Erich_Weaver(at)URSCorp.c Guest
Posted: Thu Jan 18, 2007 9:24 am Post subject: starter warning light? |
A friend recommended adding a warning light to my panel that would simply
indicate whether there was power present at the starter. Is this providing
any real benefit? I presume the warning light would be lit for the few
seconds when I push my push-to-start button, but also when the button was
inadvertently stuck in the on position or the starter contactor was stuck
closed. Are a stuck switch or contactor likely enough to warrant this
warning light? I have vague memories of a starter run-on issue, but
perhaps that is a separate issue all together? Gotta re-read the
'Connection before I forget all the great stuff I learned.
Erich Weaver
nuckollsr(at)cox.net Guest
Posted: Thu Jan 18, 2007 10:12 am Post subject: starter warning light? |
At 09:23 AM 1/18/2007 -0800, you wrote:
Starter "run-on" and "sticking" are two separate issues. Run-on
is a phenomenon unique to permanent magnet motors on starters
that under certain wiring configurations will cause a delayed
dis-engagement of the pinion gear after the engine catches and
the starter button is released.
One solution to this problem is illustrated at:
http://www.aeroelectric.com/PPS/Engine/Starter/PM_Starter_w_RunOn_Relay.pdf
The value of a STARTER ENGAGED light is to detect a stuck
starter button and/or stuck starter contactor. These events
are rare but allowed to proceed without detection is always
expensive.
You can use an LED. Put the LED's ballasting resistor right
at the starter main power terminal. Incorporate into the
wire using techniques described in:
http://www.aeroelectric.com/articles/Homeless/Homeless_Components.htm
Put a diode across the LED in the reverse direction to protect
from small reverse votlage transients that are ALWAYS hard
on LEDs. See:
http://www.aeroelectric.com/Pictures/Schematics/Starter_Engaged_Warning_Lt.pdf
It's a toss up. Adding the light is relatively easy, inexpensive
and doesn't add much weight to the airplane. It's easier to add
while building the airplane than to add it after it's finished.
If you're un-decided, at least pull the wire in and cap it off
to make it easier to add later.
Another instance of value added warning lights for starter
control systems is illustrated at:
http://www.aeroelectric.com/PPS/Engine/Starter/24V_Starter_14V_System.pdf
Here we see a means by which a 24 volt starter can be
serviced in 14 volt airplane. The lights are designed to
detect a stuck contactor in the series/parallel changeover
contactors. An unattended sticking of one of these relays
causes BIG fault currents to flow when buttons are pushed.
< with experiment. >
< --Lawrence M. Krauss >
Posted: Thu Jan 18, 2007 10:41 am Post subject: starter warning light? |
Bob,
On the B&C website, the documentation for the starter relay says you can use the I terminal as a starter on light source.
Is this different than the solutions you have described below?
Ralph
Posted: Thu Jan 18, 2007 11:03 am Post subject: starter warning light? |
At 01:39 PM 1/18/2007 -0500, you wrote:
<recapen(at)earthlink.net>
Bob,
If your starter contactor HAS and "I" terminal, it can
be used for this purpose. I show the "generic" version
because it works with any contactor . . . INCLUDING the
one built onto the starter whether or not it incorporates
an "I" terminal.
Posted: Thu Jan 18, 2007 11:36 am Post subject: starter warning light? |
-----> If your starter contactor HAS and "I" terminal, it can
| Quote: | be used for this purpose.
Posted: Thu Jan 18, 2007 2:11 pm Post subject: starter warning light? |
OK, got it: starter run-on and sticking are different issues. But assuming
I install the warning light and subsequently have a starter run-on
occurrence, will the warning light be on while the run-on is occurring? An
individual suggested to me off-list that if the starter gear is stuck in
the engaged position and the engine is running (push-to-start button
released and starter contactor open), the starter motor could act as a
generator and produce some current. If this is the case, it would seem
that a warning light that stayed on a little longer than the short period
my push to start button was in use could potentially be warning me of the
dreaded run-on condition instead of just the stuck contactor or stuck
starter button. Added value or just wishful thinking?
Erich Weaver
Posted: Fri Jan 19, 2007 5:16 am Post subject: starter warning light? |
At 02:09 PM 1/18/2007 -0800, you wrote:
Yes. While the PM motor is spinning down the voltage generated
by the rotating armature will keep the light lit. As the armature
comes to a stop the light will go out.
| Quote: | An
A much fertilize myth. Starters have over-run clutches. The engine
CANNOT be allowed to 'push' the starter under any circumstances.
Consider that a highly geared starter armature is spinning at thousands
of RPM while cranking the engine at perhaps 300 rpm. When the engine
starts, it jumps up to 1000-1500 rpm. This 3 to 5 times increase in
speed cannot be allowed to impress on the starter's gears and armature.
The forces applied to gear teeth place them at risk. Spinning the
armature places winding and commutator at risk for damage due to
centrifugal forces.
| Quote: | If this is the case, it would seem
The condition we've called "run-on" is poorly named. It's really
"delayed disengagement" do to currents circulating in the pinion
gear engagement solenoid that are being generated in a slowing
armature spinning in a permanent magnetic field. I've never personally
observed this event but it's my understanding that it lasts perhaps
3-5 seconds.
The "run-on" condition is not particularly stressful on the
starter . . . because of the over-run clutch cited. Assuming
(1) you wire your starter engaged light so as to sense voltage
at the starter motor power terminal and (2) it's a PM starter and
(3) you HAVE installed the relay intended to prevent delayed
disengagement then, you would STILL observe a fading STARTER
ENGAGED indication from the annunciator as the starter motor spins
down. This happens in spite of the fact that the relay has broken
the circuit responsible for delayed disengagement.
The light has value in that it shows when voltage is present
at the starter motor terminals at times when it is not expected
or desirable. It will also demonstrate the voltage generating
quality of a PM motor as it spins down after being disconnected
from the battery.
