jeepacro(at)cox.net Guest
Posted: Thu Jan 25, 2007 8:31 pm Post subject: wings |
Has anyone chose to rib stitch instead of riveting the skin to the wing's? I'm thinking it will leave the rib's stronger this way as apposed to drilling into them. Any thought's
Rob.
Posted: Thu Jan 25, 2007 8:58 pm Post subject: wings |
| Rob.
Rob:
Rib stitching works better with flat wood ribs.
Fabric rivets work better with round aluminum tubing.
Kolbs have amassed thousands of hours over the years with no
indication of weak ribs because of rib stitching. It is a well
proven, approved method of fixing fabric to the wing.
_________________ John Hauck
Titus, Alabama |
Richard Pike
Posted: Thu Jan 25, 2007 9:00 pm Post subject: wings |
Yes I have, and yes I think it would.
But almost no one on the list agrees with me.
However, I am unwilling to abuse my airplane sufficient to find a conclusive
answer...
Don't know how long it takes to drill all those holes, but my wife and I rib
stiched one wing in half a day, and a friend brought his son over the next
day to see how it was done and we did the other one in about three hours.
Richard Pike
MKIII N420P (420ldPoops)
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Posted: Thu Jan 25, 2007 9:12 pm Post subject: wings |
| john h
Hi Gang:
Made a boo boo. The above is incorrect. Should have said, "No
indication of weakened ribs because of drilling for fabric rivets."
Xin loi!!
Titus, Alabama |
planecrazzzy Guest
Posted: Fri Jan 26, 2007 5:25 am Post subject: Re: wings |
Hi Richard,
Just wondering.....on a Tractor , the rib stitching needs to
be "more" in the area of the prop blast.....
Did you just keep the same pattern all the way , since it's a pusher ?
Gotta Fly...
Mike in MN
34.99 KB |
299 Time(s) |
Richard Pike
Posted: Fri Jan 26, 2007 6:30 am Post subject: wings |
But you were correct the first time.
There is no indication of weakened ribs because of rib stitching... <grin>
Richard Pike
Kingsport, TN 3TN0
Richard Pike
Posted: Fri Jan 26, 2007 6:50 am Post subject: wings |
Yep. But I put a few extra on the tail surfaces. Probably more than
necessary...
Richard Pike
Kingsport, TN 3TN0
Posted: Fri Jan 26, 2007 7:01 am Post subject: wings |
<grin>
| Richard Pike
Morning Richard:
I agree.
Last night, after I went to bed, I remembered what I was trying to
think of about the comparison of rib stitching and fabric rivets. It
has to do with grip and pull.
Wooden rib caps are usually flat and wide. Rib stiching does a good
job of covering the same width of fabric and reinforcing tape as the
width of the rib cap.
On the other hand, rib stitching a 5/16" tube presents a problem or
two. First, if we grab the same amount of reinforcing tape and fabric
as the width of the rib, the rib stitch will pull the fabric down
around the round rib cap. Second, if we grab the apex of the round
rib cap, we may not have sufficient material to secure it correctly.
I may be wrong, but that is what was running through my head when I
went to sleep last night.
Now, which system is quicker? Probably depends on the operator.
However, it doesn't take long to mark and drill the rivet holes before
the fabric goes on. Then a quick once over with the pencil soldering
iron to burn through the reinforcing tape and fabric. Setting and
popping the rivets is quick. All this requires one man.
I have very little rib stitching experience. I stitched the rear
longerons of the mkIII fuselage in the area of prop drumming. Was
made more difficult because I had already installed the fuel tank and
most of the stitching was "blind" stitching. Don't want to do that
again.
Take care,
Titus, Alabama |
Richard Pike
Posted: Fri Jan 26, 2007 7:34 am Post subject: wings |
Correct on all counts. If you are going to rib stitch 5/16" tubing, you want
1/4" wide reinforcing tape.
Perhaps the most important thing is your mentioning that rivits take one
man. If you are going to do it by yourself, by all means, use rivits.
If you have the luxury of a companion to talk to while you poke the needle
back and forth from one side of the wing to the other, with a cup of coffee
sitting on the stool next to you, rib stitching becomes more appealing.
Richard Pike
Kingsport, TN 3TN0
Posted: Fri Jan 26, 2007 8:16 am Post subject: wings |
For what it's worth...
John H. has some important points re: stitching, and bunching of
tape, etc. And as I already stated, stitching is really a two man job.
Although I intended on rib-stitching, my mind can easily be changed!!!!
My only question is: Are the rivets very noticable when the wing is
finished???
If they aren't, then I will go back to the rivet method. It will be a LOT
less work, that's for sure.
Mike in Utah
Laugh, share and connect with Windows Live Messenger
Posted: Fri Jan 26, 2007 8:49 am Post subject: wings |
is
| finished???
| Mike in Utah
Mike:
Take a look.
67.61 KB |
304 Time(s) |
Titus, Alabama |
Dennis.Kirby(at)kirtland. Guest
Posted: Fri Jan 26, 2007 12:24 pm Post subject: wings |
<< Has anyone chose to rib stitch instead of riveting the skin to the
apposed to drilling into them. Any thought's -- Rob. >>
Rob - I rib stitched the fabric to the wings of my Kolb. I like to
think it was less work than drilling a thousand holes in 5/16" tubes.
Plus, the finish is less bumpy. Like you, my thoughts are that it will
be much easier to remove the old fabric if I ever have to replace the
wing fabric.
But best of all, learning & perfecting the rib stitching technique was
an enjoyable and very gratifying part of the building process for me!
Learning the special finishing knot was fun.
If you are even mildly considering rib stitching over rivets, my advice
is, "Go for the rib stitching!"
Dennis Kirby
Mark-III, 912ul, 63 hrs
planecrazzzy Guest
Posted: Fri Jan 26, 2007 12:32 pm Post subject: Re: wings |
A Thousand Holes...?
There's your problem.... You drilled 750 holes too many.....
Gotta Fly...
Mike in MN
| Dennis.Kirby(at)kirtland. wrote: | <<Has>>
wing fabric.
Dennis Kirby
do not archive |
Steven Green
Posted: Sat Jan 27, 2007 4:29 am Post subject: wings |
Mike,
If you decide to go with the rivets and buy your covering supplies from Jim
and Dondi they will send you a drill jig to make drilling the ribs a little
easier.
Steven
finished???
Mike in Utah
_________________ Steven Green |
planecrazzzy Guest
Posted: Sat Jan 27, 2007 6:23 am Post subject: Re: wings |
Hey Steve,
I had my Doubts about that drilling jig at first...
But that little sucker really worked GOOD !
Gotta Fly...
Mike & "Jaz" in MN
Picture below is for the question , Are rivets MORE noticeable...
Most picture, the rivets won't show up ( I looked ) but this picture you
can see them.... Judge for yerself
123.47 KB |
319 Time(s) |
Posted: Mon Jan 29, 2007 12:57 pm Post subject: wings |
<< your mentioning that rivits take one man. If you are going to do it
by yourself, by all means, use rivits. If you have the luxury of a
companion to talk to while you poke the needle back and forth from one
side of the wing to the other ... rib stitching becomes more appealing.
Richard Pike >>
I was able to stitch both wings solo. It's easiest done with the wing
hanging from the ceiling, trialing edge up. In looking back at my
builder's log, the first wing took about 4.5 hours to rib stitch; the
second one, a little more than half that time. And it was STILL
appealing for me!
As Richard also pointed out, I used quarter-inch wide reinforcing tape
(at Jim & Dondi's recommendation) over the 5/16" rib tubes. This did an
excellent job of minimizing any pucker at each stitch, while still
providing adequate surface area for the stitch to grip. You can sleep
peacefully now, John H.
Dennis Kirby, with orangutan arms, in
Cedar Crest, NM
