Nick(at)Scholtes1.com Guest
Posted: Thu Feb 01, 2007 8:37 am Post subject: Speedster Electric Trim Wire Routing |
Hey Listers!
I bought a Model IV Speedster recently. It was designed to have
electric trim, so darn-it, I want it to have electric trim! The seller
(also the builder) told me:
"The servo is installed and the wire goes from here (up under the panel)
back to the servo. I just never connected the switches and the
indicator." Ok, I can connect the wires under the panel, no problem.
Well, last night I opened up the "hatch" in the elevator to take a look
at the servo. Sure enough, it's in there. Then I noticed the wires
that come out of the servo are bundled into a neat package and stuffed
to the side. They're not connected to anything. The wire that is under
the panel heads aft and dissapears somewhere in the back of the
fuselage, never to be seen or heard from again! It never comes out.
So, my question:
-- How do I route the wire out of the back of the fuselage and into the
elevator to connect to the servo, especially now that the elevator has
been covered and the wire wasn't installed prior to covering?
Recovering the elevator would be SO unappealing!
-- How is the wire normally routed?
Any suggestions?
Thanks!
Nick
starlaker
Posted: Thu Feb 01, 2007 9:24 am Post subject: Speedster Electric Trim Wire Routing |
Nick Scholtes wrote:
Hey Listers!
seller (also the builder) told me:
panel) back to the servo. I just never connected the switches and the
look at the servo. Sure enough, it's in there. Then I noticed the
wires that come out of the servo are bundled into a neat package and
stuffed to the side. They're not connected to anything. The wire
that is under the panel heads aft and dissapears somewhere in the back
of the fuselage, never to be seen or heard from again! It never comes
out.
So, my question:
the elevator to connect to the servo, especially now that the elevator
has been covered and the wire wasn't installed prior to covering?
Any suggestions?
Thanks!
Nick
Nick,
Have you removed the cover around the horizontal stabilizer to see if
the wire from the panel is visible there? Mine exits at the rear of
the horizontal stab and enters the elevator on the top front corner.
Dick
_________________ Dick D'Archangel
Classic 4 6061D |
Fox5flyer Guest
Recovering a small portion of the underside of the elevator is not really a
big deal. If it's painted with Polytone the patch can easily be made
invisible. I doubt there is any other effective way to do it other than
some sort of surface mount.
Deke
Guy Buchanan
Posted: Thu Feb 01, 2007 11:01 am Post subject: Speedster Electric Trim Wire Routing |
At 08:36 AM 2/1/2007, you wrote:
| Quote: | How do I route the wire out of the back of the fuselage and into the
I recently routed a manual trim cable without re-covering so this
should be easy.
1. Locate an exit point near the inboard end of the elevator. Be
careful because there are steel reinforcements in this area so the
exit may not be in as ideal a location as you'd like.
2. Melt a hole in the cover with a soldering pen.
3. Bend a small loop in the end of a piece of coat hanger.
4. Gently feed the coat hangar from the new exit hole toward the
servo. Try to pass "below" the elevator longerons; that way any bumps
caused by the wire feeding over the longeron will be less noticeable.
5. Attach the end of the wire to the loop and very carefully pull it back out.
6. Tie-wrap the wire to the elevator cross tube and feed it forward
below the elevator to meet the wire coming aft.
Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
Float Flyr
Michel
Posted: Fri Feb 02, 2007 10:49 am Post subject: Speedster Electric Trim Wire Routing |
On Feb 1, 2007, at 8:00 PM, Guy Buchanan wrote:
| Quote: | I recently routed a manual trim cable without re-covering so this
should be easy.
Guy, like most of us, I keep some email from this list for later
reference, in a special folder. While I am not specially interested in
the electric trim of a Speedster (I have a model 3 without trim), I
would like to take the occasion to salute you, and the nice way you
document your work and explain it to the benefit of everyone. Together
with e.g. Lowell, Torgeir (and many others, I can't write them all) you
make this place worth the reading and archiving of good stuff that
makes our flying a safer and enjoyable experience.
Thank you, Sir! Keep up the good job (and everyone else)
Michel
Guy Buchanan
Posted: Fri Feb 02, 2007 10:17 pm Post subject: Speedster Electric Trim Wire Routing |
At 10:49 AM 2/2/2007, you wrote:
| Quote: | I would like to take the occasion to salute you, and the nice way
you document your work and explain it to the benefit of everyone.
Thank you. :-[ And to think I un-subscribed last month because the
signal / noise was just too low to justify the effort. I
re-subscribed after a couple of days cooling.
Guy Buchanan
Deceased K-IV 1200
