n113gb(at)yahoo.com Guest
Posted: Mon Jan 29, 2007 8:16 pm Post subject: stitching ribs |
Ya, I've got one. Why would you even want to take the chance on being the first casualty when the answer is one that basically doesn't weigh anything, costs next to nothing, yet gives you a little stronger product. I was willing to invest 10 - 12 hours to eliminate one more possible problem. After all, isn't homebuilding all about learning to build the safest product possible? Rib stitching is a very interesting skill to learn and after a while it can be an enjoyable experience. I would do it again in a heartbeat.
Gary Olson
Oshkosh
Float Flyr
Posted: Tue Jan 30, 2007 7:21 am Post subject: stitching ribs |
To stitch or not to stitch, that is the question.
I don't think there is a person here who would not recognize the physical strength of rib stitching. that's the plus.
Removing the skins at a future date may be a little easier.
Rib stitching is done after the cloth is shrunk. so the tension on either side of a rib can be equalized easily.
It looks right.
The stitching minuses are:
It takes longer to do. My cat can fix up a pretty good knot so I don't think any one who can build a plane will have too much trouble with that.
It is not as sleek/smooth there will be tapes and little bumps that may show through.
Of course it will be heavier... You are putting more into the wings. Not only the string but the tapes and extra dope to apply them.
It is hard, if not impossible to rib stitch through fuel tanks.
Pros for the gluing:
It is faster.
It is lighter.
It is more aerodynamic
Cons for gluing:
You may not be able to get the cloth shrunk with an even tension on each side of a rib... If you don't fixing it may be difficult.
Removing the cloth may damage the ribs if you are not very careful.
A small void in a joint may have bad results as the shear forces a void in the glue joint can exert may separate a large piece of cloth on a rib over a period of time.
What to do:
Get all the info you can remember none of your planes are supersonic or going to see +/- 7 G.
Go with your decision, being as careful as possible to do a good clean job.
Noel
Kitfox III-A
All glued up....Still like the look of stitching.
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
MichaelGibbs(at)cox.net Guest
Posted: Tue Jan 30, 2007 8:42 am Post subject: stitching ribs |
Dave sez:
| Quote: | What did the former companies reco-mend ? denney ,skystar, avid, and
now Sportplanes ?
As Don said, the only recommendation that matters is from the maker
of the glue that holds the fabric on, and they say to rib stitch.
Poly-tac is very strong in sheer, less so under a peel load.
| Quote: | What does the airplane Kit manufacturer ask for in build manual?
That is what is required for inspection here.
I'm pretty sure my manual refers me to the Poly Fiber manual for
instructions on attaching fabric. If you don't follow the Poly Fiber
instructions, you haven't done it per spec.
Mike G.
N728KF
lcfitt(at)sbcglobal.net Guest
Posted: Tue Jan 30, 2007 10:26 am Post subject: stitching ribs |
I suspect that the Polyfiber recommendation is generic in nature. Example -
the Rans rib was previously fabricated from aluminum tubing. The contact
surface is probably a tangent of about an eighth of an inch wide. I have
seen their new ribs and the capstrip - all aluminum stamped rib - is
probably a half inch wide. With our 1" capstrip I think we can get away
with a bit more leeway in the decision process. That said, I did rib
stitch, largely because of a discussion such as this. I think someone said
something about "belt and suspenders". Something like fuel tank valves,
essential busses, dual ignitions - those things we just don't want to wish
we had when the proverbial "combination of factors" smites us.
Lowell
dosmythe(at)cox.net Guest
Posted: Tue Jan 30, 2007 11:31 am Post subject: stitching ribs |
Dave,
I must admit, this whole thread between you and me was a test. You remember my post a couple weeks ago about the list becoming a basic CHAT room. I wanted to see how far you would go trying to convince everyone that rib stitching wasn't necessary.
You asked for proof of a cap failure and I gave you one. You never mentioned it or acknowledge it just kept saying, "rib lacing not necessary"... You never offered one piece of informative, factual information except to say, rib stitching not necessary". You asked all the questions and accepted no answers.
Finally, I almost spit my first cup of coffee all over the computer this morning when I saw your final words. "anymore questions" ? Dave, you asked all the questions ("what did SS say, what did Avid say, what did John say, has there ever been a cap failure, and on and on.") Your very latest now want's a survey. What purpose would that serve except to tie the List up with more unnecessary CHAT? Rib lacing is highly preferred and recommended by Poly Fiber. Period. In your last post you said you would have to be sold on rib lacing. I really don't know what else it would take to sell you.
Gary Olsen answered your "anymore questions" the best of all. If that's not reason enough, what else do you want?
>>doesn't weigh anything, costs next to nothing, gives a little stronger product, invest 10 - 12 hours, build the safest product possible, interesting skill, enjoyable experience.>>
BTW Dave, I don't have any more questions.
Don Smythe
jdmcbean(at)cableone.net Guest
Posted: Tue Jan 30, 2007 4:46 pm Post subject: stitching ribs |
Why is this an issue?... Rib Lace ! It's fun and you get to learn. Poly
Fiber recommends a mechanical attachment and there are a few "approved"
methods.
What is Kitfox Aircrafts point of view... Rib Lace ! It's fun and you get
to learn. Poly Fiber recommends a mechanical attachment and there are a few
"approved" methods.
Round cord or flat cord... I like the flat... takes a little more time but I
like the look..
I have never looked out at the wings and said... I wish I hadn't rib
laced....
Fly Safe !!
John McBean
208.337.5111
www.kitfoxaircraft.com
"It's not how Fast... It's how Fun!"
9:31 AM
dave
Posted: Tue Jan 30, 2007 5:05 pm Post subject: stitching ribs |
John , it is not an issue,
I only stating that a vast majority of Kitfoxs are not stitched.
I certainly do not want to caue any concern for the many owners and builders
of these great planes.
I fly mine with out stitching over 250 to 300 hours per year and no
troubles.
If I was to recover would i stitch ? Possibly but in a 582 I doubt it.
The 1 inch wide capstrip does a excellent job at adhesion.
Look at many Ultralights with 1/2 " Round tube with fabric "glued to them
only" not to mention alum ribs that are only 1/2 "
That is my ten cents worth,
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
occom
Posted: Wed Jan 31, 2007 4:13 am Post subject: stitching ribs |
Hi Dave, you sure know how to start a debate! I heard back from John
Falconar about the Hipec method. He states that I can use his covering
method on the structure I have primed with Stits epoxy primer and epoxy
varnish with the proviso that I scuff up areas of attachment a little. Now
the Hipec method does not ask for any stitching or finish tapes. I have seen
a Coot with just this method and it's held up very well to ten years of
hangar rash. A young and energetic has built a Rans S6 using it and he's
pleased with it. I haven't decided yet, but if I use the Polyfiber method it
would make sense to use the full method. If someone wanted to avoid the
extra work of finish tapes and lacing it would make sense to use a method
that does not ask for them I would think. In my case the extra work will not
be a determining factor. I have the Hipec book coming and will decide when I
have all the information. I did have occasion to pull some fabric free of
structure and in peel it come free with only moderate effort.
eskflyer(at)lvcisp.com Guest
Posted: Wed Jan 31, 2007 5:28 pm Post subject: stitching ribs |
This is a quote from you DAVE
" I have no trouble flying without stitching. And remeber Poly fibrre is
most likely being over cautious for liability reasoning.
I don't think that if you not stitched that there is any case for alarm
at all. "
Dave
DAVE you are talking out of both sides of your ass and neither one is winning.
When I suggested using the same sparkplugs but a different part number than rotaxes you hammered on me for not Buying and following rotaxes recommended parts . SO where are you going to make up your mind on this . You cannot say to only use rotax parts but when it comes to your wings and the fabric manufacturer I" Dave" know whats best and dont listen to the factory they are only saying this for liability reasons .
And to change the subject while I am at it I would really like to see you land and take off in a TRUE 1 FOOT OF WATER. The damage done would be something to behold lol. Now if you are skip landing and the flying off that is another thing . But to say you are landing and taking off from this is a little bit much on the story telling side.
John Perry
