Michel
Posted: Fri Feb 09, 2007 10:10 am Post subject: GPS. WAS: ASIs |
On Feb 9, 2007, at 4:22 PM, Noel Loveys wrote:
| Quote: | How much do you guys trust the altitude feature of your GPS?
Unless it is differential GPS, about 300 feet, Noel. And it's not
likely to change. Something to do with the geoidal height table,
somewhat coarse in your "worldwide" instrument and the fact that the
angles made by the satellites over the horizon give poor triangulation
in the Y-axis (altitude).
Cheers,
Michel
dave
Posted: Fri Feb 09, 2007 10:35 am Post subject: GPS. WAS: ASIs |
I have a 196 garmin and find it to be fairly accurate ( +/- 50 feet)
most of the time.
I have had at time erratic readings of 200 to 800 feet fklying over
Georgian Bay here in Ontario.
Why ? No idea here , but it only happens afew times but once over land
again it seems to be ok. ?
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Posted: Fri Feb 09, 2007 11:35 am Post subject: GPS. WAS: ASIs |
Probably the infamous "Georgian Bay Triangle".
But at a guess, I'd say you are seeing some reflecting
signals off the water confusing your GPS a bit. I
don't know for sure, but the GPS freq doesn't
penetrate water well and may bounce off. All the
signals are weak to begin with, so it could be one
reason.
VOR and other signals can bend as they cross shore
lines too and can cause some position error. When I
flew across the bigger ponds, we had to watch for
this. Only was a problem when far enough out to
receive just one navaid.
Kurt S. S-5
--- dave <dave(at)cfisher.com> wrote:
| Quote: | I have a 196 garmin and find it to be fairly
accurate ( +/- 50 feet) most of the time.
feet fklying over Georgian Bay here in Ontario.
Why ? No idea here , but it only happens a few
times but once over land again it seems to be ok. ?
Dave
Don't pick lemons.
See all the new 2007 cars at Yahoo! Autos.
http://autos.yahoo.com/new_cars.html
Float Flyr
Posted: Sun Feb 11, 2007 4:25 pm Post subject: GPS. WAS: ASIs |
The further you deviate from the equator the worse it gets. I'm at around
48 N give or take and it's not too bad. There was one day as I mentioned in
an earlier post where my location (static) was jumping around several miles.
On the map source topo maps I have for Canada one end of the pond I use to
launch from is programmed in as 20' ( it's closer to 8') the middle of the
pond is listed as close to 30' and the far end is 24'. Imagine here in
Newfoundland water doesn't meet it's own level!
With more than six satellites I will trust the speed indication if it read 0
static before starting.
Still like maps and usually I'll spend the time dead reckoning before the
flight just to stay familiar with it. Then again I still carry and use,
every chance I get, a slide rule. Amazes some people what can be done
without batteries.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Float Flyr
Posted: Sun Feb 11, 2007 4:28 pm Post subject: GPS. WAS: ASIs |
Loran C..... No problems with a good fix. They were supposed to add
altitude to it some time ago but don't think they ever did. Needs a long
wire antenna though
Noel
[quote] --
Kitfox III-A
Beemer
Joined: 26 Aug 2006 Posts: 87 Location: Middle Georgia
Posted: Mon Feb 12, 2007 6:20 am Post subject: GPS. WAS: ASIs |
Noel,
I don't remember which GPS you have, but could you be getting out of WAAS
range if you go north far enough?
Bradley
_________________ Beemer
KF2 (and now an M3!)
Suzuki G10 three-banger
Middle Georgia |
Float Flyr
Posted: Mon Feb 12, 2007 6:01 pm Post subject: GPS. WAS: ASIs |
All satellites in the GPS constellation are in geostationary orbit. By
definition that means they must also be directly over the equator. The
further away form the equator you are the greater the angle of incidence of
any signal reaching your receiver. The greater the angle of incidence the
greater the possibility of error both vertical and horizontal.
I believe there are WAAS transmitters in northern Labrador (Voisey's Bay).
They were installed to facilitate heli-borne geo-magnetic surveys.
I had a friend who was the navigator of a ship doing exploration surveys all
over the world. He told me in the high arctic and in the Antarctic the GPS
was just another big expensive paperweight.
Noel
[quote] --
Kitfox III-A
jcorner(at)shaw.ca Guest
Posted: Mon Feb 12, 2007 7:53 pm Post subject: GPS. WAS: ASIs |
Noel
Your statement in your last post are quite incorrect and I could not
let them pass without comment.
First as I understand it there are 6 orbits of 4 satellites each
inclined at approximately 55 degrees to the equator.
This gives world-wide coverage, including the north and south poles,
with a minimum of 4 satellites in view at all times.
WAAS stations are currently all located in continental US or Alaska
and provide coverage in those areas.
The farther north areas of Canada do not benefit from this
augmentation service nor does Europe.
You may be referring to differential GPS locations in Labrador.
Your final comments I believe apply to Loran coverage at the poles.
Cheers
Jim
orbit. By
The
incidence of
incidence the
(Voisey's Bay).
surveys all
the GPS
Noel
Guy Buchanan
Posted: Mon Feb 12, 2007 11:06 pm Post subject: GPS. WAS: ASIs |
At 06:01 PM 2/12/2007, you wrote:
| Quote: | All satellites in the GPS constellation are in geostationary orbit. By
GPS orbit altitude: 10,988 nautical miles (Geo is about 22,300 statute miles.)
Ref: http://www.losangeles.af.mil/smc/pa/fact_sheets/gps_fs.htm
Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
Michel
Posted: Tue Feb 13, 2007 10:22 am Post subject: GPS. WAS: ASIs |
On Feb 13, 2007, at 4:51 AM, Jim Corner wrote:
| Quote: | Your final comments I believe apply to Loran coverage at the poles.
Well, I don't think so, Jim, Loran C is a hyperbolic system and you
only need to be within range of the stations. Nothing to do with the
poles. I think our friend Noel was mistaking GPS for many other
satellites, like communication ones, which are indeed geostationary
over the equator. Such as broadcasting satellites and the INMARSAT
maritime communication satellites.
In Norway, which goes up to latitude 72 N on mainland (hello Torgeir!
TV sateliites and INMARSAT are not covering those latitudes. Even
here, in the south, all TV dishes are nearly horizontal.
The GPS, pretty much like its predecessor, the Transit Satellite
System, is making a birdcage around the earth. I think the GPS doesn't
have true polar orbits but the Transit had. And because of that, the
frequency of a fix opportunity was actually greater the further north
or south, one would come.
Noel, of course Loran C is much better than Decca, which was 1943
technology and phased out a few years ago. Decca and Loran C are very
reliable as a relative positioning system. I.e. fishermen could come
back and fetch their nets in the thickest fog if the had plotted the
position. But it was not too accurate as absolute position, i.e.
relative to latitude and longitude. Something to do with lower
frequencies that are influenced by land masses, etc.
The Omega system was also working on a very low frequency and therefore
not so accurate. But it was the first system to use the idea of a
differential signal. It meant that existing maritime VHF coastal
stations were registering the current offset and sent it back to the
ships as to increase the accuracy of their position.
WAAS is also a differential system and while it is only covering North
America, differential GPS has been used for a long time in e.g. Europe.
But then, it was only a local service that you had to subscribe to.
E.g. in the North Sea offshore industry, they use differential GPS
where a correction is sent to the platforms or pipe-laying vessels. The
problem is: There isn't really a standard format as for WAAS.
Sorry to be a bit lengthy on the subject but I have worked with
maritime navigation systems for many years. The bottom line is: All of
them beat the old sextant!
Cheers,
Michel
Float Flyr
Posted: Tue Feb 13, 2007 1:59 pm Post subject: GPS. WAS: ASIs |
I guess you can't believe everything you are told. That includes the GPS
constellations being geostationary. The site says it is a 12 hr orbit.
They don't go into accuracies or more directly inaccuracies in any specific
part of the world. After all you really don't want Bin Laden's crew using
GPS against yourself.
Noel
[quote] --
Kitfox III-A
Float Flyr
Posted: Tue Feb 13, 2007 6:09 pm Post subject: GPS. WAS: ASIs |
On 13-Feb-07, at 11:22 AM, Michel Verheughe wrote:
Michel, the reason I suspected he was referring to loran is that I
think you will find that the nearest Loran station or slave is a
long, long way from the poles.
Canada doesn't have any mid continent stations and the coastal
stations are at lower latitudes.
the poles. I think our friend Noel was mistaking GPS for many other
I
As I understand it, the main difference between WAAS and what
commonly called differential GPS is that WAAS broadcasts its
corrections via stationary satellites where differential GPS
stations communicated error signals directly to a special receiver,
thus useable over a much smaller range, but perhaps more accurate.
| Quote: | WAAS is also a differential system and while it is only covering
North America, differential GPS has been used for a long time in
e.g. Europe. But then, it was only a local service that you had to
subscribe to. E.g. in the North Sea offshore industry, they use
differential GPS where a correction is sent to the platforms or
pipe-laying vessels. The problem is: There isn't really a standard
format as for WAAS.
of them beat the old sextant!
I have to agree the old sextant was difficult in turbulence, as was
transposing time differentials from the loran scope to the charts!
My nav experience was in the early 60's in P2V7's over the Pacific
Cheers
JIm
KF2- 582 1100+ hrs
MichaelGibbs(at)cox.net Guest
Posted: Tue Feb 13, 2007 9:27 pm Post subject: GPS. WAS: ASIs |
Noel sez:
geostationary orbit. By definition that means
Noel, you are a one-man dis-information machine.
According to Wikipedia
<http://en.wikipedia.org/wiki/Global_Positioning_System>:
"...The GPS design calls for 24 SVs [satellites]
to be distributed equally among six circular
orbital planes. The orbital planes are centered
on the Earth, not rotating with respect to the
distant stars. The six planes have approximately
55° inclination (tilt relative to Earth's
equator) and are separated by 60° right ascension
of the ascending node (angle along the equator
from a reference point to the orbit's
intersection).
"Orbiting at an altitude of approximately 20,200
kilometers (12,600 miles or 10,900 nautical
miles; orbital radius of 26,600 km (16,500 mi or
14,400 NM)), each SV makes two complete orbits
each sidereal day, so it passes over the same
location on Earth once each day. The orbits are
arranged so that at least six satellites are
always within line of sight from almost anywhere
on Earth.
"As of January 2007, there are 29 actively
broadcasting satellites in the GPS constellation.
The additional satellites improve the precision
of GPS receiver calculations by providing
redundant measurements. With the increased number
of satellites, the constellation was changed to a
nonuniform arrangement. Such an arrangement was
shown to improve reliability and availability of
the system, relative to a uniform system, when
multiple satellites fail."
Mike G.
N728KF
