Liquid Cooling
Float Flyr
PostPosted: Fri Jan 19, 2007 6:19 am    Post subject: Liquid Cooling Reply with quote
As a few know I'm the one who has been asking about the HKS engine (700E). I definitely won't be replacing my engine for at least a year.
In the meantime I'd like to clean up the plane a bit. and the first thing I noticed was the rad hanging off the belly. This must have the aerodynamic stability of a brick or less.
I have noticed on some of the pictures here that some of the planes have what looks to be a very nice scoop mounted to the belly of the plane and could offer a streamlining effect, directed airflow through the rad and possibly even offer a damper of sorts for winter flying. I haven't seen anything like this scoop available on line and such a scoop isn't mentioned in my construction manual. Building a mould to fabricate one scoop seems kind of expensive.
Three questions.
Are these scoops available?
If they are where do you get one?
How much will it cost?
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Fox5flyer
PostPosted: Fri Jan 19, 2007 7:15 am    Post subject: Liquid Cooling Reply with quote
Building a one time mold isn't expensive if you just use typical one inch blue board foam then cover it with glass. When it's set up remove the foam and you have a scoop. It almost requires the airplane be upside down though, but when the wings and engine are removed it isn't too difficult with Somme help.
I'm going to attach a photo of mine. It's on Sportflight, but the site is down temporarily so I can't send a link. I'll try an attachment.
Deke
scroll down
Three questions.
Noel
 Filesize:  222.43 KB
 Viewed:  795 Time(s)
lcfitt(at)sbcglobal.net
PostPosted: Fri Jan 19, 2007 8:11 am    Post subject: Liquid Cooling Reply with quote
Noel,
I have the scoop offered in the Model IV Speedster kit. I picked it up from
a builder in Alaska that didn't want to use it. Others have gone the hard
way and built their own. I don't think the Speedster scoup is still
available. Contact John to make sure of that.
Regarding winter flying, the scoop actually enhances cooling.
Lowell
Lynn Matteson
PostPosted: Fri Jan 19, 2007 9:15 am    Post subject: Liquid Cooling Reply with quote
Noel-
I've got a scoop from my IV that I'm not using. It's yours for the
postage...or actually I owe Deke a lunch for an owed postage deal, so
you and he could... oh, never mind...let me know where you are.
Lynn
year.
expensive.
Three questions.
Noel
www.matronics.com/Navigator?Kitfox-List _-
Lynn
Kitfox IV-Jabiru 2200
N369LM
Sjklerks(at)aol.com
PostPosted: Fri Jan 19, 2007 9:24 am    Post subject: Liquid Cooling Reply with quote
Hi Lynn, How much speed would you gain by adding the rad scoop that was available from skystar. Jim
msm_9949(at)yahoo.com
PostPosted: Fri Jan 19, 2007 9:29 am    Post subject: Liquid Cooling Reply with quote
Noel,
You have a Model 2, right? As slow (Vne 100) and draggy as the Mod 2 is, do you think the extra weight is justified by the extra couple cruise mph you're likely to gain?
Lowell Fitt <lcfitt(at)sbcglobal.net> wrote:
[quote]--> Kitfox-List message posted by: "Lowell Fitt"
Noel,
Lowell
jdmcbean(at)cableone.net
PostPosted: Fri Jan 19, 2007 11:19 am    Post subject: Liquid Cooling Reply with quote
Noel,
            The scoops are available…
<![if !supportEmptyParas]> <![endif]>
 AUTOTEXTLIST \s "E-mail Signature" <![endif]-->Fly Safe !!
John & Debra McBean
208.337.5111
www.kitfoxaircraft.com
"It's not how Fast... It's how Fun!"
<![endif]--><![if !supportEmptyParas]> <![endif]>
-----Original Message-----
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Noel Loveys
Sent: Friday, January 19, 2007 7:19 AM
Subject: Liquid Cooling
Three questions.
Noel
[quote]<![if !supportEmptyParas]> <![endif]><![if !supportEmptyParas]> <![endif]>          - The Kitfox-List Email Forum -   --> http://www.matronics.com/Navigator?Kitfox-List              - NEW MATRONICS WEB FORUMS -   --> http://forums.matronics.com<![if !supportEmptyParas]> <![endif]>[b]
Float Flyr
PostPosted: Fri Jan 19, 2007 12:02 pm    Post subject: Liquid Cooling Reply with quote
It is a very draggy Model II... very late numbers (736). It is on a nice sleek set of Aerocet straight floats. As I was saying I've been doing a bit of work on the plane the past few days and would like to clean it up a bit. Also dragging those floats up hill does require the engine to do 1quite a bit of work. I thought I could install some kind of shutter in the intake of a scoop to cut down the airflow through the scoop in the winter. To be honest an extra mile or two per hour really doesn't interest me too much on this kind of plane but if I can improve the cooling efficiency in the summer and control the air through the rad in the winter I think it will be worth it.
I am also considering trying some plastic fairings on the wing struts.
It seems there are a few of those scoops around and several of them are on planes. I'll post some measurements and see what fits.
Noel [quote]
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Float Flyr
PostPosted: Fri Jan 19, 2007 12:32 pm    Post subject: Liquid Cooling Reply with quote
Thanks Lowell. I expect if John has one in stock he'll post it. That way
if any one wants to install a scoop they will know where to get them.
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Lynn Matteson
PostPosted: Fri Jan 19, 2007 2:11 pm    Post subject: Liquid Cooling Reply with quote
Beats me...I'm aircooled, so I've never looked into the scoop
situation. But this (the one that I have) is the one that Skystar
provided.
Lynn
Lynn
N369LM
PostPosted: Fri Jan 19, 2007 4:07 pm    Post subject: Liquid Cooling Reply with quote
Thought I did... they are available...
Fly Safe !!
John & Debra McBean
208.337.5111
Float Flyr
PostPosted: Fri Jan 19, 2007 8:02 pm    Post subject: Liquid Cooling Reply with quote
Great! The next questions are how heavy and how much.
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Kfyellowbird(at)cs.com
PostPosted: Mon Jan 22, 2007 10:00 pm    Post subject: Liquid Cooling Reply with quote
I purchased one from Skystar. I would think the new Kitfox would have them available.
Lowell 560KF [quote][b]
avtar412
PostPosted: Mon Jan 22, 2007 10:57 pm    Post subject: Re: Liquid Cooling Reply with quote
http://ph.groups.yahoo.com/group/airsoob/photos/browse/32fc
