clint_bazzill(at)hotmail. Guest
Posted: Wed Jan 17, 2007 7:10 pm Post subject: 912S alternator Was: RE: Kitfox list just like the Lancair |
You energize the regulator. It uses magnets on the flywheel to
generate pulses which are rectified and filtered. Clint
From: "Randy Daughenbaugh" <rjdaugh(at)rapidnet.com>
Subject: 912S alternator Was: RE: Kitfox list just like the
Lancair List - Not building or fhying related do not archive
Date: Wed, 17 Jan 2007 16:29:48 -0700
Well, I will say again that I was told by Bob Robertson's 912S expert that
the 912 has an alternator and needs to have the field energized in order to
charge. I believe it because when I hooked the wire up as he told me, it
all worked as it should and started charging the battery. So a dead battery
gives no joy.
Hope this gives him joy.
Randy
Now to the Kitfox list A guy posts that his 912 won't charge a dead
battery. So far no joy to him as the argument so far has been as to whether
the 912 has an alternator or generator and the related thought as to whether
it has a field coil.
The truth is in the book and not wanting to be a stiffler of the "chat"
someone else will have to go there and be the "idiot" or "spoil sport"
Lowell.
Turn searches into helpful donations. Make your search count.
http://click4thecause.live.com/search/charity/default.aspx?source=hmemtagline_donation&FORM=WLMTAG
