rvreynolds(at)macs.net Guest
Posted: Mon Feb 12, 2007 6:51 am Post subject: Static Air System - Alternate Air Valve- REDUX |
OK,I 'm sorry, apologize, etc.
Does anyone have a source or suggestion for the alternate air valve for superior crafted OBAM planes?
Does anyone have a source or suggestion for the alternate air valve like the "real" planes have?
Richard Reynolds
ddddsp1(at)juno.com Guest
Posted: Mon Feb 12, 2007 8:25 am Post subject: Static Air System - Alternate Air Valve- REDUX |
Try Tony at SAFEAIR1.
Dean
40449
Interested in getting caught up on today's news?
Click here to checkout USA TODAY Headlines.
glastar(at)gmx.net Guest
Posted: Mon Feb 12, 2007 8:44 am Post subject: Static Air System - Alternate Air Valve- REDUX |
Hi Richard,
hopefully attached, what I did (on a Glastar) a Curtis Drain Valve CCA-1550 together with a T and two elbows to fit the static line.
And I did an inflight check, error is 4 KIAS to high indication.
Werner
Richard Reynolds wrote: | Quote: | OK,I 'm sorry, apologize, etc.
Richard Reynolds
27.84 KB |
424 Time(s) |
LarryRosen
Posted: Mon Feb 12, 2007 9:32 am Post subject: Static Air System - Alternate Air Valve- REDUX |
Safe Air 1 has a kit <www.safeair1.com>
But, I like Werner's approach better.
Larry Rosen
#356
-------------- Original message ----------------------
| Quote: | Hi Richard,
Werner
> Richard Reynolds
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
LloydDR(at)wernerco.com Guest
Posted: Mon Feb 12, 2007 11:07 am Post subject: Static Air System - Alternate Air Valve- REDUX |
It is basically the same thing, breaking the static air line, just one
comes with a streamer to pull, or am I missing something?
Posted: Mon Feb 12, 2007 10:13 pm Post subject: Static Air System - Alternate Air Valve- REDUX |
Hi Daniel,
yes, the SafeAir one seems to have a plug with a streamer attached, my
DIY one has a CCA-1550 <http://curtissuperiorvalve.com/pipethread.html>
which you push and turn to lock open (not visible in my last picture as
it it protruding on the bottom of my panel (below the alum. angle visible)).
br Werner
Posted: Tue Feb 13, 2007 6:28 am Post subject: Static Air System - Alternate Air Valve- REDUX |
Very nice, and eliminates the possibility of an accidental opening. I
wish I had known about these...I like the safe air method, but am
worried about where to put the streamer to make it accessible, but
reduce accidental pulling.
Dan
marcausman
Posted: Tue Feb 13, 2007 7:46 pm Post subject: Re: Static Air System - Alternate Air Valve- REDUX |
Try the alt air valve used on a Cirrus SR-20, which can be purchased from a dealer. Part # is long forgotten, but it was about $20. It's plastic, light weight, and has a large lever on it. The lever and valve are two different part #s, if I recall correctly. You can mount it with an Adel clamp.
Marc
_________________ Marc Ausman
http://www.verticalpower.com "Move up to a modern electrical system"
RV-7 IO-390 Flying |
