sideslip(at)tiscali.co.uk Guest
Posted: Tue Jan 16, 2007 5:42 am Post subject: Radio interference when receiving |
I have a new Jabiru 2200 (85hp) installed in a Murphy Maverick with an Icom IC-A200 panel mount VHFand an external antenna mounted throughthe fuselage skin midway between the cabin and fin using the fuselage for a groundplane.
I am picking up ignition interference when receiving which increases with engine speed.
I have tried running the radio from an independant power supply to eliminate installation wiring and still get the same problem, which seems to indicate that the antenna is picking up the radiated noise.
The engine has suppressed ht leads to the plugs but I am not sure about the leads to the coils.I checked the rotor arms for security and they seem fine.
Does anyone have any suggestions on how to cure the problem?
Geoff Leedham
nuckollsr(at)cox.net Guest
Posted: Wed Jan 17, 2007 6:38 am Post subject: Radio interference when receiving |
IC-A200 panel mount VHFand an external antenna mounted through the fuselage
engine speed.
I have tried running the radio from an independent power supply to
antenna is picking
leads to
Hmmmm . . . when problems arise from a "per-the-factory"
ignition system installation, this can get sticky. I've
never had occasion to get a problem ignition system
into the lab to fix a noise problem. Our production piston
aircraft still use the classic shielded magneto installations
which have evolved into pretty radio-friendly products
over the years.
Are you on a list-server for either the Maverick, the
engine or both? I'd also contact the service rep for
the engine. You may find that he/she is aware of the
occasional odd problem that's easily fixed.
Try running from one ignition at a time. The problem
may be isolated to a single system. If this is true,
likelihood of it being a simple fix is improved.
How much of the wiring is stuff that's used as-supplied
and how much do you install? I did a quick look-see on the
'net for the installation manual. Don't have time to chase
it right now. Do you know where it can be acquired? I'd
like to see the schematic for the ignition system.
Posted: Thu Jan 18, 2007 1:50 am Post subject: Radio interference when receiving |
Hi Bob,
I have tried running one mag at a time- same problem from either.
The ignition wiring is all installed by Jabiru only the mag kill wires have
been installed by myself (screened wires earthing at the engine.
The plug leads are resistive car type but the leads from coils to
distributer caps are not marked so I am not sure about these and have my
suspicions. I will contact Jabiru to find out. Also the plugs are NGK but
not resistive type, perhaps it might be worth me changing these.
The only drawing in the manual I can find is a very basic drawing which
includes wiring for the Jabiru aircraft, and shows the ignition in a basic
form ie.transistor ignition unit feeding to spark plugs.
Geoff
Posted: Thu Jan 18, 2007 8:32 am Post subject: Radio interference when receiving |
At 09:48 AM 1/18/2007 +0000, you wrote:
<sideslip(at)tiscali.co.uk>
Hi Bob,
have been installed by myself (screened wires earthing at the engine.
Okay, try running the engine with kill-leads totally
disconnected at the engine end.
khurst(at)taroom.qld.gov. Guest
Posted: Thu Jan 18, 2007 3:34 pm Post subject: Radio interference when receiving |
Geoff,
I don't remember your saying what kind of noise it is i.e.. Tick,tick .
. . . or a Hash type noise.
I know a chap over here with a Jabiru (with Jab engine) and he had to
put an earth wire on the carburettor to stop static interference on his
radio.
Now if anybody thinks this is a load of hog wash, please don't shoot ME,
I'm only the messenger !
Cheers
Kingsley in Oz.
