Mark II Xtra update
icrashrc
PostPosted: Thu Jan 11, 2007 7:34 pm    Post subject: Mark II Xtra update Reply with quote
Just letting everyone know were back to work on the plane. I've uploaded some new pictures to
http://www.picturetrail.com/gallery/view?icrashrc
Scott
www.ill-EagleAviation.com
PostPosted: Thu Jan 11, 2007 7:47 pm    Post subject: Mark II Xtra update Reply with quote
| Scott
Scott:
Looks like you are making progress.
I especially like the photo of your new vehicle that probably arrived
in Kit 2. Wink
DO NOT ARCHIVE
icrashrc
PostPosted: Sun Jan 14, 2007 3:29 am    Post subject: Re: Mark II Xtra update Reply with quote
Maybe Kolb should go in the go-cart business too?
Did you notice the extra corner gussets on the elevators and rudder? I figured i would build mine in instead of adding them later like you had to do. Smile
 Filesize:  35.69 KB
 Viewed:  599 Time(s)
Scott
PostPosted: Sun Jan 14, 2007 6:35 am    Post subject: Mark II Xtra update Reply with quote
| Scott
Hi Scott:
Glad you picked up on the corner gussets. Don't forget the rudder
too.
Has Kolb incorporated them into the plans? I think not, but have not
seen the new mkIIIx plans.
icrashrc
PostPosted: Mon Jan 15, 2007 3:58 am    Post subject: Re: Mark II Xtra update Reply with quote
John Hauck wrote:
Hi Scott:
too.
We put gussets on the rudder as well. I just didn't post a seperate picture of them.
And no. There are no corner gussets on the plans. I noticed them on your plane (at) Sun-n-Fun last year but never got around to asking you about them. Looking at the design it made sense that the single rivet would see a lot of rotational stress so we just went ahead and added them. In the attached pic you can see the corner gussets as well as the slight changes to the cross bracing to help transmit rotational forces to the rudder TE
 Filesize:  34.36 KB
 Viewed:  542 Time(s)
Scott
David Lucas
PostPosted: Mon Jan 15, 2007 4:18 am    Post subject: Re: Mark II Xtra update Reply with quote
Just curious, Has anyone ever used welded joints instead of riveting in putting a Kolb together ? Considering that, for example, moutain bikes these days are all welded aluminium frame and they take an increadable beating, that method of construction could probably be applied to a Kolb. Less simplicity of construction of course, which is a downside but perhaps a stronger joint and it definately looks better. Like I say, just curious. Anybody care to comment ?
David.
PostPosted: Mon Jan 15, 2007 6:19 am    Post subject: Mark II Xtra update Reply with quote
| Scott
Morning Scott:
Rudder looks good, clean and strong.
Steven Green
PostPosted: Mon Jan 15, 2007 4:26 pm    Post subject: Mark II Xtra update Reply with quote
David,
Most of the aluminum tubing used in the Kolbs is 6061-T6. The T6 means it
is heat treated which would be compromised by welding. It would also take a
heck of a jig to weld it up in to prevent warping. As you stated welding
would really add a lot of time to the project. The strength of the Kolb
structure is very adequate.
Steven
Hope my spelling is ok
I don't have a spell checker.
Steven Green
Paul Petty
PostPosted: Tue Jan 16, 2007 8:02 am    Post subject: Re: Mark II Xtra update Reply with quote
Scott,
When did you buy kit 1? Your project and workman ship looks great! I also added the gussets to the rudder and elevator like johns plane. There are some real good mods for the wings as well.
Paul Petty
Kolbra #12
Ms Dixie
912 UL 70" warp
Paul Petty
PostPosted: Tue Jan 16, 2007 8:17 am    Post subject: Re: Mark II Xtra update Reply with quote
Scott,
One other thing i noticed. Flaps. Does the Mark 3 X come with flaps now or did you add them. If added what are your plans for deploying them i.e. mech or eletric.
Paul Petty
Kolbra #12
Ms Dixie
912 UL 70" warp
icrashrc
PostPosted: Wed Jan 17, 2007 3:14 am    Post subject: Re: Mark II Xtra update Reply with quote
Paul,
I purchased Kit 1 At the Kolb homecoming in 2005. Started work on it around 12/1/05. Worked until the end of March on it. I picked up Kit 2 At the Homecoming 2006 and just started working on the plane around Christmas.
Thanks for the compliments. My friend Paul and I both tend to follow some of Burt Rutans wisdom, "your best is ALMOST good enough".
I ordered the Mark III X with the 'Classic' style wing. Kolb will build them either way for you. If you order the flapped wing they mod the cage for you. The flaps and linkage are the same as the Classic.
Scott
APilot(at)webtv.net
PostPosted: Wed Jan 17, 2007 5:06 am    Post subject: Mark II Xtra update Reply with quote
What is the difference between the Mark III Extra wing and the Classic
wing?
icrashrc
PostPosted: Thu Jan 18, 2007 12:10 am    Post subject: Re: Mark II Xtra update Reply with quote
The Xtra wing uses flaperons.
The Classic wing uses seperate flaps and ailerons.
wing?
Scott
APilot(at)webtv.net
PostPosted: Thu Jan 18, 2007 1:18 am    Post subject: Mark II Xtra update Reply with quote
Thanks for the info.
dhkey(at)msn.com
PostPosted: Thu Jan 18, 2007 4:34 am    Post subject: Mark II Xtra update Reply with quote
Some xtra' s have flaps. Most of the xtra lights have flaperons and the xtra
heavies have flaps.
Reply-To: kolb-list(at)matronics.com
Subject: Re: Mark II Xtra update
Date: Thu, 18 Jan 2007 00:10:28 -0800
> wing?
Scott
http://forums.matronics.com/viewtopic.php?p=88532#88532
