dave
Posted: Wed Jan 24, 2007 12:21 pm Post subject: Fuel Flow, continued. |
Lowell,
so if he had his cessna fuel selector at both and he lost on tank only
or did he have one tank selected ?
Dave
On topic My Kitfox fuel system seems to work well -- I have no vent tube on
the wing tanks at all.
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Float Flyr
Posted: Wed Jan 24, 2007 12:43 pm Post subject: Fuel Flow, continued. |
Dave if you were to loose a cap in flight ... Your ears would get cold....
Seriously though... You would probably lose the fuel in the tank that lost
the cap. And you would have to make another cap.
I lost a cap a couple of years ago. I used a chrome feed stem for a toilet
and soldered it into a gas cap that I'd removed the plastic from the inside.
T removed the rubber sealing ring before soldering the tube in and once in I
installed the cap with the tube pointing straight up so I could mark forward
on the cap. Then I bent and trimmed the tube to "look right"
I used a bit of MEK to remove the mark I made for front. It doesn't leak
and it does work total cost was under $5.00 sure wish I had the gear for
silver soldering.
Big snow storm on here today... There'll be tons of snow to push around
with the J5 tomorrow!
Still no ice on the bay. So the 'Fox is still on floats. The rebuild kit
for my fuel pump should be I tomorrow that will take care of an hour or so.
Noel
After thought... To archive or not... Not... Do not archive.
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Float Flyr
Posted: Wed Jan 24, 2007 12:51 pm Post subject: Fuel Flow, continued. |
I've known enough pilots who have lost various quantities of fuel from open
gas fillers in flight one thing is for sure the gas does get sucked out.
It may, or may not, have something to do with the boundary layers getting
broken up around the gas filler. I guess the reason isn't so important
especially at the price of gas now days.
Fluid dynamics can be spooky.
Noel
[quote] --
Kitfox III-A
Guy Buchanan
Posted: Wed Jan 24, 2007 1:13 pm Post subject: Fuel Flow, continued. |
At 11:50 AM 1/24/2007, you wrote:
| Quote: | There is one overriding assumption that seems to be common to all the posts
and that is that the fuel essentially sits quitely and overflows the tank
filler neck because of transfilling. I don't think that is necessarily the
case. Based on what I experienced and the tales of others - granted the
sample is very small, Consider that my flight was in Central Nevada over
the desert and mountains and there is always turbulance there.
But the strange thing is that you ended up with one full tank and one empty
tank. Now my system readily cross feeds from one tank to the other, so if I
was sloshing fuel out, or siphoning, or whatever, both of my tanks would
empty at about the same rate. Next time I fill up I'm going to time how
long it takes one full tank to equilibrate across both tanks, just for
grins and another data point.
Guy
Deceased K-IV 1200
A glider pilot too. |
lcfitt(at)sbcglobal.net Guest
Posted: Wed Jan 24, 2007 2:53 pm Post subject: Fuel Flow, continued. |
Guy and others,
I guess my origanal post might be a bit misleading. When I first noticed
the low fuel in the right tank, the other tank registered mostly full. This
was about an hour into the flight. I have no memory of what the sight
gauges looked like on landing after the 12 gallons blew out.
Lowell
eskflyer(at)lvcisp.com Guest
Posted: Wed Jan 24, 2007 3:10 pm Post subject: Fuel Flow, continued. |
This is getting ridiculous.
Do you all not know what makes a wing fly?. if not you need to study it .
The area that the filler gas cap is in is in a high suction zone on the wing
. If you leave it off then yes your fuel will be sucked out fast and
furiously.
There should never be a fuel cap left off loose or otherwise. This is
part of your PREFLIGHT. If you do not have a written preflight checklist
then I would suggest you make one and follow it everyflight .
Complacency is the excuse of dead pilots
John Perry
DO NOT ARCHIVE
Float Flyr
Posted: Wed Jan 24, 2007 4:15 pm Post subject: Fuel Flow, continued. |
The more I go over the check lists the more I ask myself the question, "Am I
being complacent today?" If I'm nor sure I'll check the list again. I've
only flown once without a checklist. That was one time was with a very high
time bush pilot in the second seat. I felt as naked as a Jaybird especially
as I wasn't thoroughly familiar with the operation of that plane.
Going by the list on at least one occasion I have found items that prevented
me from flying. In my mind it's a lot better to be down here wishing I was
up there than to be up there wishing I was down here!
As john said, and I paraphrase ... Use your written checklists.
Noel
[quote] --
Kitfox III-A
Lynn Matteson
Posted: Wed Jan 24, 2007 4:35 pm Post subject: Fuel Flow, continued. |
Right on, John. Another thing to study might be the lowly insect
sprayer....air gets blown over a tube which leads to a liquid in a
tank...sound familiar? Some of these newer folks might never have
heard of such a contraption, but believe me, they existed at one time.
Lynn
On Jan 24, 2007, at 6:09 PM, john perry wrote:
study it .
the wing . If you leave it off then yes your fuel will be sucked
out fast and furiously.
This is part of your PREFLIGHT. If you do not have a written
preflight checklist then I would suggest you make one and follow it
everyflight .
John Perry
DO NOT ARCHIVE
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
rjdaugh
Posted: Wed Jan 24, 2007 6:18 pm Post subject: Fuel Flow, continued. |
Both you guys are right.
But if your tanks can cross feed - via header or otherwise - the tank that
will empty is the one WITH the cap on. Yes, the fuel is going out of the
tank without the good cap seal, but the air going into the system to
displace the fuel with be going into the other tank - the one with cap on
correctly. So it is the OTHER tank (the one with a good cap!) that will
empty first.
Torgeir! Help!
Randy
_________________ Randy
Kitfox 5/7 912S
Black Hills, South Dakota |
Posted: Wed Jan 24, 2007 6:38 pm Post subject: Fuel Flow, continued. |
Randy
I would dare you to test your theory but then that would probably cause a
engine to quit in flight . No you are wrong on this one ,the tank with the
lid off will empty first every time . Remember that you are pulling fuel
from an opening around 3 inches arcross. and the other tank is feeding a 1/4
inch line , Now which will empty first .
John Perry
DO NOT ARCHIVE
dave
Posted: Wed Jan 24, 2007 6:51 pm Post subject: Fuel Flow, continued. |
John, I have to agree with you as well.
That is why I have a shut off for each tank .
Hell , Someone try it and report the findings.
Did oned Kitfox just go down recently due to a fuel cap missing?
I really think this arguement is getting silly now.
I have no idea if GA aircraft have a vent tube or not but I will say if you
run on LEFT TANK and it runs dry , your engine stops and Likewise on right.
But with fuel selector on both- what happens ?
Dave
PS when i was in flight school nearly 30 years ago we were taught on
walkaround to start at right wing tank , engine , prop around nose to left
wing tank , left leading edge , airlerons, flaps etc then fuselage stab. ,
elevator , rudder etc and when were at the tail we were to inspect the fuel
caps from the REAR to ensure they are on and aligned properly.
rjdaugh
Posted: Wed Jan 24, 2007 7:20 pm Post subject: Fuel Flow, continued. |
You are right; I don't want to test it. But what if the fuel cap is just on
poorly - only one lug caught - or on backwards? And my cap is less than
2" open cross section. Yours must be the old pre-unleaded type cap.
Another factor (which was mentioned by Lowell) was turbulence. If the plane
is bouncing wildly, the main loss mechanism could be due to splashing and
our discussion of relative pressure would be rather moot.
But someone a couple of months ago reported just what I describe. Their
tank that emptied first was the one WITH the cap on.
Guy mentioned measuring how fast the two tanks equalize levels. I have
checked this and the answer is that it depends. ! As the levels get
closer together, it is not surprising that the flow is slower. But when
there is significant differential (as in height or pressure differential)
the flow is about half a gallon per minute. At that rate, it would not
take long to make quite a deficit in your anticipated range.
Randy
Kitfox 5/7 912S
Float Flyr
Posted: Wed Jan 24, 2007 7:30 pm Post subject: Fuel Flow, continued. |
The short answer is any time you are siphoning or blowing fuel out of an
aircraft the range is cut down. When both tanks empty you either come
down.... or look for a real long ladder. Seriously though without a
reasonable place to do a forced approach any loss of fuel can be dangerous.
Some GA have their vents under the wings facing forward. Not all aircraft
have any kind of header tank. I worked on a Super Cub one time that had two
header tanks one in the front and one in the back.... I don't know if that
was something particular to that plane, which was a spotter with the Italian
air force, or not.
As I understand it the reason for the header tank is to allow the plane to
access fuel while in different attitudes which may stop fuel flow from the
tanks.
Noel
[quote] --
Kitfox III-A
Guy Buchanan
Posted: Wed Jan 24, 2007 7:38 pm Post subject: Fuel Flow, continued. |
At 04:36 PM 1/24/2007, you wrote:
| Quote: | Right on, John. Another thing to study might be the lowly insect
Do you remember, Lynn, whether that tube was immersed in the liquid? Or was
there just a hole in the cap? Perhaps you could try it both ways and let us
know if there's a difference.
Guy Buchanan
Deceased K-IV 1200
Lynn Matteson
Posted: Thu Jan 25, 2007 3:45 am Post subject: Fuel Flow, continued. |
Yes, Guy, as I recall, the tube went into the tank, and down to the
"corner" of the(usually) round tank. Geez, I just thought of another
similar application of this principle...the paint sprayer gun...DUH!
on me! At any rate, the bug sprayer had you putting air pressure
over that drop tube via a plunger. This air would come out a nozzle
at the end of the plunger cylinder, and blow directly over the upper
end of the drop tube. This arrangement was the ideal pressure/siphon
device, while our planes have a rather crude and inefficient
"facsimile." Maybe I wouldn't say crude if I was the one who just
lost a tankful in an hour like Lowell did.
I also had a sandblaster that worked on the bug sprayer principle.
Lynn
On Jan 24, 2007, at 10:37 PM, Guy Buchanan wrote:
> time.
liquid? Or was there just a hole in the cap? Perhaps you could try
it both ways and let us know if there's a difference.
Guy Buchanan
N369LM |
Fox5flyer Guest
Posted: Thu Jan 25, 2007 4:36 am Post subject: Fuel Flow, continued. |
As I recall the NTSB archives are full of incidents related to fuel
starvation and it's probably the number one cause of engine failure, so IMO
this is a good topic and may save some people the pain of a broken airplane,
or worse.
I've been watching this debate with interest because it happened to me with
my old Model II. I took off with full tanks for a breakfast run and before
I'd gotten ten miles I noticed that my left tank was at the half way mark
while the right tank was full. I watched it for another minute or so and
saw that the left tank level was still dropping rapidly so I did a 180 and
headed home, landing just about the time the left tank was nearly empty.
What I determined was that two things had happened. One, the right tank
fuel with the cap not completely secured (on by only one tab) was being
sucked out, and two, the left tank being pressurized by the secure cap/pitot
was pushing the fuel from the left tank down through the header and out the
right tank.
My conclusion was that the loss of fuel was a combination of both the
pressurized left tank and the leaking from the right tank. I don't know
whether or not the engine would have quit had the left tank run completely
dry, but I suspect it would not have so long as there was still fuel in the
right tank, but that's definitely debatable.
Now, this is different from a tank that has the cap completely missing.
That's a big hole, especially in turbulence where you can lose a lot of fuel
very fast, BUT considering the internal baffling, as the fuel level goes
down the rate of loss will slow, right? No, because it's still being pushed
out by the pressurized left tank (which is going down) and the right tank
level will stay up until the left tank unports. Right? What I'm not sure
about here is what would happen when the left tank empties.
Personally, I'd really like to see the results of a controlled test in
flying conditions to see just what would happen if this was allowed to go
all the way. It would take the loss of a few gallons of gas and of course
at altitude above an airport with a long runway, but it shouldn't be hard to
make the test. Probably best with two people so the pilot only flies the
airplane. Then again, it would depend on the configuration and integrity of
the fuel system because no two are exactly alike. I have no idea how a test
could be made while on the ground.
Basically I agree with Randy.
Deke Morisse
S5 Outback
NE Michigan and 14F, breezy
dave
Posted: Thu Jan 25, 2007 5:46 am Post subject: Fuel Flow, continued. |
Deke,
Can I ask , What is the reasoning for the vent tube that would allow this to
happen ?
If you have a pitot cap and a shut off for each wing tank before the header
tank.
If you need a vent for the header tank make it indenpendant of the wing
tanks ?
Does this make sense ?
In your case then the right tank would have drained ?
Dave
Fox5flyer Guest
Posted: Thu Jan 25, 2007 6:55 am Post subject: Fuel Flow, continued. |
Those are good questions Dave. The vent tube is simply to allow the header
to fill and stay filled. The reason why ours vent to the right tank is
because it's the closest one (behind the seat header). Some folks have the
vent tube independent of the wing tanks, as has been discussed here.
Personally, I don't think the vent tube had anything to do with what
happened to me and had the left cap rather than the right cap been installed
incorrectly the same would have happened in reverse. In my opinion it's
simply the differential pressure between the tanks when one tank is being
vacuumed (loose cap) and the other pressurized (pitot). Both tanks are
connected by the header. Valves on the tank lines would help, but they
create a whole new set of problems. Overall, the factory setup as designed
by Dan Denny/Dean Wilson/Skystar is sound and like any other airplane is not
foolproof when mistakes are made like forgetting to install a fuel cap or
installing it incorrectly.
Deke
dave
Posted: Thu Jan 25, 2007 7:14 am Post subject: Fuel Flow, continued. |
Deke,
My Buddy has an AVID with 2 - 12 gal wing tanks.
and a header behind the seat.
Stupidest system i seen. He fills both tank full and if it is parked not
level the fuel runs out the low tank cap .
I told him to put a shut off on each tank but he has not yet. Still has to
worry about fuel transfering tank to tank via the flow thru the header tank.
Dave
kitfoxmike
Posted: Thu Jan 25, 2007 7:22 am Post subject: Re: Fuel Flow, continued. |
I made my system simple and it has been mentioned by others, that they use the same.
I have NO gascalator, I run from my tanks ,each, to a filter, inline filter, to a shutoff valve, to the header tank, the right tank has the vent that goes to the header tank.
I have a line that goes from the header to another inline filter and then to a shut off valve then to the fuel pump. I run one tank at a time, when that tank gets down to about an inch off the bottom of the site hose I switch to the other tank.
I also have the problem with the right tank draining into the left tank, but when the left tank gets full that stops. Not a problem, but I like to know what I have so I settled on using only one tank at a time.
This time of year I don't go anywhere and I always want spare fuel, so I put av gas in the right tank, 5 gallons, and only use the left tank. The right tank with the av fuel will not go bad like auto fuel so that's my reasoning for that.
The hoses I use is the blue hose, which turns green from the auto fuel, from the tanks to the header. from the header I have aluminum tube, then blue hose at the main filter and shut off valve, then aluminum tube out through the fire wall, then I have auto, fuel injection hose from the fire wall to the fuel pump, from the fuel pump to the carbs, fuel injection hose.
I fly over 250 hrs a year and I have had no problems with this setup. The hobbs on the airplane just hit 802 yesterday.
