mclayton(at)rochester.rr. Guest
Posted: Sat Feb 03, 2007 5:26 pm Post subject: Landing Gear for Kitfox II |
I am rebuilding a badly damaged KitFox II, S/N 89. One of the
problems is that the right landing gear was partially rebuilt, and is
not the same as the left landing gear, which was undamaged. I would
like to avoid building a jig to make a new gear, and wondered if
anyone had a gear available, and in good condition. I don't need the
tire, wheel, or brakes. Alternatively, does anyone have a drawing,
sketch, or the necessary dimensions to allow me to make a new one?
dave
Posted: Sat Feb 03, 2007 6:09 pm Post subject: Landing Gear for Kitfox II |
Mike,
First I would contact John Mc Bean as he might be able to make you one.
secondly if that fails I will get you some measurements possibly from
blueprints I have for a Kitfox 1 clone.
thirdly I can build you one if it the same. I have most jigs for the KF 1
Clone .
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
aldaniels(at)fmtcblue.com Guest
Posted: Sat Feb 03, 2007 9:44 pm Post subject: Landing Gear for Kitfox II |
I have a like new set of tube gear for a Model 2 in my hangar which you
can have for very reasonable and shipping. Contact me off list for details.
Alan Daniels
Mike wrote:
Posted: Sat Feb 03, 2007 9:48 pm Post subject: Landing Gear for Kitfox II |
Correction they might be for a model 3. I don't know if it will fit. I
can measure them up to see if they will work.
Alan
Mike wrote:
Posted: Sun Feb 04, 2007 7:12 am Post subject: Landing Gear for Kitfox II |
Alan,
Thanks for the response.
I would be interested in the gear, if it will fit. If you can send
me some dimensions, and a picture, I can figure out whether they will
work. Also, I have some indication that the KF# gear has a wider
track, which would contribute to stability. If I need to make some
changes to the fuselage to fit the gear, or relatively modest changes
to the gear, I can do so. I am replacing a lot of the tube structure
in that part of the fuselage anyway. (Actually, my friend who is an
A&P, and a certified PV welder will do the work).
On Feb 4, 2007, at 12:47 AM, Alan Daniels wrote:
<aldaniels(at)fmtcblue.com>
fit. I can measure them up to see if they will work.
Alan
> is not the same as the left landing gear, which was undamaged. I
> would like to avoid building a jig to make a new gear, and
> wondered if anyone had a gear available, and in good condition. I
> don't need the tire, wheel, or brakes. Alternatively, does anyone
> have a drawing, sketch, or the necessary dimensions to allow me to
> make a new one?
> Mike
