Wiring a MAG Toggle Switch
msteffensen(at)ups.com
PostPosted: Thu Feb 01, 2007 4:31 am    Post subject: Wiring a MAG Toggle Switch Reply with quote
Bob,
I am using your Dual Alt & Dual Buss setup in my RV10 with one mag
(Left)and the lightspeed ignition system. I bought a switch from B&C
it's a on and off switch, (2 terminal).
I am confused on wiring the toggle switch.
Based on your the diagrams, I belive that I install the switch with the
keyway up and the wire runs between the switch (terminal 1) and MAG, the
shielding is attached to the other terminal (#2) on the switch and a
grounding screw on the MAG.
As I understand, the MAG live when the switch in open and it's dead when
the switch is to ground.
Please advise as I don't want the MAG live when I think it's dead.
Thanks....Mark Steffensen
nuckollsr(at)cox.net
PostPosted: Thu Feb 01, 2007 7:31 am    Post subject: Wiring a MAG Toggle Switch Reply with quote
At 07:24 AM 2/1/2007 -0500, you wrote:
Bob,
Yes . . . to turn OFF a magneto, you CLOSE a switch to make
a connection that kills the mag.
So check your switch with an ohmmeter and orient it in
the panel such that it is CLOSED with the toggle in the
down position.
I didn't know B&C was selling any two-terminal switches.
When I sold them that part of my business, I carried only
the three-terminal, SPDT style switches so that ANY function
could be achieved irrespective of the keyway position. This
allowed a builder to install keyway lock washers all facing in
the same direction. In this case, you MIGHT find that the
switch you purchased will be "upside down" compared to other
switches on the panel.
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
PostPosted: Thu Feb 01, 2007 10:44 am    Post subject: Wiring a MAG Toggle Switch Reply with quote
Bob,
Do I need to take one of the terminals of the switch to a firewall
ground so that when the switch in open the MAG is grounded and when the
switch is closed the MAG is not grounded or does the switch have this
function without taking a terminal to a grounding point?
Subject: Re: Wiring a MAG Toggle Switch
From: Robert L. Nuckolls, III (nuckollsr(at)cox.net)
Date: Thu Feb 01 - 7:31 AM
Bob,
the
when
down position.
( EVERY day . . . )
PostPosted: Thu Feb 01, 2007 11:10 am    Post subject: Wiring a MAG Toggle Switch Reply with quote
At 01:42 PM 2/1/2007 -0500, you wrote:
Bob,
You wire it per the diagrams where p-lead shields are
grounded to the mag or engine under the cowl. The switch
USES the shield to provide a ground at the panel. The diagram
is explicit as to how shields are handled and grounds supplied.
mprather(at)spro.net
PostPosted: Thu Feb 01, 2007 12:02 pm    Post subject: Wiring a MAG Toggle Switch Reply with quote
No 'grounding' of the mag system is required. Closing the mag switch
causes one end of the p-lead winding to be connected to the other end of
the p-lead winding (in a slightly roundabout way) which disables the
magneto from sparking.. From the standpoint of wiring the switch, it's
only a bit of a coincidence that one end of the p-lead winding is also
connected to the magneto body which is bolted to the engine case which on
most airplanes is known as 'ground'..
So, the closed switch should connect the p-lead (the 'free end' of the
'primary' winding) to the body of the magneto. No additional connections
required. And, this method of wiring offers the lowest risk of p-lead
noise to other electronics in the airplane..
Matt-
Bob,
>Bob,
the
when
down position.
( EVERY day . . . )
