JimmieBlackwell(at)austin Guest
Posted: Fri Feb 02, 2007 7:35 pm Post subject: High Voltage Indication |
With engine running I normally see about 14 volts indicated on the panel meter and pulsating slightly if the strobes are on. While flying today I noted that the voltage pegged high for awhile and then settled back down to normal. A few minutes later the volt meter again pegged high, (above 16 volts). At that point I turned off the alternator circuit and the meter immediately dropped down and showed a steady 13-14 volts. Turning the alternator on again the volt meter pegged high again, but after awhile settled down to normal.
Would appreciate any ideas on what may be causing this indication.
Jimmie
Model IV Speedster, 912 UL
kitfox(at)ida.net Guest
Posted: Fri Feb 02, 2007 8:42 pm Post subject: High Voltage Indication |
Internal regulator on the alternator??? They can weld shut on some units when they are overloaded.
ALbert
smokey_bear_40220(at)yaho Guest
Posted: Sat Feb 03, 2007 3:18 am Post subject: High Voltage Indication |
"Welded" points in the regulator, as has already been
mentioned, is the likely cause. These points will
develope pits on one side and built up points on the
other. Gently prying the points open will show if
that is true. Filing them level will temporarily fix
it until replaced, but they will wear faster when
filed. If you find the points are the problem,
replace ASAP. Some things donīt like the high voltage
spikes.
Kurt S. S-5
--- Jimmie Blackwell <JimmieBlackwell(at)austin.rr.com>
wrote:
| Quote: | With engine running I normally see about 14 volts
this indication.
Jimmie
Finding fabulous fares is fun.
Let Yahoo! FareChase search your favorite travel sites to find flight and hotel bargains.
http://farechase.yahoo.com/promo-generic-14795097
Posted: Sat Feb 03, 2007 4:23 am Post subject: High Voltage Indication |
Albert/Kurt
Sounds like a likely source.
Thank you.
Fox5flyer Guest
Posted: Sat Feb 03, 2007 4:50 am Post subject: High Voltage Indication |
Sounds to me like the voltage regulator.
Deke
Joined: 24 Oct 2006 Posts: 89 Location: Damascus, Maryland, USA
Posted: Sat Feb 03, 2007 4:57 am Post subject: Re: High Voltage Indication |
Good suggestions, but the first and easiest step is to check and clean each of the the alternator and battery connections. If a bit loose or corroded, the regulator may sense lower voltage (V=IR, with increased R) and try to make up for it.
_________________ Remember that internet advice may only be worth what you pay. |
dave
Posted: Sat Feb 03, 2007 5:27 am Post subject: High Voltage Indication |
912 info overvoltage info you you guys,
Dave
Figure Z-16. Rotax 912/914 System is a "stone simple"
electrical system typical of many aircraft fitted with
permanent magnet alternators. A noteworthy feature in this
figure is the means by which I've added OV protection to the
alternator system. Many airplanes flying with a Rotax 912
have relatively small batteries. Even the limited 18 amps of
alternator output can push the bus voltage up rather quickly
on a small battery. Adding the relay and OV module as
shown provides automatic protection from unobserved
regulator failure.
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
dave
Glenn Horne
Posted: Sat Feb 03, 2007 5:57 am Post subject: High Voltage Indication |
Had the same problem with my Key West regulator and it blew off the firewall.
Called Key West manufacture and they have had problem with the older models
regulators. The compactor inside is suppose to be vented to the atmosphere.
If yours is a Key West give them a call and they will re-place it free.
Glenn Horne
Model II 582 ----- Original Message -----
[quote] From: Jimmie Blackwell (JimmieBlackwell(at)austin.rr.com)
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
Sent: Friday, February 02, 2007 10:32 PM
Subject: High Voltage Indication
Jimmie
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
| [b]
kerrjohna(at)comcast.net Guest
Posted: Sat Feb 03, 2007 6:34 am Post subject: High Voltage Indication |
voltage regulator going, going, gone south....
It happened to me over the backwoods of Idaho. I coaxed it back to civilization and ordered a replacement from Lockwood.
John Kerr
[quote]-------------- Original message --------------
From: "Jimmie Blackwell" <JimmieBlackwell(at)austin.rr.com>
Jimmie
lcfitt(at)sbcglobal.net Guest
Posted: Sat Feb 03, 2007 8:01 am Post subject: High Voltage Indication |
Sorry, no joy here, the 912 has a generator and no points in the regualtor.
Lowell
Posted: Sat Feb 03, 2007 9:14 am Post subject: High Voltage Indication |
Thanks lowell,
The old points systems were not as reliable, but you
could temp fix them with a fingernail file until you
got home. Something gained, something lost.
If not a bad connection as Rob says, a change is
required. Hopefully the free replacement mentioned
for the bad capacitor???
Kurt S.
--- Lowell Fitt <lcfitt(at)sbcglobal.net> wrote:
| Quote: | Sorry, no joy here, the 912 has a generator and no
Lowell
Don't pick lemons.
See all the new 2007 cars at Yahoo! Autos.
http://autos.yahoo.com/new_cars.html
torgemor(at)online.no Guest
Posted: Sat Feb 03, 2007 3:28 pm Post subject: High Voltage Indication |
Hi Jimmie,
Interesting, this one.
As many already said, this system is a "permanent magnet generator"
system, well -if you do not have the "optional alternator system" with
this fault..
Anyhow, this is the charging system that's found in all of the Rotax
engines, even the smallest of them..
The (big?) benefit of this system -over the standard alternator setup is
this(I'll belive); this system do not need any excitation voltage to come
alive. So, if your battery is completely dead and you manage to start your
engine, this system start to deliver power anytime the engine is running.
Yes, -as all the others out there I'll agree this might be the
rectifier-regulator that's fails "now and then".
But, don't throw away your old regulator yet, -cause I do believe there is
a spare circuit inside this box! Why you might ask, well remember this
unit is born as a three phase unit -and most probably contain one more SCR
(silicone controlled rectifier) unit that's working OK.
Now remember this regulator contain three yellow input wires, and one of
them is never in use, so you'll have two more combination to try -and one
of them probably give you a new regulator..
This depend a little if there is one zener for each phase, or if it just
one zener for all three phases -then bad luck, if it is the zener that's
the problem, bad luck.
Over the yrs. most of the problems like this is due to a faulty zener
(diode), but sometimes other parts fails. So, make a try!
Just something general about this system; This regulator shunt the
alternator if the voltage arise above the preset voltage (close to 14
volt), then the SCR short all the way until the current cross the "zero"
line, then it's ready for a new shot (half period). So you see, this
system work with full load all the time, even when your battery is fully
charged or all empty.
Here's a link to tympanium corp., the producer of those regulators:
I'll think the design tip is worth reading.
http://www.tympanium.com/index.html
Here's another one, a complete schematic, for those who want to build your
own one -go for diodes and SCR's handling 40 Amp's and this never fails,
, experimental -yes :
http://www.takisnet.org/~abayko/vreg.pdf
You know, I've often heard lot's of good thing about Key West rectifier
regulator, but folks where can we find some more facts about this
regulator, -as is this a serial regulator (?), or is this just another
shunt rectifier-regulator?
Why do I ask like this, well - (see my next posting).
Keep up the good work, and good luck.
Torgeir.
On Sat, 03 Feb 2007 04:32:40 +0100, Jimmie Blackwell
<JimmieBlackwell(at)austin.rr.com> wrote:
| Quote: | With engine running I normally see about 14 volts indicated on the panel
Jimmie
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
