Tim Olson
Posted: Fri Feb 02, 2007 4:47 am Post subject: Interesting panel-mount handheld GPS comment |
I saw this in today's AOPA newsletter:
FAA MAY TAKE AWAY PANEL-MOUNT OPTION FOR PORTABLE GPS
Think your portable GPS would work great mounted to your old Cessna
172's instrument panel? If the FAA has its way, you won't be able to
mount it.
The parts--panel dock and connective wiring--needed to mount your
portable GPS would either no longer be available or be too expensive to
buy. The FAA's proposal would make it illegal for manufacturers to
produce a replacement or modification part if they know (or should
know) the part would end up installed in a certified aircraft--that is
unless they obtain production approval from the agency. But that costs
tens of thousands of dollars, something many companies can't afford.
While AOPA agrees production approval is necessary for critical parts
like connecting rods and cylinders, it isn't needed for non-critical
parts like a portable GPS panel dock or traffic detector that enhance
pilot safety.
See AOPA Online
http://www.aopa.org/whatsnew/newsitems/2007/070201parts.html ).
To me, this would seem like pretty much a direct attack on Air gizmos
for the Garmin handheld docking stations. I know the 396/496 get
awfully tempting to substitute in for a certified box. They must
be seeing some 337's (or worse....NOT seeing 337's) coming in on
putting those in certified planes. They're great boxes, but apparently
the FAA has their opinion of what they want to see.
Never thought I'd read that when I woke up today.
GRANSCOTT(at)AOL.COM Guest
Posted: Fri Feb 02, 2007 5:19 am Post subject: Interesting panel-mount handheld GPS comment |
Tim posted...
From what I see, the LSA folks are creating or mounting portable devices in their panels. I'm not an expert on FAR regs...now CIR's but isn't there an item somewhere about permanent mounted devices needing FAA approval...I think the FAA may have been a little lax in recent years on the LSA crowd since most of them are approved oversea's and with the conventions they must accept what other countries have approved unless safety is compromised.
This may be a statement from them (FAA) laying a line in the sand on production products...probably will not affect experimental's, though.
P
rvbuilder(at)sausen.net Guest
Posted: Fri Feb 02, 2007 5:46 am Post subject: Interesting panel-mount handheld GPS comment |
I read that too. I wonder if there really are that many of the docks
being put in the certified aircraft. I always assumed they were
targeting the experimental and other markets. It sucks but at least
they aren't saying that you can't use them period.
You can always go with some of the old external mounting options. I
have a suction cup gooseneck mount that I would use to mount my 196 in
rentals that worked quite well. I also put a little puck mount in both
of my vehicles and I can move it between them quickly.
Michael
Tim Olson
Posted: Fri Feb 02, 2007 6:25 am Post subject: Interesting panel-mount handheld GPS comment |
Ahh, you're probably right...it's probably due to the new
LSA's being developed like that as production planes.
I do agree that this isn't likely to affect experimentals
much, but it does show their philosophical direction, so for
a hardcore IFR plane, consideration as to what you put in
should be thought out carefully.
GRANSCOTT(at)aol.com wrote:
| Quote: | Tim posted...
tadsargent(at)bellsouth.n Guest
Posted: Fri Feb 02, 2007 7:03 am Post subject: Interesting panel-mount handheld GPS comment |
I believe experimental means just that. I could put a TRS80 personal
computer in the panel if I wanted to use it for navigation or Comm. I think
we have much latitude in this respect. Mounting a GPS on an experimental
requires no FAA sign off unless you are making major changes to the AC.
Just a thought.
Tad Sargent
7A and helping build a 10A
apilot2(at)gmail.com Guest
Posted: Fri Feb 02, 2007 7:09 am Post subject: Interesting panel-mount handheld GPS comment |
Let me take you through the logic of the regs as I understand
them..not that any FAA inspector would agree. Primary reference is
Appendix A of FAR 43.
The Airgizmo mount could be considered a cover plate for a blank space
in a radio rack...clearly a minor modification. Portable devices
connected by temporary, quick disconnects, such as cigar lighter
socket are clearly NOT installed devices, and are for pilot and
passenger amusement and not legal for use in navigation.(that might be
debatable for a portable navcom with VOR that meets the VOR check
rule.
Connecting wiring to said quick disconnect with proper fusing and
aircraft quality wiring may be considered a minor mod, although some
will argue that it could be major, depending on potential implications
to overall electrical system.
Assemble all that together, and plug in a portable GPS, and you have
1. a minor modification, 2. a controversy.
KM
A&P/IA
PS: I'll be real interested to see how much, if any discussion there
is on this point at my IA renewal sessions next month.
On 2/2/07, GRANSCOTT(at)aol.com <GRANSCOTT(at)aol.com> wrote:
Tim posted...
P
greenley(at)starband.net Guest
Posted: Fri Feb 02, 2007 7:46 am Post subject: Interesting panel-mount handheld GPS comment |
I hope that would be a TRS-80 model 100.
Bill
think we have much latitude in this respect. Mounting a GPS on an
experimental requires no FAA sign off unless you are making major
changes to the AC. Just a thought.
Tad Sargent
mike(at)learningplanet.co Guest
Posted: Fri Feb 02, 2007 7:53 am Post subject: Interesting panel-mount handheld GPS comment |
I don't normally make posts regarding AirGizmos, but in this case I
feel compelled to tell a bit of the story, just so you guys can know.
AirGizmos is a very small company. I designed the Panel Dock for the
Garmin 196 when I was building my RV-9A. It was simply a solution to
a problem that I had when designing my panel. I am fortunate to have
a friend who is in the plastics industry. We worked together to make
something that we could be proud of. It was always intended for
experimental use. The business just grew because other builders had
the same problem as I did. I have been amazed at the number of
positive emails I have received from fellow builders.
Well, over time it seems that certified owners have noticed the
AirGizmos products because they are looking for solutions to the same
issues. They want something safer than the yoke-mount contraption
they've been using. So, we've worked to have burn tests and load
analyses done on the Panel Dock to make it easier for people to get
337s approved. Again, this isn't the market we were targeting, but
there is definitely a lot of demand.
What is really interesting is that this comes down to politics.
Apparently the people in the avionics industry are not happy. We've
been approached by the leader of one professional organization saying
we need to join their association "or else." It felt like extortion
to me, so we declined. Well, now we see this story. We have good
working relationships with several avionics shops and local FSDOs,
and we've provided everything short of a PMA for our products.
The sad part is that in my opinion the AirGizmos Panel Dock is a
good, safe solution. Much safer than the yoke mount for obvious reasons.
Mike Schipper
RV-9A - N63MS - www.my9a.com
RV-10 - #40576 - www.rvten.com
www.airgizmos.com
On Feb 2, 2007, at 6:43 AM, Tim Olson wrote:
to mount it.
expensive to buy. The FAA's proposal would make it illegal for
manufacturers to produce a replacement or modification part if
they know (or should know) the part would end up installed in a
certified aircraft--that is unless they obtain production approval
from the agency. But that costs tens of thousands of dollars,
something many companies can't afford. While AOPA agrees production
approval is necessary for critical parts like connecting rods and
cylinders, it isn't needed for non-critical parts like a portable
GPS panel dock or traffic detector that enhance pilot safety.
See AOPA Online http://www.aopa.org/whatsnew/newsitems/
apparently
james.k.hovis(at)gmail.co Guest
Posted: Fri Feb 02, 2007 8:02 am Post subject: Interesting panel-mount handheld GPS comment |
When it comes to radio gear, remember you have to deal with another
Fed agency, the FCC. Depending on the radio service and spectrum used,
the FCC requires equipment used, whether a signal reciever like a GPS
unit or a transmitter to be certified to conform to the FCC rules by
the manufacturer, similar to FAA TSO process. If you're a Ham, you can
build your own gear for use in the spectrum allocated to Amatuer Radio
service, but I'm not sure about the Aviation service, whether
build-your-own is allowed. So unless Radio Shack made a transmitter
registered with the FCC for your Trash-80, I doubt you could legally
(FCC-wise, not necessarily FAA) use it.
JKH
Just a thought.
Tad Sargent
Posted: Fri Feb 02, 2007 8:05 am Post subject: Interesting panel-mount handheld GPS comment |
The point of the article was TC aircraft, NOT experimental. The mounts
are pretty popular in TC aircraft as well.
Just a thought.
Tad Sargent
deej(at)deej.net Guest
Posted: Fri Feb 02, 2007 8:08 am Post subject: Interesting panel-mount handheld GPS comment |
greenley(at)starband.net wrote:
Bill
I kinda liked the "White Whale" Model III myself... *grin
-Dj
Posted: Fri Feb 02, 2007 8:33 am Post subject: Interesting panel-mount handheld GPS comment |
What it shows is a total lack of practical common sense within the
FAA. Other than a possible increase in electrical load (very MINOR at
that), what else would this affect? Is the structure altered? Doesn't
appear so. Is weight increased? Not really. Is safe aircraft operation
enhanced? I think so. Can the aircraft be brought back to "original
condition" if the installation was removed? Looks like to to me. The
only thing needed for this should be a logbook entry or at the most a
form 337 filing even for TC aircraft.
JKH
think
> Just a thought.
> Tad Sargent
Posted: Fri Feb 02, 2007 8:48 am Post subject: Interesting panel-mount handheld GPS comment |
The problem is in the definition. The FAA has allowed PORTABLE devices
to be used in certified aircraft. PORTABLE devices do not have to meet
the FAAs testing and installation guidelines. When you physically mount
a PORTABLE device to the airframe, it's no longer PORTABLE, and the FAA
is re-visiting the wording in this area, since some owners are mounting
the docking stations etc. to the airframe. The FAA doesn't see
hardmounting a docking station and having the GPS (or whatever)
removeable as meeting the spirit of the interpretation. At leat that's
what I hear.
Linn
James K Hovis wrote:
<james.k.hovis(at)gmail.com>
JKH
> think
> experimental
> AC.
> > Just a thought.
> > Tad Sargent
Tim Olson
Posted: Fri Feb 02, 2007 9:25 am Post subject: Interesting panel-mount handheld GPS comment |
When I first saw these things, I was amazed. It was like magically
reading the minds of the people on how to best put a nice handheld
into a panel. I didn't even consider putting one in my Sundowner,
because I didn't think I could get it approved. But, even though
I think for a harcore IFR panel you're best putting the info on
an integrated MFD, I think it's a fantastic option for the homebuilders.
The 496 is an extremely impressive device. I've even recommended
to my own father that if he builds a plane, he should buy one
of the AirGizmos and do just that...mount a handheld in the plane.
I didn't realize that people would even try to put them in a
certified plane though, although from the comments returned
on this thread already today, I guess I agree...I can't
see why you shouldn't be able to. I've always just equated
handheld with non-approved and extended non-approved to mean
"can't do in a certified plane". That's a poor assumption
I guess.
You know, what burns me the most is that if you look at
the GOAL of the FAA, it's generally safety. And what
could make today's VFR AND IFR planes safer than affordable
ways to get weather data into the panel. Again, I think if
you're doing a really hardcore IFR panel, you're probably
best off doing an MX-20/MX-200/EX-500/Chelton/OPTech type
thing, because you'll have much better integration than
doing it on a separate box. But, I would think that even
for people who HAVE some of that stuff, these panel mount
handhelds would be a fantastic solution. Weather data
in the cockpit IMHO is a minimum requirement type thing.
I wish you luck in your education of the FAA on the issue,
because you've got a great product, that serves a very
useful market niche, and has the potential for adding
a lot of safety to todays aircraft. The fact that you even did
burn and load testing is a sure sign that you're doing your
share to do it right. You should shoot an email once in
a while about your product to the list, as you get
significant happenings. I don't think anyone here would be
offended, but on the contrary, they'd probably love to hear.
Michael Schipper wrote:
I don't normally make posts regarding AirGizmos, but in this case I feel
Garmin 196 when I was building my RV-9A. It was simply a solution to a
problem that I had when designing my panel. I am fortunate to have a
experimental use. The business just grew because other builders had the
same problem as I did. I have been amazed at the number of positive
analyses done on the Panel Dock to make it easier for people to get 337s
approved. Again, this isn't the market we were targeting, but there is
Apparently the people in the avionics industry are not happy. We've been
approached by the leader of one professional organization saying we need
to join their association "or else." It felt like extortion to me, so we
declined. Well, now we see this story. We have good working
relationships with several avionics shops and local FSDOs, and we've
The sad part is that in my opinion the AirGizmos Panel Dock is a good,
Mike Schipper
www.airgizmos.com
> mount it.
> to buy. The FAA's proposal would make it illegal for manufacturers to
> pilot safety.
> See AOPA Online
> --Tim Olson - RV-10 N104CD - Flying
> do not archive
Posted: Fri Feb 02, 2007 9:58 am Post subject: Interesting panel-mount handheld GPS comment |
One of the requirements of a panel mounted GPS (I think) is that it have
a separate attachment that warns of signal loss (raim?) that is in the
pilot's view when he scans the instruments. You do not find that in a
hand-held GPS. In fact, your handheld GPS may go TU and you won't
notice for quite a while ...... when you notice that the GPS airplane is
parked somewhere far behind you. Bad news in an IFR environment. Ranks
up there with a gyro compass that dies on ya because the vacuum pump failed.
Tim is right .... with the FAA, it's all about safety ...... trying to
protect us from ourselves and our penchant for taking the
less-espensive-route (notice I didn't say cheap) and relying on
something that may just not be fully functional when you need it.
Lets take a handheld radio. You can buy one for a whole lot less than a
panel mount, and it'll be as good or better in it's operation. Even has
a VOR display!!! But it's PORTABLE and it runs on batteries. Batteries
run down and then it's useless. Kinda like my AnywhereMap on a trip!
So you plug it into ships power ...... and the jack fails, or the cable
fails ..... pick any scenario ..... and now you're stuck. What do you
do when your headste mike takes a dump???? Do you have another mic
plugged in that you can use? Have you tried your hand mic lately???
Most die and are never replaced .... and yeah, I'm guilty here too. I
feel naked when I can't communicate ..... or navigate .....
And back to your GPS ...... do you regularly tune in your VOR receiver
to make sure it's still working??? I'll be a lot of you don't. When
your GPS croaks, it's a bad time to find out your VOR won't tune or died
somehow.
Just a few things to think about, and I'm not pointing fingers here
.... if I get a few folks to really think aboout the complacency thingy
.... I'm happy.
Linn
Tim Olson wrote:
I guess.
n8vim(at)arrl.net Guest
Posted: Fri Feb 02, 2007 10:20 am Post subject: Interesting panel-mount handheld GPS comment |
>You do not find that in a hand-held GPS.
I don't know about the others, but my GPSMAP 296 has a white ALARM wire
that you can hookup to a relay to drive a buzzer, light, or whatever you
want. The signal activates whenever a message pops up on the display,
such as "GPS SIGNAL LOST" along with about a hundred other messages.
The signal does work, but curiously there's no mention of that wire in
my 296 manual.
-Jim 40384
linn Walters wrote:
have a separate attachment that warns of signal loss (raim?) that is
in the pilot's view when he scans the instruments. You do not find
that in a hand-held GPS. In fact, your handheld GPS may go TU and you
won't notice for quite a while ...... when you notice that the GPS
airplane is parked somewhere far behind you. Bad news in an IFR
environment. Ranks up there with a gyro compass that dies on ya
a panel mount, and it'll be as good or better in it's operation. Even
has a VOR display!!! But it's PORTABLE and it runs on batteries.
Batteries run down and then it's useless. Kinda like my AnywhereMap
on a trip! So you plug it into ships power ...... and the jack fails,
or the cable fails ..... pick any scenario ..... and now you're
stuck. What do you do when your headste mike takes a dump???? Do you
have another mic plugged in that you can use? Have you tried your
hand mic lately??? Most die and are never replaced .... and yeah, I'm
guilty here too. I feel naked when I can't communicate ..... or
navigate .....
died somehow.
..... if I get a few folks to really think aboout the complacency
thingy ..... I'm happy.
Linn
Posted: Fri Feb 02, 2007 10:41 am Post subject: Interesting panel-mount handheld GPS comment |
Sure, we can make the cockpit safer...ban all portable electronic
devices, especially game boys, dvd players and Ipods from aircraft
cockpit. Ban cigar lighter receptacles. Put the TC aircraft pilots
back to VOR, ADF and Loran until they can afford a certified panel
mount GPS. That will really enhance safety.
I see it now, kids in back seat, with "are we there yet" syndrome,
with nothing but crayons and coloring books, "helping" the pilot's
concentration.
While we are at it, might as well ban all the panel mount VFR GPS's
that have the same shortcomings as the portables. Yup, Uncle is here
to protect us from ourselves.
On 2/2/07, linn Walters <pitts_pilot(at)bellsouth.net> wrote:
Tim Olson
Posted: Fri Feb 02, 2007 11:14 am Post subject: Interesting panel-mount handheld GPS comment |
I know it might not have been intended to invoke a laugh
Kelly, but your post reminded me of something...
I consider to be one of the TOP safety devices in my
airplane to be the "ISO" button on my intercom. You
don't know how many times I've saved myself from a wailing
kid. My wife and I wish they had those for our cars.
and better yet... I always carry ear plugs. No, the kids
don't need them anymore, but one time on final
from a trip, my daughter said "I gotta poop", and since
she was potty training my wife got out the portable kid
toilet and sat her down. Them ear plug things work well
in the nostrils too, and it can prevent some serious
flight safety issues.
I'm also not ashamed to admit I always carry one of
those "bottles" with me. If I'm on an x/c trip to an
unfamiliar airport, after a 4 hours flight, I think
it's a great flight safety enhancer to NOT be thinking
about how bad you want to be on the ground for some
relief.
Yup, it's the little things that count...and having
good quality gear available to the masses can only help...
but ONLY if they use them for their intended purpose.
Kelly McMullen wrote:
concentration.
> failed.
