canpilot03(at)yahoo.ca Guest
Posted: Wed Jan 31, 2007 6:03 am Post subject: Dimension of speedster tips |
Hi All,
I want to build a set of fiberglass speedster wing tips for my Model 4!( droop tips now)
Could some one with time on their hands measure their tips for me and give me some Dimensions!
1......angle from bottom to top surface
2......distance from inboard edge to out board edge (top suface only needed)
3...... radius at leading edge
4...... thickness of fibreglass
I am going to carve these tips from blue foam and glass them ,then remove the foam!
Has anyone done this ?Any suggestion are greatly appreciated!
Many thanks
Gil Levesque
Model 4 1050
Rotax 582
Now you can have a huge leap forward in email:[url=http://us.rd.yahoo.com/evt=40705/*http://mrd.mail.yahoo.com/try_beta?.intl=ca] get the new Yahoo! Mail.[/url] [quote][b]
Michel
Posted: Wed Jan 31, 2007 7:07 am Post subject: Dimension of speedster tips |
| Quote: | From: Gill Levesque [canpilot03(at)yahoo.ca]
I don't know what "blue foam" is, Gil, but you should first test if it doesn't dissolve in the polyester or epoxy. I think that, for that respect, you're safer with epoxy. Why do you want to remove the foam after? If you leave it there, it makes a great sandwich construction and you can use a thinner layer of glassfiber , hence lighter. Working with glassfiber reinforced plastics, the general thumb rule is that you must have at least 70% of the weight as glassfiber. Because that is what gives strenght. The plastic is only to glue and keep in place the glassfiber.
Cheers,
Michel
JimmieBlackwell(at)austin Guest
Posted: Wed Jan 31, 2007 8:37 am Post subject: Dimension of speedster tips |
Gil
I will try to get the measurements you need tomorrow or Friday, Wx permitting. Wx here in Central Texas is to cold for this cowboy to go flying or even be in the hangar.
Please elaborate a little more on the measurement you need for the, "radius at leading edge".
Jimmie
Posted: Wed Jan 31, 2007 9:33 am Post subject: Dimension of speedster tips |
Hi Gill,
You might check with John McB first and see what his
costs from the factory.
Also John was going to produce some clear tips where
you could install your wing lights inside and keep the
tips clean from drag. Easy for walk around
inspections too.
Third, I think 2 layers of light weight S glass over
the foam and leave the foam there would work. (AKA
Michels idea) You can carve hunks out of the foam and
leave "ribs" to lighten it up, if you want. I have
been thinking of adding foam ribs to mine to reduce
the concave upper surface problem mine has. Leaving
the foam in assures you retain the shape.
I have epoxied over foam, smoothed and light sanded to
get a good surface, then glassed over that for a very
nice finish on my rudder gap seal. Worked well. Not
sure about the weight on a larger surface, but you can
sand down the inside after you remove the foam if you
go that way.
Just some ideas...
Kurt S.
--- Gill Levesque <canpilot03(at)yahoo.ca> wrote:
| Quote: | Hi All,
| Quote: | I am going to carve these tips from blue foam and
appreciated!
Many thanks
Gil
Now that's room service! Choose from over 150,000 hotels
in 45,000 destinations on Yahoo! Travel to find your fit.
http://farechase.yahoo.com/promo-generic-14795097
lcfitt(at)sbcglobal.net Guest
Posted: Wed Jan 31, 2007 12:08 pm Post subject: Dimension of speedster tips |
Gil,
For some reason I didn't get your original post, just a couple of replies.
What you are suggesting will work fine in my experience. I think the trick
will be making them both the same so you don't introduce a roll tendency.
The foam will help there. You may want to make some templates with the
profile you want and match the left and right to minimize twist.
For final finish, the glass airplane folks will use a thick mix of
microballoons and epoxy to fill the weave. It is very light weight and very
easy to sand. It sounds like a fun project. I'd say go for it.
Lowell
| Quote: | --- Gill Levesque <canpilot03(at)yahoo.ca> wrote:
> Hi All,
> appreciated!
> Many thanks
> Gil
Michel
Posted: Wed Jan 31, 2007 1:46 pm Post subject: Dimension of speedster tips |
On Jan 31, 2007, at 9:06 PM, Lowell Fitt wrote:
| Quote: | For final finish, the glass airplane folks will use a thick mix of
and very easy to sand
I did the finish on my customised cowling with West Systems
microballoons and epoxy. Great stuff! Go for it, Gil!
Michel
barry(at)pgtc.com Guest
Posted: Wed Jan 31, 2007 2:18 pm Post subject: Dimension of speedster tips |
Blue foam works fine.
Barry West
ppeerenbo(at)charter.net Guest
Posted: Wed Jan 31, 2007 6:28 pm Post subject: Dimension of speedster tips |
I also want to do the same, but I was thinking of modifying the drop tips
Paul N102DG
