jwt(at)roadmapscoaching.c Guest
Posted: Tue Feb 06, 2007 8:48 pm Post subject: Electrical System Critique |
I am pretty close to finalizing my electrical system and would really like to have some knowledgeable folks give it a rigorous critique. I have attached a Word document with my objectives, panel layout and schematic. If any of you are willing, I would really appreciate your taking the time to study the design and give me your recommendations.
Feel free to contact me offline or call me at 804-303-1927
Thanks in advance to those who give me some input.
John Testement
jwt(at)roadmapscoaching.com (jwt(at)roadmapscoaching.com)
40321
Richmond, VA
FWF, engine, wiring
No virus found in this outgoing message.
Checked by AVG Release Date: 2/6/2007
 Download |
| Filename: |
Electrical_System_Objectives.doc |
275.5 KB |
| Downloaded: |
539 Time(s) |
sean(at)stephensville.com Guest
Posted: Tue Feb 06, 2007 11:21 pm Post subject: Electrical System Critique |
Posted: Wed Feb 07, 2007 8:43 am Post subject: Electrical System Critique |
Jon Reining
Posted: Wed Feb 07, 2007 9:26 am Post subject: Re: Electrical System Critique |
This is a new product coming out on the market that looks like it may have a lot of appeal.
http://www.verticalpower.com/
Jon (and Bill) Reining
40514 - tailcone - still
rvbuilder(at)sausen.net Guest
Posted: Wed Feb 07, 2007 10:54 am Post subject: Electrical System Critique |
That is cool! Look forward to seeing them at OSH.
Michael
marcausman
Posted: Thu Feb 08, 2007 9:12 pm Post subject: Re: Electrical System Critique |
John,
Unless you believe that you'll have a disabling catastophic failure caused by the main battery, you could simplify your system by wiring the two batteries in parallel and eliminate a contactor and switch. It may be hard to properly diagnose and manage such a failure while in flight. And if that type of failure occurred, you'd lose your attitude sources while you diagnosed the problem and switched to the backup batt.
It sounds likes you mainly want some extra juice for starting and alternator failure, and if that's the case, wiring the batteries in parallel would take care of that and always be available.
_________________ Marc Ausman
http://www.verticalpower.com "Move up to a modern electrical system"
RV-7 IO-390 Flying |
LarryRosen
Posted: Sat Feb 10, 2007 8:39 am Post subject: Electrical System Critique |
John,
I have not seen much response, so I will add my 2 cents.
The list is long. Much of which are things to consider. The design you
have is safe and will work just fine. Just some of my thoughts.
I do not see anything in the equipment list to allow GPS navigation.
Are you adding a Freeflight GPS to the Chelton?
You have a 30 amp battery bus feed that is longer than 6" it should have
a contactor. But the contactor would not make it a battery bus. The
only load that needs to be on the battery bus would be the electric
ignition and maybe the dome lights. Then you can have a 10 amp battery
bus. Another feed with a contactor would feed the other loads.
Why the double pole switch for the e-bus feed and the standby battery
switch?
replace the double pole avionics master with 2 switches to eliminate the
single point failure to the avionics bus and endurance bus.
Do you need the transponder on the e-bus? (it is on mine also)
Consider moving the pitot and to the main bus.
Why a 50 amp ANL from the alternator. Change to 60 and 6awg wire. You
show 43 amps max. Is that with zero diversity? I thought at one point
you had 58 amps max intermittent load.
Why 16awg wire to the starter on light? with a 1amp fuse you only need
22awg. Consider a fusable link in lieu of the fuse. Whose starter? I
have not seen this wiring detail.
Starter contactor. BNC has the diode internal, Vans does not have a
diode. I am using Perihelion designs snap jacks (bi-directional zener)
in lieu of the diode.
The wire from the alternator to the ALT out light then goes to a 1 amp
fuse/breaker on a bus.
Are you using the same fat wire from the starter contactor to the starter?
Consider using shotkey diodes everywhere. Low voltage drop.
You have the EIS (AFS 3400) fed through diodes from both the main bus
and the endurance bus. This will give you an inaccurate voltage
reading. The AFS3400 has dual power feeds pin 1 & 15. This would give
you voltage on the main bus & e-bus which could be nice to have.
Doesn't the AFS 3400 have internal diodes to prevent drain of its
internal battery?
Do you want to power the pinpoint MSU & GADAHRS from both the Avionics
and e-bus for some redundancy. It also has dual power inputs.
Are you adding a switch on the panel for the pinpoint GADAHRS compass
swing & alignment procedure (pin 16)?
Any switch to activate/deactivate the functions of the co pilot stick
grip (assuming some sort of grip with switches)
Trim on the ebus, I would assume that is pitch trim. How about roll
trim? Rudder trim?
Larry Rosen
#356
John Testement wrote:
| Quote: | I am pretty close to finalizing my electrical system and would really
John Testement
jwt(at)roadmapscoaching.com <mailto:jwt(at)roadmapscoaching.com>
40321
Richmond, VA
FWF, engine, wiring
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
Tim Olson
Posted: Sat Feb 10, 2007 5:08 pm Post subject: Electrical System Critique |
I have 2 very minor notes to add.
1: I'm finding my running load with landing lights is somewhere around
36A. (Not with flaps and trim moving). Just a data point.
2: As far as that pinpoint pin 16 switch, I would hide that switch
behind the panel. You'll never use it once you are done calibrating,
and I'm not only confused as to why some dealers think it should
be there, but I think it's a bad idea. If they insist on putting
it on the panel, insist on them not labeling it, so you can move it
somewhere else behind the panel....then stick a switch for something
else in that hole. I've not touched mine since it was calibrated.
Larry Rosen wrote:
John,
switch?
internal battery?
trim? Rudder trim?
Larry Rosen
#356
> John Testement
> 40321
> Richmond, VA
> FWF, engine, wiring
> do not archive
Posted: Sun Feb 11, 2007 6:36 pm Post subject: Electrical System Critique |
Thank you Tim, Larry, Jesse, and Carl for you inputs.
My guess is that there are a lot of us deliberating the numerous options and
trade offs on the electrical system. I would like to encourage us to get a
useful dialog going to sort through the pros and cons of the various
approaches.
Based on what I have learned, I have changed my approach considerably. I
have attached my new design as well as the old design (as a PDF for those
who could not open it before). Let's continue to critique the approach for
everyone's benefit.
Tim made some really good points about having independent power (not on the
cranking battery) to the Cheltons, Eng. Monitor and Elect. Ignition for
engine start. This caused me to drop the idea of having a 2nd battery
available for cranking and use the second battery for start-up avionics and
Ebus backup. The main changes I have made are:
I am going with one large main battery - Odyssey 925, 25AH; and a smaller
12AH auxiliary battery (much like Tim's).
During engine start I will run the Ebus (PFD, Eng Mon and E Ign) off of the
Aux battery while cranking from the main battery. After start, I will turn
off the Ebus alternate feed, turn on the Avionics switch, and run everything
off the main battery. I will run the E Ign. off the aux battery (everything
is really running off the alternator during flight anyway).
I have moved the pitot heat and the fuel boost pump to the main bus.
If the alternator fails I will switch to the Ebus alt feed, manually load
shed the main bus (most loads are on switches anyway). And if I need fuel
boost or pitot, I can turn the main bus back on. The only downside is if the
main battery fails I can only power the Ebus from the aux battery.
I took the contactor off the aux battery since the load is under 15A and a
contactor would draw 1A during an emergency. I don't have an Aux battery
switch (other than the Ebus alt feed switch) since I can't think of a need
for one. The Aux battery will be charged through a diode to the main bus and
the E. Ign is tied through a breaker.
I put the Eng. Monitor on the Ebus since it will be on during start up. I
will be using the AFS3400 which gives me full EFIS back up with its own
internal battery.
Some concerns and questions: I am running #8 from the alternator to the main
bus. The wire size chart (AC43.13) says a #8 wire is good for 70A at 10ft.
Others are using #6 to go from alternator to the main bus. Do I have a
problem?
Should I put the smaller aux battery under the flap tunnel or next to the
main battery for W&B? What is a good/light 12AH battery?
Is the Ebus diode really needed in this design?
Should the main battery be grounded locally as well as running to the
firewall?
Let me know what you think and contribute any ideas for the benefit of all
the others who are working through their designs.
John Testement
40321
Richmond, VA
FWF, engine, wiring
 Download |
| Filename: |
N311RV_Electical_System_v5.pdf |
104.67 KB |
| Downloaded: |
367 Time(s) |
 Download |
| Filename: |
N311RV_Electical_System_v4.pdf |
117.06 KB |
| Downloaded: |
418 Time(s) |
LarryRosen
Posted: Sun Feb 11, 2007 8:29 pm Post subject: Electrical System Critique |
Reply below
| Quote: | Thank you Tim, Larry, Jesse, and Carl for you inputs.
approaches.
I think I have considered every different type electrical design. It
went something like this: Dual alternator single battery, single
alternator dual battery, duel alternator duel battery, then back to a
dual alternator single battery design, which is where I am now. An now
with your comments I am considering a small battery just for start up.
My plan was to use the internal battery in the AFS-3400 to run the
engine monitor during start. All other avionics off.
| Quote: | Based on what I have learned, I have changed my approach considerably. I
everyone's benefit.
Shut off the master battery contactor?
| Quote: | manually load shed the main bus (most loads are on switches anyway).
And then turn on the master battery contactor to use the main battery
and the standby battery?
| Quote: | And if I need fuel
If you do lose the main battery, won't the alternator still supply
power, although in may not be a stable?
| Quote: | ...
problem?
I am using AC 43.13-1B Acceptable Methods, Techniques, and Practices -
Aircraft Inspection and Repair table 11-3 DC wire and circuit protector
chart. It recommends 8AWG up to 50 amp fuse or breaker and 6AWG for an
80amp breaker and 70amp fuse. But, I am sure the devil is in the
details. 11-49 says, "... This chart was prepared for the conditions
specified.... In general, the chart is conservative for all ordinary
aircraft electrical installations" However Table 11-9 Current carrying
capacity and resistance of copper wire. Figure 11-2 does say 8AWG wire
and 70 amps. Since the continuous load is not 60 amps I would think
8AWG is not a problem. That being said I am using 6AWG. I would like
to know more about the details.
| Quote: | Should I put the smaller aux battery under the flap tunnel or next to the
If you find one let me know
firewall?
I think this would give more problems with ground loops.
| Quote: | Let me know what you think and contribute any ideas for the benefit of all
John Testement
40321
Richmond, VA
FWF, engine, wiring
#40356
N205EN (reserved)
<http> |
Posted: Mon Feb 12, 2007 4:42 am Post subject: Electrical System Critique |
Responses below.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
john_rv10(at)yahoo.com Guest
Posted: Mon Feb 12, 2007 9:39 am Post subject: Electrical System Critique |
Hi John,
I am also struggling with this design and am probably two steps behind you.
I like the way you have laid yours out, combining physical location with the electrical diagram. This helps me conceptualise.
My own thoughts are not dissimilar to yours with a couple of variations. I am keen to bullet proof my electrical system so at a conceptual level what I am thinking is as follows:-
<![if !supportLists]>· <![endif]>Two batteries of equal size so you can change them out alternately and always have a relatively new battery for the avionics/endurance buss. Two 17AH batteries should suffice
<![if !supportLists]>· <![endif]>Run two fairly equal size busses, one with the main airframe electrics as you have done, the second with the critical to flight safety avionics etc. The critical to flight safety buss might be on two busses, an avionics buss and an endurance buss. To balance out the busses I am considering putting the engine monitor system on the main power buss because I want it for engine start and if I lose a circuit I figure I can live without this for the time it takes to sort out what has happened and what I need to do. If necessary, completing the rest of the flight without it is probably OK if not desirable. As pointed out, most items on the main buss are separately switched, so after things settle you can switch as desired to get back what you can afford to carry.
<![if !supportLists]>· <![endif]>Set the batteries up so you can choose to run either battery with either circuit. If both batteries are down the back, this creates a problem with added wire weight to my mind, because you need to run three 4AWG wires from the back if you plan to use both batteries to crank, and two 4AWG plus 1 2AWG if you plan to use one battery to crank. We live in Australia so we don’t get the freezing conditions where I plan to do most my flying, so I like the idea of using the older battery on the power circuit, using it to crank the engine on its own, and at the first sign of not doing that task well, change that battery out for a new one and rotate batteries. I recognize that this approach won’t suit all situations. I would like to put the main battery up the front so I can run very short wires from it to crank the engine, but I am not sure yet whether this is appropriate from a weight and balance perspective. I do like Jesse Saint’s logic from a weight and balance perspective with doing this.
<![if !supportLists]>· <![endif]>Install two alternators which are switched to run either/or, not both because of the complexity associated with trying to get both alternators working at the same time, plus I think it is better redundancy planning this way.
<![if !supportLists]>· <![endif]>Run one electronic and one mag ignition as you have done, so that in the absolute worse case scenario the engine keeps running on the mag.
<![if !supportLists]>· <![endif]>No vacuum system because of their weight and inherent unreliability.
<![if !supportLists]>· <![endif]>Run over voltage protection on both alternators because of the damage that can be done to everything without it.
That’s about where I am with my thinking at this stage and I am now ready to move to the more detailed planning phase.
Would you please post an ACAD version of your layout if you have one?
Thanks very much for kicking this thread off, it is very helpful.
John Cleary
(finishing wings, started fuse)
Posted: Sat Feb 17, 2007 7:40 am Post subject: Electrical System Critique |
John, Larry
I also liked the idea of 2 same size batteries (17ah) and an annual swap. The concern I ran into was if you use one for cranking and the other for the start-up avionics, I would have only half the cranking power that I would have had with the one 25ah battery. According to Tim, you want to start up your Cheltons as well as your engine monitor before cranking and you do not want to have these or the e. ignition on the cranking battery (will re-boot the Cheltons and this takes some time). If I tie the two 17ah batteries together for cranking then I have tied the avionics to the cranking batteries. This led me to having one larger cranking battery and one smaller battery for start-up avionics, e. ign., and essential bus backup. Is there an option I am missing here?
I dropped the idea of a second alternator after discussions with several people. The main reason is that if I have any electrical failure, I am going to land as soon as possible. I do not need a second alternator to take me to the end of my fuel endurance (might be a dangerous temptation to keep going). With 2 quality RG batteries I should get about 1 1/2 hours of backup (plus my AFS3400 internal battery - 1 hr.). This should easily get me to an airport or instrument approach if IFR. The other reason was the cost of the accessory pad back up alternator - about $1,000.
I don't want to sound like I am any kind of expert or know the right answer. So please challenge my thinking.
Couple of issues I am struggling over now:
1) Lightspeed suggest that you run a 18awg shielded power wire to a breaker and then all the way back to the battery. I am resisting this, thinking of running the shielded wire to the breaker, then the 2nd battery bus at the panel, I am not sure that I will not get ignition noise if I do this. What have others done and what has been your experience with ignition noise?
2) I can't decide if I should put a switch between the 2nd battery and the ebus alternate feed (see attached schematic).
3) Still looking for a good 12-17ah small/light 2nd battery.
Thanks for all the inputs
John Testement
40321
Richmond, VA
FWF, engine, wiring
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]
Hi John,
John Cleary
 Download |
| Filename: |
104.67 KB |
| Downloaded: |
374 Time(s) |
GenGrumpy(at)aol.com Guest
Posted: Sat Feb 17, 2007 7:49 pm Post subject: Electrical System Critique |
For what it's worth.
My 2 batteries automatically come together when cranking, wired it that way so that the start position of the ignition uses both (Avionics systems did this in the panel).
Lightspeed? You need to run the hot wire through either a fuse or breaker and tie it directly to the battery. Don't tie it to a bus relay that can fail on you.
As an example, during flight test I lost an entire bus unexpectedly.
Troubleshooting found that the battery switch wire to the solenoid pulled out of the terminal, so the solenoid lost its ground, and the bus went dead.
I wouldn't want my Lightspeed to go dead because of that.
And Klaus says that if you shut the battery solenoid off, and the battery goes down to 4-5 volts, the light speed will still work!!
So........don't wire your lightspeed into a battery bus controlled by a battery solenoid!!
Grumpy
In a message dated 2/17/2007 9:42:33 AM Central Standard Time, jwt(at)roadmapscoaching.com writes:
| Quote: | John, Larry
John Testement
40321
Richmond, VA
FWF, engine, wiring
Scott Keadle
Joined: 10 Jan 2006 Posts: 31 Location: Lake Norman, North Carolina
Posted: Sun Feb 18, 2007 6:01 am Post subject: Re: Electrical System Critique |
All,
I have my panel completed from SteinAir, and was planning on running two alternators, because I didn't think that it was possible to charge two batteries simultaneously with one alternator. Is this correct? If not, then I think I could just charge both with one 60amp alternator. Honestly, I could ask Stein, but I'm too embarrassed to aggravate him any further with a question that I probably already asked him several months ago!
I am running two seperate busses, each of which is capable of operating the airplane in IFR conditions indefinitely. My thought was that if I were going to count on a "backup" system, then I should be constantly monitoring that system for operational readiness, lest I turn to the "backup" and find that it doesn't work when I really need it (this seems common in the typical small business computer backup, for instance).
I am also running dual Lightspeed ignitions, and will run separate physical routing of each wire directly to the battery, in case of a master-solenoid failure, which is actually not that uncommon and pretty much unpreventable. The seperate physical routing is in case of something weird happening to the wire bundle (fire, big toe, AAA from spamcan ground defenses, etc.).
I too, am just now realizing the starter/avionics clash for battery power, and trying to decide how to handle the situation. It may be as simple as starting on the "backup" bus, which doesn't have the Chelton's on it, and using a "cranking" style battery on that bus. I would appreciate any suggestions.
I have a wiring diagram that I would be happy to share if anyone cared to see it, but it is a hard copy produced by SteinAir, and I'm not quite sure I know how to get it onto the computer. I am copying this message to Stein, so maybe he has a digital copy that he can send to the list.
Scott
[quote="GenGrumpy(at)aol.com"]For what it's worth.
Grumpy
I dropped the idea of a second alternator after discussions with several people. The main reason is that if I have any electrical failure, I am going to land as soon as possible. I do not need a second alternator to take me? to the end of my fuel endurance (might be a dangerous temptation to keep going). With 2 quality RG batteries I should get about 1 1/2 hours of backup (plus my AFS3400 internal battery - 1 hr.). This should easily get me to an airport or instrument approach if IFR. The other reason was the cost of the accessory pad back up alternator - about $1,000.
John Testement
40321
Richmond, VA
FWF, engine, wiring
_________________ Scott Keadle
14A, Lake Norman Airpark
N426AK RV-10, final assembly
N246SK, Giles 202, flying |
Posted: Sun Feb 18, 2007 7:49 am Post subject: Electrical System Critique |
Grumpy,
Would you run the shielded wire all the way to the back of the plane to the battery or just to a battery buss (non-contactor) at the panel?
John Testement
40321
Richmond, VA
FWF, engine, wiring
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of GenGrumpy(at)aol.com
Sent: Saturday, February 17, 2007 10:48 PM
Subject: Re: RV10-List: Electrical System Critique
Grumpy
John Testement
40321
Richmond, VA
FWF, engine, wiring
| -- No virus found in this Edition.
2/17/2007
Posted: Sun Feb 18, 2007 8:05 am Post subject: Electrical System Critique |
Scott - and others,
Based on all of great inputs on and off line I am now leaning back towards
the 2 PC680 17ah battery scheme. I will allow the 2nd battery to
independently run avionics during start up. I would provide the option to
tie the 2nd battery to the main battery through a contactor if in a cold
situation the main battery cannot start the engine.
Once started I can also tie the 2nd battery to the main bus to let it
charge. If the 1st battery fails and I need main bus items I can power the
main bus from the second battery.
Unless I am overlooking something (which I usually do), this seems like the
best of all worlds - independent avionics on start, annual rotation of
batteries, minimal weight impact, longer ebus backup time.
Please give me your reactions - diagram attached.
John Testement
40321
Richmond, VA
FWF, engine, wiring
 Download |
| Filename: |
N311RV_Electrical_System_v6.pdf |
148.02 KB |
| Downloaded: |
434 Time(s) |
