epoxys
Goto page 1, 2  Next
kitfox555(at)sbcglobal.ne
PostPosted: Sat Feb 03, 2007 10:30 am    Post subject: epoxys Reply with quote
What is the filler that you mix with the system three t-88 structural adhesive to hold in vertical places not to sag while curing?
Jerry Evans
kitfox 555 [quote][b]
Beemer
PostPosted: Sat Feb 03, 2007 10:59 am    Post subject: epoxys Reply with quote
Can you use baby/talcum powder? Cheap and easy. All you need to do is thicken the mixture.
DO NOT use micro-balloons. While they do the job perfectly, you cannot breathe them in. Huge lung problems.
Bradley
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of jerry evans
Sent: Saturday, February 03, 2007 1:30 PM
Subject: epoxys
Jerry Evans
kitfox 555
Beemer
KF2 (and now an M3!)
Suzuki G10 three-banger
Middle Georgia
aldaniels(at)fmtcblue.com
PostPosted: Sat Feb 03, 2007 11:06 am    Post subject: epoxys Reply with quote
micro or flox depending on what you are doing. Micro is light and easy
to work with but not as strong, flox adds strength but sands like concrete.
Jerry Evans
kitfox 555
Guy Buchanan
PostPosted: Sat Feb 03, 2007 11:54 am    Post subject: epoxys Reply with quote
Depends on what you're doing. First, Bradley's right, wear a good
mask when using any of these as none of them are great for your lungs
or nasal passages.
1. Microballoons. (Ceramic, glass, Q-cel, phenolic) Decreases
compression strength a little and tensile and shear strength a lot.
Medium-easy to sand. They make a putty but do NOT increase the
viscosity, meaning that your fillet still sags, it just happens
slower than pure resin. These are mainly used to extend resin, though
a lot of people use them to make fairing putties. I don't recommend the latter.
2. Chopped glass / carbon / boron. Increases compression strength a
little and tensile and shear strength a lot. Hard to sand. Does not
increase viscosity. (See above.) Note that these fibers are fairly
long, on the order of inches.
3. Milled fiber. Same as chopped but much shorter fibers for a more
putty like consistency. Used for structural fillets.
4. Cotton Flock. Increases tensile and shear strength a little. Also
increases viscosity, making a fillet that stays in place. Hard to sand.
5. Colloidal Silica or Cab-0-Sil. These increase viscosity, making a
putty that stays in place. I'm not sure about their strength
properties. They're also sandable.
6. Talc. Used to make a cheap sanding filler. Non-structural.
7. West System's 409 Micro-Lite. This is the best sandable putty I've
ever used. It was used extensively in the America's Cup before they
went to female molds for the boats. Non-structural
There's zillions more associated with non-skid, fire retardance, UV
protection, etc.
Guy Buchanan
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
lcfitt(at)sbcglobal.net
PostPosted: Sat Feb 03, 2007 3:49 pm    Post subject: epoxys Reply with quote
Hi, Bradley,
In the Lancari project I have been helping with we have used a "ton" of
mircroballoons. I have been monitering the Lancari list for two years and
this if the first time I have read "NO NOT" with regard to microballoons. I
spent some time on Google trying to find a MSDS on microballoons wothout
success. Can you elaberate on it's hazards and maybe stear me to a MSDS.
Lowell
flier(at)sbcglobal.net
PostPosted: Sat Feb 03, 2007 4:23 pm    Post subject: epoxys Reply with quote
Use cotton flox to thicken structural adhesive.
Float Flyr
PostPosted: Sat Feb 03, 2007 4:47 pm    Post subject: epoxys Reply with quote
The only place I used a filler in epoxy was on my boat. What I found is
filling with silicon made a much harder finish. Sanding was much harder
than the micro balloons but it can be applied so very little sanding was
necessary.
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Beemer
PostPosted: Sat Feb 03, 2007 5:00 pm    Post subject: epoxys Reply with quote
I'll have to do some searching. A few years ago, the subject came up in the
RC model world, as microballoons are very popular in that hobby. At the
moment, I can't back that up with paper, but I do remember that the result
of that discussion was that the small glass beads are like breathing diamond
dust, and really chews up the lining in the lungs, a similar thing to what
happened to miners years back with no protection.
I'll see if I can find anything.
Bradley
Beemer
Middle Georgia
Michel
PostPosted: Sun Feb 04, 2007 1:24 am    Post subject: epoxys Reply with quote
Bradley has a point about microballoons being a potential health
hazard if inhaled, Lowell. But how much of a hazard?
As an illustrator, before the age of the digital art, I used often
glassfiber erasers when inking. I was told to be very careful with the
dust it made. Then, in the yachting industry (as I designed sailboats,
I had to experience the making of them) there was a lot of GRP hulls
that had to be trimmed, etc. and a lot of polyester and glassfiber dust
in the air, in those places. Some wore masks, some didn't.
But glass is silicate and I read that the lungs of Egyptian mummies are
not very pretty to look at; A lot of soot from indoor cooking, and a
lot of silicate from the desert sand.
So, I think we should be careful with microballoons and all kind of
silicate dust. But we don't need to be hysterical, it is not like
asbestos.
Michel
Kitfox 3 - Jabiru 2200
Guy Buchanan
PostPosted: Sun Feb 04, 2007 7:27 am    Post subject: epoxys Reply with quote
I treat anything inorganic and small as a hazard, even if there's no
notice. My weak understanding is that silicosis results from inhaled
inorganic matter that's so small it can make it all the way to the
alveoli where it is encapsulated by the lungs, thereby blocking off
that region. It can't be expelled because it's beyond the "pipes", in
an area where you can't generate enough velocity to expel it. (That's
what normally happens with "larger" particles.) Some organic matter
can be absorbed by the lungs.
Anything inorganic small enough to "float" in the air I treat as a
hazard. I don't think microballoons will actually float, but the
problem is that in a typical batch of microballoons a significant
fraction are broken. It's the "pieces" I worry about, and I don't
know that I could see them if they were floating. (If you buy Q-cell,
the percentage of broken balloons is certified to be very low.)
I hope someone can come up with definitive information, but in my
case I'll stay on the side of caution.
Guy Buchanan
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
PostPosted: Sun Feb 04, 2007 7:59 am    Post subject: epoxys Reply with quote
Thanks Michel,
I just get troubled with statements out of the blue like "don't use .... I
would think if the hazard was strong enough for a statement like that there
would be some research out there - sort of like MEK and cancer. A scary
urban legend, but not based on any research I have been able to find
including the MSDS.
Sometimes I get the idea poeple wish we could all stay in bed in filtered
air eating organic food with little taste and somehow find life enjoyable
and fulfilling. I guess if a guy saw this stuff at work everyday for thirty
five years, it might prove a problem but the occasional use while in the
building process...?
Another search did find the MSDS on a produce called Syl Cell Microballoons
and others. See link below.
I have experienced the acute affects to a slight degree. The trick to
mixing is to proportion the resin in a cup, add the micro and then simply
walk forward around the work area while mixing you will be moving into an
area of clean air as you mix. No problem. I do use a mask while sanding.
http://www.eagerplastics.com/silcelmsds.htm
http://www.fiberglasssupply.com/pdf/msds/3MGlassBubbles.pdf
http://msds.ogden.disa.mil/msds/owa/web_msds.display?imsdsnr=191069
Lowell
rjdaugh
PostPosted: Sun Feb 04, 2007 9:26 am    Post subject: epoxys Reply with quote
You should also put a small amount of microballoons in the adhesive when you
are gluing two dissimilar metals together to prevent the actual contact of
the two metals and thus prevent galvanic corrosion.
Thanks for the MSDS Lowell. It doesn't sound like they are very bad.
Randy
Randy
Kitfox 5/7 912S
Black Hills, South Dakota
Michel
PostPosted: Sun Feb 04, 2007 10:28 am    Post subject: epoxys Reply with quote
filtered air eating organic food with little taste and somehow find
life enjoyable and fulfilling.
Good Lord, don't stay in bed, Lowell; most accidents happen at home,
didn't you know that? A much safer place to be is ... in a Kitfox! Smile
Michel
PS: Went flying both yesterday and today. Lovely winter flying!
Float Flyr
PostPosted: Sun Feb 04, 2007 4:23 pm    Post subject: epoxys Reply with quote
The glass fabric is to an extent dangerous to good health. The epoxy resins
are supposed to be quite toxic. Common horse sense says to wear a good
respirator... Preferably one withy a remote air supply.
So much for theory.
I use a respirator with the canisters on the front. When at home I use a
similar respirator but I also try to sand outdoors with my back to the
breeze. BTW when god created respirators he made them totally
uncomfortable.... I hate wearing one but I wouldn't be without it.
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
dan(at)azshowersolutions.
PostPosted: Sun Feb 04, 2007 5:06 pm    Post subject: epoxys Reply with quote
The best respirator I have found lies in an Israeli M-15 gas mask. You can find good deals on them and the filters on E-Bay. They are full face, comfortable, and they have a generous field of vision. I can also attach a fresh air hose to the canister area as it came with an adaptor. Just a thought.
My 2 cents on wearing protection...when in doubt...do it.
Dan,
KF-IV Building
Mesa, AZ
Noel Loveys <noelloveys(at)yahoo.ca> wrote:
[quote]--> Kitfox-List message posted by: "Noel Loveys"
So much for theory.
Noel
[quote] --
 Filesize:  29.24 KB
 Viewed:  588 Time(s)
 Filesize:  71.64 KB
 Viewed:  622 Time(s)
Guy Buchanan
PostPosted: Sun Feb 04, 2007 9:39 pm    Post subject: epoxys Reply with quote
When I bought one for painting I splurged and bought the best
canister unit I could find with the best filters. It turned out to be
surprisingly comfortable, so much so that I pretty much forget it's
on if I really get into the task. It's nice, because I can then wear
it from the time I pull the paint until after I'm done cleaning up.
The filtration is so good there's absolutely no trace of odor, even
when painting lacquer.
Guy Buchanan
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
jlfernan
PostPosted: Sun Aug 03, 2008 5:26 pm    Post subject: Re: epoxys Reply with quote
I've got a new Supersport kit and included with the kit was two part Hysol. How much flox is used when the ratio of the Hysol is 1:1?
Jorge Fernandez
Supersport
Fuselage/Forward Controls
http://websites.expercraft.com/jlfernan/
PostPosted: Sun Aug 03, 2008 6:39 pm    Post subject: epoxys Reply with quote
Jorge,
When I built, in the old days of the 3M structural adhesive, the flox was
added to the point where the adhesive would no longer sag after placement..
This adhesive was used in assembling the wing ribs to wing spars as well as
in other non structural applications. If there are other instructions
unique to Hysol, others will respond.
Lowell
pwmac(at)sisna.com
PostPosted: Sun Aug 03, 2008 8:20 pm    Post subject: epoxys Reply with quote
Back when we were using the West epoxy system the stuff came with
detailed instructions which said add the flox or other filler until
you arrive at the consistency of peanut butter and could spread it on
with a pop stick. Thicker is better for vertical surfaces to keep the
epoxy from flowing. Chopped Fiberglas or strands of Fiberglas are
used for stronger final product. Glass beads and ground up powder
are also used just to make the stuff thick like flox.
I bet you could get on line and get Hysols detailed instructions for
their product.
Paul
>Jorge Fernandez
>Supersport
>Waiting on delivery
icubob(at)newnorth.net
PostPosted: Mon Aug 04, 2008 4:04 am    Post subject: epoxys Reply with quote
as i understand it glass beads are not just like flox. beads are used to
stiffen the mix , say to use as filler, but they weaken the mix and should
not be used in a structural application. bob noffs
Goto page 1, 2  Next
Page 1 of 2
