Vern(at)teclabsinc.com Guest
Posted: Fri Feb 02, 2007 8:01 am Post subject: Firewalls and proseal |
Just an FYI: Chapters 27 and 28 mentions using “proseal” to seal the firewall seams. The plans offer no further explanation than this. Proseal is proseal right? No. My Tech. counselor pointed out this is high temperature sealant not the stuff used on the fuel tanks.
So just for fun I put a propane torch on a small sample of cured proseal left over from the fuel tanks. This stuff burns almost as well as marshmallows! The fact the can says Flamemaster (Company name) doesn’t help clarify things either. I know it’s probably ‘in the archives.’ But unless it was pointed out I would have not known there was a difference. Hope this save someone some grief. Good news it was caught before I used the wrong sealantJ
Vern Smith (#324)
jjessen
Posted: Fri Feb 02, 2007 9:31 am Post subject: Firewalls and proseal |
I just want to make sure I know what product you set the torch to. Was it Proseal, or was it the Flamemaster stuff that Van's sells for prosealing things like trailing edges.
John Jessen
#328
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Vern W. Smith
Sent: Friday, February 02, 2007 8:00 AM
Subject: Firewalls and proseal
Vern Smith (#324)
Posted: Fri Feb 02, 2007 11:12 am Post subject: Firewalls and proseal |
Good catch. Van’s sells two products and both are made by Firemaster. The one I put the torch to is the Fuel Tank Sealant (part# MC-236-B2 quart size.) The other product CS1900 Firewall Sealant is the high temp product.
Vern Smith (#324 fuselage)
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Jessen
Sent: Friday, February 02, 2007 9:30 AM
Subject: RE: Firewalls and proseal
John Jessen
#328
Vern Smith (#324) | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com">http://forums.matronics.com | 0123456789
