smokey_bear_40220(at)yaho Guest
Posted: Wed Feb 07, 2007 5:06 pm Post subject: ASIs (was Vixen Information) |
Paul,
Any chance that water got in the static line?
Kurt S.
--- Paul Seehafer <av8rps(at)tznet.com> wrote:
| Quote: | Mark,
I've noticed that the airspeed indicator for my
Model IV is off by sometimes 10 - 15 mph (e.g;
reading 85-90 when I'm really going 100 mph). Weird
thing is that it is not consistent at all......
8:00? 8:25? 8:40? Find a flick in no time
with the Yahoo! Search movie showtime shortcut.
http://tools.search.yahoo.com/shortcuts/#news
av8rps(at)tznet.com Guest
Posted: Thu Feb 08, 2007 5:22 am Post subject: ASIs (was Vixen Information) |
Kurt,
Yes, very possible. I guess of all the things I thought of I never thought
about that one. I am typically having so much fun flying my Kitfox that I
ignore the ASI for the most part (chuckle).
Paul
barry(at)pgtc.com Guest
Posted: Thu Feb 08, 2007 6:10 am Post subject: ASIs (was Vixen Information) |
My airspeed indicator is just the opposite, it is accurate up to about 90
mph then starts reading too high, as much as 15 mph at 100 (which has to be
while decending.)
I operated without a static port, just using the pressure behind the panel,
until recently when I put a static port in anticipating installation of a
transponder, but this seemed to have no effect. I will learn more when the
system is calibrated and certified. But there must be something wrong with
the airspeed indicator. Does anyone have any suggestions?
Barry West
Lynn Matteson
Posted: Thu Feb 08, 2007 6:12 am Post subject: ASIs (was Vixen Information) |
I never got an answer to my personal email to you, so I'll ask again
here...what are the black objects on the top of your Vixen wing?
Another lister asked the same question, and I didn't see an answer
there either.
Lynn
On Feb 8, 2007, at 8:17 AM, Paul Seehafer wrote:
Kurt,
thought about that one. I am typically having so much fun flying
my Kitfox that I ignore the ASI for the most part (chuckle).
Paul
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
dave
Posted: Thu Feb 08, 2007 6:35 am Post subject: ASIs (was Vixen Information) |
Barry, Mine reads at 90MPH TAS about 105 +
I have no external static port.
Now If i open the door the ASI drops to about 95 mph
Then if I stick my arm out the door fully exteneded and my ASI reads about
90 mph.
I guess you could say that doing this makes the cabin at th proper pressure
as it would be with a proper external static port.
At lower speeds 75 mph or les it seems fairly accurate to about 45 mph then
the ASI reads low.
Movies here http://www.cfisher.com
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Posted: Thu Feb 08, 2007 6:52 am Post subject: ASIs (was Vixen Information) |
Sorry Lynn. I resonded twice last night but the e-mails kept bouncing back.
I tried again just a few minutes ago to resend. Let me know if it doesn't
work. Btw your e-mails are coming to me just fine.
If you don't get my e-mail I did respond to the lists questions in detail as
well. Should show up on the list soon I would think? (with my internet
provider one never knows?)
Ok ok, to satisfy your curiousity, those covers are for my dual on board
radar units....don't all kitfoxes have these? Alright, just kidding....
Paul Seehafer
Lynn Matteson
Posted: Thu Feb 08, 2007 7:31 am Post subject: ASIs (was Vixen Information) |
Thanks, Paul, I got all the info now and your emails, and all the
pictures. Yeah, I have radar units on mine just in case those
Washington, DC jets get a little too close (kick in the other
cylinders and leave 'em : ) )
Lynn
bouncing back. I tried again just a few minutes ago to resend. Let
me know if it doesn't work. Btw your e-mails are coming to me just
fine.
detail as well. Should show up on the list soon I would think?
(with my internet provider one never knows?)
board radar units....don't all kitfoxes have these? Alright, just
kidding....
Paul Seehafer
N369LM |
Posted: Thu Feb 08, 2007 8:37 am Post subject: ASIs (was Vixen Information) |
Paul,
Being from Wis myself, I know what you mean with fun
somehow beating out small problems like jittery ASI's.
I am sure you fly mostly by feel anyway, so it is not
a big problem. And winter is just when you have fun
without bugs....
I agree with the leaky line idea too. Be careful
blowing in the pitot. Very little pressure will bust
the ASI. I used a looped tube at the pitot instead
for this. Just add a little water in the lower loop
and raise a few inches to pressure the line.
On mine, I ran the pitot line down the left doorpost
and put a "T" about 6" from the bottom. The "T" runs
up to the ASI. I can see thru the line enough to
check for water and drain out the sealed bottom, if
necessary. It can hold a bit before it ever
interferes.
For the static line, I put a 90 elbow just inside the
plane and ran the line up and over to the other side
in a loop before going forward. If any water gets in,
it doesn't get past the 90 and drains back out.
All that worked fine until I added my radiator scoop.
That seems to have changed the airflow over my static
port and changed my accuracy.
I did make the static port with a center nylon bolt in
it. This bolt is drilled for airflow and slotted so
that I can screw it in or out to slightly change the
distance from the fabric that I draw static pressure.
Havenīt tried changing that yet for effect. Maybe
overkill. But I liked the building process enough to
enjoy inventing....
Kurt S. S-5
| Quote: | Kurt,
Paul
Sucker-punch spam with award-winning protection.
Try the free Yahoo! Mail Beta.
Posted: Thu Feb 08, 2007 4:09 pm Post subject: ASIs (was Vixen Information) |
Thanks Dave, I think we both need an answer. Anybody have an explanation
to these different problems, Dave's reads too low and mine reads too high?
Barry
Original Message:
Date: Thu, 8 Feb 2007 09:31:45 -0500
Subject: Re: Re: ASIs (was Vixen Information)
90 mph.
the ASI reads low.
Dave
dave
torgemor(at)online.no Guest
Posted: Thu Feb 08, 2007 4:53 pm Post subject: ASIs (was Vixen Information) |
Barry and Dave,
the first step is to check the airspeed indicator, such indicators often
have a S shape in the graph. I.E. Show too low at low speed near perfect
in the middle and much to high at max. speed.
Then look at the aircraft side, a crossvented static port (this is a must
for some "correct" static pressure). Also the pitot line must be without
leak, etc.
As an example, a frozen pitot head will give increasing speed as you
climb! Or, vice versa.
Cockpit static source may give some large altimeter error as well.
It is not just enough to check the altimeter against the encoder
altimeter, you'll also need to check that the altimeter is within the
required specifications with a ramp tester, and the as a whole system.
This is really important for those flying in/into controlled airspace,
lot's of other aircraft with TCAS (traffic collision avoidness system).
Our altimeter and transponder is important items under such conditions.
Torgeir.
On Fri, 09 Feb 2007 01:08:25 +0100, barry(at)pgtc.com <barry(at)pgtc.com> wrote:
high?
Barry
Original Message:
about
90 mph.
pressure
then
the ASI reads low.
Dave
Float Flyr
Posted: Fri Feb 09, 2007 7:12 am Post subject: ASIs (was Vixen Information) |
Torgeir:
Where I did my training was about two miles directly off the end of RWY 31
at Gander Intl.. All our training planes were more or less fully equipped.
They were the best planes in the world.... They had everything except
pilots!
On day one we were warned never to turn on a transponder. They were all
mode C without the encoders... They sent the frame sets for the altitude
without altitude info. Apparently on at least one occasion someone turned
on a transponder and gave a transport cat aircraft some interesting seconds
on take off. Definitely not a good idea.
BTW all the encoders and encoding altimeters I've seen are connected to
static lines.
I double your call for the cross vented static ports. And someone else
called for a drip loop on the static lines not altogether a bad idea
especially with the cross port system.
On my first flight last year I was doing a few circuits. On the water my
ASI was jumping around like a cat on a hot roof. Once I got airborne it
would settle out but read too high. When doing my post flight inspection I
found the static port, a plastic fitting, was hanging on, half in half out,
by the static line. I still have to get another port and install a proper
cross port static set up.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
lcfitt(at)sbcglobal.net Guest
Posted: Fri Feb 09, 2007 9:53 am Post subject: ASIs (was Vixen Information) |
You can eliminate instrument variables as a reason by using the manometer
and calculator. If that checks out OK, the problem would be elsewhere in
the plumbing and or location of the static port.
Lowell
| Quote: | Thanks Dave, I think we both need an answer. Anybody have an explanation
Barry
