ericparlow(at)hotmail.com Guest
Posted: Tue Jan 30, 2007 9:58 am Post subject: Fuel Return? |
This is how we did it in the tunnel (the line on the right above the brake
line is the return line). It can then go out to that tank or can "T" into
that line and you will want to pull from the other tank when purging the hot
fuel (if you are doing it that way). Has anybody else lined up the fuel
system to allow for straight lines connecting the pump, filter and flowscan?
Am I missing the reason they are not lined up to start with?
Hope this helps.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
75.68 KB |
321 Time(s) |
LloydDR(at)wernerco.com Guest
Posted: Tue Jan 30, 2007 10:58 am Post subject: Fuel Return? |
The one caveat I would like to put out there for Alternative engines
users, is that in the Eggenfellner install, and any other that will
require a high volume pump, the fuel should be returned to the same tank
that it was drawn from, preventing an overflow situation. This is why we
use a duplex fuel valve, so it automagically rolls the return line to
the correct tank.
Dan
N289DT
Posted: Tue Jan 30, 2007 1:01 pm Post subject: Fuel Return? |
Jesse,
Does your fuel return have a separate selector?
We plan to use the Andair duplex valve (p/n FS 20-20-D2) using -6 lines for
both supply and return.
We also built a "shelf" off the floor of the tunnel to mount the
filter/pump/sensor to.
This allowed us to put 2-3" of insulation directly on the tunnel floor under
the pump/sensor.
Also, we wrapped the brake lines with nylon spiral wrap in the tunnel.
After the insulation was packed into the tunnel for a trial fit we found the
brake and fuel lines could chafe on the shop heads of the rivets directly
below them in the tunnel.
Here's a few pictures of the lines, valve, pass-thrus, parking brake, and
the center console.
ERic--
40014, N104EP
----Original Message Follows----
Subject: RE: Fuel Return?
Date: Tue, 30 Jan 2007 12:57:43 -0500
Hope this helps.
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
33.54 KB |
352 Time(s) |
34.2 KB |
328 Time(s) |
38.62 KB |
321 Time(s) |
28.1 KB |
332 Time(s) |
31.06 KB |
352 Time(s) |
Posted: Tue Jan 30, 2007 4:30 pm Post subject: Fuel Return? |
No, it always goes to the left tank. It is only plumbed in as a purge valve
for fuel servos that allow you to pump cold fuel through the system and get
the hot fuel out to eliminate the hot start problems.
Do not archive.
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
Posted: Tue Jan 30, 2007 6:04 pm Post subject: Fuel Return? |
I've read about 6-way valves and purge valves etc., but haven't had
anyone tell me why the return (for any reason) can't be Td into the line
somewhere between the selector and the mechanical fuel pump. It seems a
far simpler solution to me.
Linn
millstees(at)ameritech.ne Guest
Posted: Tue Jan 30, 2007 6:35 pm Post subject: Fuel Return? |
Linn:
There are 2 reasons why that idea is not advisable. 1. The fuel is hot
coming from the injectors, and needs to be cooled in the fuel tank prior to
returning to the engine. 2. to maintain ballance, you need to return the
fuel to the same tank that you took it from, so you do not over fill one
tanks, and empty the other. Your idea would immediately return the hot fuel
to the engine, increasing the likelyhood of vapor lock.
Steve Mills
RV-10 40486 Slow-build
Naperville, Illinois
finishing fuselage
Posted: Tue Jan 30, 2007 6:54 pm Post subject: Fuel Return? |
I can't imagine why you couldn't do it that way, but if you are trying to
purge hot fuel and replace it with cold fuel, it is better to put the hot
fuel on the tank side of the selector so you can get cold fuel out of the
other tank from the side you are putting the hot fuel in. I think Allen
Barrett said that just mixing the hot fuel with the cold fuel aft of the
firewall would be good enough, but I like the idea of sending it to the
tank.
Does this make sense?
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
ericmpmail-rv10(at)yahoo. Guest
Posted: Tue Jan 30, 2007 6:55 pm Post subject: Fuel Return? |
I've put a return line into the one tank I have built
so far. It is easy to do and I just ordered extra
fittings. In case of ECi engine or diesel, etc.
As to why not to T it back to the incoming line, this
could result in vapor lock. The return line is
pressurized relative to the line from the tank and you
could end up with a fairly high recirc rate (hotter
every loop). Also, I understand that bubbles in the
return fuel line are possible even in normal systems.
You also have the possibility of pressure instabilites
if the line from the tank is small or restricted. Pump
adds X+ pressure to inlet pressure and therefore total
pressure could be higher than expected at fuel
injectors, etc. Final fuel regulator should take care
of this but it is the recipe for a feedback loop.
If you run a tank dry, you may have enough air in the
loop that the pump cannot prime. another issue is it
might build air pressure, preventing draw from a tank,
or vapor lock during ground soak, or ?
Fuel contamination, switching tanks does not "clear
the line" immediately due to local re-circ.
I'm sure there are others. You can try a bench mockup
and look at potential failure modes.
These are good questions to ask of any fuel system.
Eric
40150
--- linn Walters <pitts_pilot(at)bellsouth.net> wrote:
but haven't had
be Td into the line
Linn
bob.kaufmann(at)cox.net Guest
Posted: Tue Jan 30, 2007 7:27 pm Post subject: Fuel Return? |
On the Helio Courier, we would run the left tank down an hour, and then burn
from the right tank until we made it run to the point of trim plus half of
what we expected for the remaining flight. We did this because all of the
return went into the left tank and that was one way of keeping the aircraft
in some semblance of trim. We never had a problem with hot fuel operating
in some of the places we flew out of, even when the conditions were less
than perfect. Less than perfect would be the most positive way of
describing it. We would do a lot of takeoff and landings, in "hot"
environments with out a fuel problem.
Bob K
91/89 to go.
Posted: Tue Jan 30, 2007 7:51 pm Post subject: Fuel Return? |
If you are using an alternative engine that has high flow, you would
eventually heat the fuel by looping it, this is why it is returned to
the tank and mixed. But if you are using a Lyco, Jesse states that it is
just a small amount of fuel for the return to dump the hot fuel.
Hope this helps
Dan
BPA(at)bpaengines.com Guest
Posted: Wed Jan 31, 2007 4:37 am Post subject: Fuel Return? |
Actually sending the fuel back to a tank is the ideal method. But if
your wings are sealed, that would be a job and a half I would think. The
whole idea is to cool the engine driven fuel pump. To 'T' the hot
between the selector and the engine driven pump would be a last resort.
Allen
