push to talk switch
lcottrell
PostPosted: Sun Jan 28, 2007 5:48 pm    Post subject: push to talk switch Reply with quote
Hi,
I am normally on the Kolb list and one of the guys there suggested that I could find the answer to one of my problems here. I have a grip on my stick that has five buttons, one of which is supposed to be a push to talk button. However it only has two connections on it. The other buttons control my EIS. I had thought that a I-Com push to talk switch was merely a momentary switch. When I cut into the wire I find a red, green, white and black wire. The red and green show continuity when the button is pushed. The white and black also are a closed circuit. I really don't want to screw things up, can anybody enlighten me as to the best way to hook this up.
lcottrell(at)fmtcblue.com
Larry, Oregon
view of switch
 Filesize:  31.89 KB
 Viewed:  400 Time(s)
nuckollsr(at)cox.net
PostPosted: Mon Jan 29, 2007 5:31 am    Post subject: push to talk switch Reply with quote
At 05:48 PM 1/28/2007 -0800, you wrote:
Hi,
a momentary switch.
Correct. ALL PTT buttons are normally open, momentary
operation.
Then use these two wires.
Didn't your stick grip come with a schematic? If not,
contact the suppler and suggest that his product is
NOT ready for prime-time until it's shipped with
lucid, tell-all instructions.
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
