . takes awhile to
wade through all the "mommy, mommy, look what I can do!!!"
things to get it running with a simple task: read and
store 3 channels of analog data.
But the more I play with it, the more impressed I am with
the capability it offers for a paulty $100.
One OBAM aviation task I'm considering for it is to measure
and store voltage and current values for a battery recharge
cycle using the various $low$ charger/maintainers. It's
pretty easy to look at a recharge voltage curve and assume
that the last 10% of the time under the curve accounts for
10% of total energy transfer. However, we know that's not
the case.
What the voltage curves don't show us is that during the final
phase of the upward climb for applied voltage, current going
into the battery is going down, hence the last 10% of charge
time may account for only a small percentage of total energy
transferred to the battery. It would be cool to really go
measure that.
So as soon as my customer takes the hit on my exorbitant
fees to learn how to use this thing do to his job, I'll be
able to move the equipment over to the bench where the battery
tests are going on for some elightening 'fun' stuff.
The second battery recharge using a Battery Tender completed
this morning. The attached image shows the first and second
recharge voltage curves. The first curve is in red, the second
in black. I note that this charge cycle ended earlier (battery
wearing out? It's several years old) but the charge cycle extended
into the end-of-charge voltage inflection. Given that devices
like the Battery Tender probably use analog comparators to
sense when states change, the earlier curve may have terminated
a tad early on noise . . . nonetheless, it appears that these
whimpy little 'chargers' may be quite capable of stuffing all
the snort back into an SVLA battery . . . all it takes is patience.
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
Description: |
Filesize: |
37.93 KB |
Viewed: |
333 Time(s) |
pilot4pay
Joined: 01 Jan 2007 Posts: 171 Location: Louisville, KY
Posted: Wed Feb 14, 2007 8:56 am Post subject: Poor man's DAS |
Thanks a bunch for the link, I've seen similar devices in my engineering
publications, but all were priced at least 3 times higher. This is
definitely going to find it's way into my bench. Way-cool! The support files
and operating system compatibility files are impressive to say the least.
Thanks again, this is a real gem of an instrument!
Craig Smith
_________________ Craig Smith
CH640 builder
SN: 0078
"Just think how stupid the average person is,
and then realize that half of them are even stupider!"
--George Carlin |
frank.hinde(at)hp.com Guest
fvalarm(at)rapidnet.net Guest
Posted: Wed Feb 14, 2007 1:31 pm Post subject: Poor man's DAS |
Bob,
I'm interested in this Labjack too for a different application. My question
is, does it come with software that is loaded on a PC to control the
labjack? If not, what software does one use or does one have to write their
own from scratch?
Bevan
Posted: Wed Feb 14, 2007 2:29 pm Post subject: Poor man's DAS |
At 01:30 PM 2/14/2007 -0800, you wrote:
Quote: |
Bob,
own from scratch?
Bevan
It comes with a manually operated test program that lets you
individually wiggle any i/o port and make measurements. Really
handy for setting up or troubleshooting. It also comes with a
scaled down version of DAQFactory, the "express" version that
lets you set up DAS and control routines and capture/plot data.
I have the test tools up and running. I hope to get into the
DAS application this weekend. You can also write routines
to access the Labjack from a variety of applications such
as LabView and Visual Basic.
klehman(at)albedo.net Guest
Posted: Wed Feb 14, 2007 4:48 pm Post subject: Poor man's DAS |
Isn't the real value of an intelligent charger simply that it prevents
or limits overcharging and battery damage? I suspect that any charging
scheme that prevents overcharging is 99% of the answer regardless of the
exact programming algorithm. A wall wart and an LM317 voltage regulator
set for float voltage for example has worked well for me for many years.
Since the current at float voltage (self discharge current) seems to end
up the same, I'm confident that the slow charge is fully charging the
battery and that I'm not overcharging. As noted , limiting the voltage
really only slows the last few percent of charging.
I've been playing a bit with desulphating pulse charging. It hasn't
helped badly sulphated batteries for me so I've been sceptical. However
lately I've been using a 60 hz 40 volt square wave (discharging a
capacitor) to periodically top up seldom used batteries (non aviation)
and I think it might be improving the cranking current that I can get
out of them and extending their lives at least a bit. Might be neat to
try to generate some hard numbers for that.
Ken
Posted: Wed Feb 14, 2007 6:36 pm Post subject: Poor man's DAS |
Yes . . . for sustaining a battery in storage, you support
the battery at or slightly above the stable open circuit
terminal voltage which is on the order of 12.9 to 13.0 volts
at room temperature. To fully charge a battery at room temperature,
13.8 volts will eventually do it but to speed things up toward
the end a shutoff/top-off of 14.0 to 15.0 volts is not uncommon
for smart chargers.
Quote: | Since the current at float voltage (self discharge current) seems to end
Well, I can try it out and see. On one of the recharge cycles
I'll set it up on a constant current power supply limited
at 13.0 volts and see what kind of energy the battery accepts.
Quote: | I've been playing a bit with desulphating pulse charging. It hasn't helped
badly sulphated batteries for me so I've been sceptical. However lately
I've been using a 60 hz 40 volt square wave (discharging a capacitor) to
periodically top up seldom used batteries (non aviation) and I think it
might be improving the cranking current that I can get out of them and
extending their lives at least a bit. Might be neat to try to generate
Just had a direct e-mail question from a reader:
"Comments/Questions: Hi Bob. I took your class several years ago in
Watsonville, CA and I thought you might have the answer for me. I am
wondering how often my battery should be changed out. It is a Concorde
RG-35AXC battery and it was placed in service "new" in October of 2002.
This battery is in a C-182. It flies approximately 100 hours per year. I
have noticed the battery not cranking the O-470 as strong as it did 6
months ago. I am just wondering what the expected life service for a
battery of this type is. Thanks for your help!"
To which I answered: There is no really hard data on "expected" service
life of a battery. There are huge variables not the least of which include
how many times it has been fully depleted and how long it was allowed
to sit in a discharged state. I'll suggest that if the battery is
noticeably
soft while cranking an engine, it has probably been unserviceable as a
standby source of energy for a long time.
Replacement of batteries should be based on energy available
to run endurance mode goodies for what ever length of
time you choose. The FAA is fond of "30 minutes". I'm fond
of "Duration of Fuel Aboard". Which ever you choose, if you
periodically test the battery for its ability to meet your
endurance goals, you'll find that it gets replaced long before
it won't crank the engine any more.
And again, "service life", whether based on engine cranking
ability or demonstrated endurance performance can be influenced
strongly by the environment in which the battery lives. I'd
be hard pressed to either persuade or dissuade you from
believing that your October 2002 purchase was not a good
value.
There are a number of products that tout some ability
to reverse sulfation. The problem is that the techniques
range from simply "pulse charging" to finely tuned pulses
of energy that supposedly match the natural resonant
frequency of the sulfate molecule . . . 3.26 Mhz as I
recall. Current levels for suggested pulses range from
hundreds of milliamps to as much as 20 amps or more.
Do a Goggle on "desulphation" and "dsulfation" and
you'll get a total of 69,000 hits the vast majority
of which discuss some process touted to rejuvenate
a sulfate-distressed battery. Even our friend Jim Weir
published an article in April 2002 Kitplanes that
suggested some popular flavor of battery performance
booster.
The wild variability of processes and techniques offered
in the marketplace suggests that nobody has hit upon
the one true process. Some guy from Soneil in Canada
sent me some chargers that featured "battery
desulfating" capabilty. I've studied both a 14v and
28v version on a DAS and 'scope and as near as I can
tell, they perform just like a Schumacher "smart
charger" . . . I can detect no special energy output
that might target the evil sulfate crystals.
I'll suggest that parking the airplane on a maintainer
and doing cap checks at one year and every 6 months
thereafter will yield the ideal replacement interval
for any given battery. If your endurance criteria is
zero minutes, then run it until it won't crank the
engine any more. Further, it's a sure bet that your
perceived service life will exceed that of the guy
in the next hangar that wants 3 hours of support for
the e-bus.
I just stuck a discharged SVLA battery on the 13.0 volt
power supply. We'll see what the battery will suck up
at that voltage.
lumkes(at)msoe.edu Guest
Posted: Thu Feb 15, 2007 12:14 pm Post subject: Poor man's DAS |
I can personally vouch for the Labjack series. I have purchased and installed approximately 25 units in a teaching laboratory; no matter how many mistakes the student made, only one unit ever failed and the factory replaced it at no charge. I now use them again at my "new" position, and have my own personal one at home. I have used it to record data around the house (temp's, flow, etc.) and plan on installing one in the airplane with a mini-ITX PC to have my own data logger / EIS. The interface can easily be done in Labview, and having the "carpc" will also allow me to run PocketFMS on a split screen. This is definitely "experimental" and so all required gauges will also be "steam wired". There so many ICs now like thermocouple amplifiers with built in cold junctions, small economical pressure transducers, etc., that adding features are easier now than ever before for amateur electrical system integrators (like myself).
Long term plans: adding solid state gyros (IC chips now have this ability) for AHRS and wing leveling / GPS based auto-pilot.
John
khorton01(at)rogers.com Guest
Posted: Thu Feb 15, 2007 4:51 pm Post subject: Poor man's DAS |
On 15 Feb 2007, at 15:11, John and Kim Lumkes wrote:
Quote: | I can personally vouch for the Labjack series. I have purchased and
Bob and John,
Thank you very much for the recommendation for the Labjack. This
unit should allow me to add some missing items to my flight test data.
John - where do you purchase suitable, affordable, robust
transducers? I'm looking to measure some temperatures, and flight
control positions.
Kevin Horton RV-8 (finishing kit)
Ottawa, Canada
http://www.kilohotel.com/rv8
Posted: Fri Feb 16, 2007 6:21 am Post subject: Poor man's DAS |
Kevin,
High Temps: Standard thermocouples with a an Analog Device AD594 or similar
Low Temps: many options, I use a LM34, outputs degrees F in mV with a 5V
supply Cheap
Low precision distance: Sharp IR GP2D120
Low pressures: check Jameco or similar, search Keywords for pressure sensor;
they have several Motorola Freescale 0-1.45psi for 8-14 dollars.
You can directly measure a thermocouple output with a good 16bit A/D
converter; probably not directly with the labjack.
This is only a small sampling of the exploding field of "cheap" electronics,
very capable linear IC circuits, and little programmable controllers.
Bob and John,
Thank you very much for the recommendation for the Labjack. This unit should
John - where do you purchase suitable, affordable, robust transducers? I'm
looking to measure some temperatures, and flight control positions.
Ottawa, Canada
Posted: Fri Feb 16, 2007 6:41 am Post subject: Poor man's DAS |
At 07:49 PM 2/15/2007 -0500, you wrote:
Quote: |
Bob and John,
control positions.
For temperatures up to 150C consider the LM135 series devices
by National. These are voltage sensitive zeners with a
regulation voltage of 10mv/degree-K. You can bias these little
fellers up with a single resistor pull-up to 5v. The measured
voltage at 25C is (273+25)x10 = 2.980 volts.
For higher temperatures, my favorite jelly-bean is the AD596/597
series thermocouple to 10mv/degree-C converter chips.
For control positions, consider "string pots" or "draw string pots".
These are spring loaded drums of fine cable mounted on
a potentiometer. See:
http://www.dataq.com/support/documentation/pdf/article_pdfs/stringpotan.pdf
http://www.aeroelectric.com/Pictures/Data_Acquisition/String-Pot.jpg
Here's one I made using a piece of retraction spring from a
pocket tape measure, a miniature RV-4 series potentiometer
and some odd bits of aluminum stock. The "cable" is 7-strand
u-control flying wire from a hobby shop.
This was used to measure a stroke of about 1/2" on the
master brake cylinders of a cockpit simulator. You can
measure longer strokes by using multi-turn pots. The metal
work is pretty straightforward. These can be had as purchased
items. See:
http://www.globalspec.com/FeaturedProducts/Detail/celesco/Compact_String_Pot_SP1/29565/0?fromSpotlight=1
http://www.unimeasure.com/
http://www.impresssensors.co.uk/draw-wire.htm
They're not inexpensive.
( EVERY day . . . )
ainut(at)hiwaay.net Guest
Posted: Thu Feb 22, 2007 7:20 am Post subject: Poor man's DAS |
John, my plans are similar to yours. Good luck with them.
I've had a labjack U12 for many years now and may have found a better alternative. Go to some of the Freescale (Motorola) processor seminars where the price includes a test board. You're more into the design phase during implementation but you can keep costs in the under $10 range if you like. The downside is that even though CodeWarrior lite comes 'free' during the seminar,it is ATROCIOUS as a development environment.
David M.
